Wireing problem
Old Nov 25, 2005 | 06:38 PM
vortech35091RS's Avatar
Car: 1991 camaro RS
Engine: 350,vortech heads,zz4 cam,3:73 posi trac,edelbrock carb,wiend stealth intake,raven mufflers,hooker supercomp shorty headers and y-pipe.
Transmission: th700r4
Wireing problem
Okay this may be a no brainer, but then again I don't know much about car electronics. I own a 91 RS and the dude I bought the car from kind of rigged it all up, and I wanted to install a CD player in it, but the harness is gone, how would I fix this problem?
Old Nov 26, 2005 | 09:45 PM
Nic's Avatar
Nic
Car: 1993 Ford Mustang
Engine: 5.0L
run constant and accessories to the fuse box, ground to the chassis, and run speaker wires...pretty simple.
Old Nov 26, 2005 | 10:12 PM
True_bird's Avatar
Car: 1985 Firebird
Engine: ***Bagged 2.8***
Transmission: 4 speed auto
Yea thats simple just run your constant power(clock memoery) switched power from your fuse box, a wire for your antena (if you have one) and your speaker wire witch is a good upgrade from the stock small gauge stuff, fairly simple takes about an hour or so
Kyle
Old Nov 26, 2005 | 10:14 PM
True_bird's Avatar
Car: 1985 Firebird
oppps i forgot you will need a ground there is a nice one right on a bolt in the back of the radio pod take some sandpaper and clean some of the paint up and you're set.
Kyle
Old Nov 26, 2005 | 10:22 PM
Car: 1991 camaro RS
Alright man, thanks for the input I'am no genus when it comes to wireing. Thanks a lot.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Bert87
Aug 23, 2015 03:50 PM
Fronzizzle
Aug 17, 2015 02:52 PM
