can we use factory GM head units from..
Old Nov 3, 2005 | 11:42 AM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
01 02 or 03 cars and trucks? i wanted to add a GM CD unit form a Yukon 03 to my car.. but i didnt know the deminsions or if it will function properly.. anyone here know?
Old Nov 3, 2005 | 01:41 PM
Crayz9000's Avatar
Car: '86 IROC, '87 Volvo 240, '09 Malibu
Engine: LB9 5.0L
Re: can we use factory GM head units from..
As long as you can get a reverse wiring harness for the radio, or get at least 6" of wiring harness out of the donor car, yes. The plugs for the newer radios are different but they all have the same basic features.
On the other hand, if the radio has something like TheftLok, things get much more interesting.
Old Nov 8, 2005 | 12:28 AM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
a friend of mine bought an 05 whatever the replacement for the s10 is and put an aftermarket radio in. they had to keep the factory radio and rewire it so that he could store it under the seat. in short, it was a massive PITA.
Old Nov 8, 2005 | 01:03 AM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
I installed a Delco CD from an 02 sunfire. Simple plug and play. The wiring harness plugs are the same. The only modification i had to do to make it fit right, was cut the left mounting tab slightly.
Well, the radio has the 7 band eq and one of the slider covers is missing, but it works and for $40, I couldn't pass it up. Oh yeah on most of these cars, people never activate the theftlock (because it is such a PITA to enable/disable).
My gf's Grand Prix has the same radio, but has only bass/treble controls.
FWIW, I have heard that there are numerous problems with these factory head units. I think you would probably be happier just going aftermarket.
Vintageracer
Jan 10, 2020 05:33 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
ZsTransAm
Aug 11, 2015 07:30 PM
