tweeter location?
Old Jan 18, 2006 | 10:05 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
tweeter location?
where should i put the tweeters at in my camaro? or the better question would be where have yall put your tweeters and are you happy with it? i have mine currently in the apillars and they are driving me insane they are way to loud b/c of where they are mostly all i hear are highs and i have the treble at -10 on the headunit. i already got another set of apillar pieces so i can move them.
ps. i dont want them in the kick panels b/c i dont want to make/ buy kick panels.
heres a pic of where i have them now.
Old Jan 18, 2006 | 10:29 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
What else are you running with the tweeters? Dash 4x6s or woofers in the doors or what? Your car domain just showed the tweeters/subs and your sony amp/hu.
Also, you can still mount tweeters on the kicks yourself. No need for an enclosure if you just want to mount tweeters. Regardless, try to get them facing you/the passenger (in theory aimed at the dome light). They way they're aimed right now isn't helping you much in terms of sound quality. Also, spacing is really bad @ the a pillar.
Out of curosity, how are you powering the tweeters and what are they wired to?
Old Jan 19, 2006 | 07:57 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Gummie is right on. It really depends on the rest of the stereo. If you just added tweeters to suppliment your stock 4x6s, get them in the front corners of the windshield/dash/a-pillar area, or close to the stock 4x6s. Just don't ruin your dashpad... those are expensive and if yours is in good shape, you don't want to tape stuff to it or drill holes. Anyway, if you've got aftermarket 4x6s that already have a tweeter, you'll find no benefit in adding another set.
If you decide to go to a full component set, then you should definately consider the kick panels. There's no better place to mount speakers in a thirdgen. It helps equalize path length, and allows for the use of bigger, better drivers.
Old Jan 19, 2006 | 02:14 PM
Car: 88 IROC
i have pioneer 4x6's speakers and they are wired with the tweeters to the headunit. but i have bass blockers on both speakers so its all treble. i dont want to get components b/c i dont want kick panels b/c i think they are ugly and expensive. the tweeters get too loud where they are though and i want to move them. where would be a good place to move them?
Old Jan 19, 2006 | 02:16 PM
Jim85IROC's Avatar
Since you seem to have decent 4x6s, I'd just take out the tweeters. Having 2 sets of tweeters is causing more trouble than it's worth.
Old Jan 19, 2006 | 02:30 PM
Car: 88 IROC
well it is kinda an old set of pioneer 4x6's. i want to keep the tweeters b/c it makes more treble which is what i want but the way they are positioned it seems like they are right by your ear.
Old Jan 19, 2006 | 03:00 PM
Jim85IROC's Avatar
Which is exactly the problem when running tweeters on the dash.
Try moving them down to your kick panels. You can flush mount a tweeter into your kick very easily. To see if you like the sound with them down there, try attaching them with double-backed tape to see if you like the sound.
In fact, use that method to try them in numerous places to see if you can find something you like. Try them in the far corners of the dash too, but if you do that, get them as close to the windshield as possible. No wonder what you do you're going to get some cancellation up there, but that's the nature of the beast.
By the way, what kind of tweeters are they? If they're cheap tweeters, chances are you won't like the sound no matter where you put them. Your money may be better spent in a decent quality set of 4x6s.
Old Feb 8, 2006 | 09:02 AM
davidb's Avatar
Car: 92 t/a
TWEET TWEET
I PUT MINE IN THE DOOR PANELS FORWARD OF THE UPPER ARMREST MOUNT... THEY SOUND GREAT! VERY GOOD SEPERATION, I PUT 4 X 6 NON COAX'S IN THE DASH ( ABOUT A DOLLAR EACH FROM PARTS EXPRESS, ONKYO BUYOUTS) BUT THEY WERE TOO LOUD SO I WIRED IN 40 OHM RESISTORS, I REALLY LIKE IT!
Old Feb 8, 2006 | 06:17 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
really in all honesty if you have a really good midrange speaker, you dont even need tweeders. like for instance, i have Memphis 4x6's and 6x9's (i'm pretty sure those are the sizes, it's been a while) and they sound EXCELLENT. i have no need for tweeders, it would just be more money to spend.. just throwin' my $0.02 in
Old Feb 8, 2006 | 06:55 PM
Car: 88 IROC
well i got the tweeters for free so i would like to use them. and my 4x6's i got for free also and they arent very great. but i have those bass blockers on the 4x6's so w/ the tweeters being right there beside them its just all treble. i would like to keep the tweeters but find another place for them. how would they sound mounted on the carpet area of the center console? like below or a little bit farther forward than the ashtray.
Old Feb 8, 2006 | 07:41 PM
BlueZee28's Avatar
well if they're free that's a different story lol
what about in the dash, like right under the "shelf" the top part of the dash?
Old Feb 8, 2006 | 07:57 PM
Jim85IROC's Avatar
All of those locations present the same problems. The unequal pathlengths and the poor integration with the woofers will prevent these locations from sounding as good as the usual kick panel spot.
Old Feb 11, 2006 | 09:19 PM
sgt0704's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
Axle/Gears: what ever stock is
i had put mine back by the 6x9s. on the plasic part. it wasn't bad. not flush. and my door panels were from manual window, so i put a set there to cover up the holes. i like how it was set up, then someone broke into my car, and stole my ****.
Old Feb 12, 2006 | 03:40 AM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
love my kick panel components, no need for any other speakers in my car
Old Feb 12, 2006 | 10:36 PM
Gummie's Avatar
Car: 88 GTA
I drove someone home from work last night and he saw that I had holes in my sail panels (I don't have the cloth covers installed right now). He asked if I wanted speakers and I told him that I already had some and didn't want them/was trying to get rid of them. Cranked up some random music and he saw what I meant
Old Feb 22, 2006 | 04:19 PM
lockchad's Avatar
Car: 88 camaro, black, T-tops
Engine: 305 5.0L
Hey I have a suggestion for you guys. Have you ever connected tweeters out of phase on the dash location. I learned this trick from Steven Head, numerous time IASCA world finalist. It works really good for adjusting the staging of tweeters in non-ideal locations. Give it a shot sometime, you'll be pleasantly suprised.
Old Feb 23, 2006 | 03:11 PM
Car: 88 IROC
i solved my problem by removing them.
Old Feb 23, 2006 | 03:22 PM
Jim85IROC's Avatar
Wiring them out of phase may or may not help them better integrate with the other speakers, depending on their specific position and your ear's position WRT those two speakers. It doesn't actually solve anything, it just gives the potential for better phase integration at your specific listening position. Path length issues, and a whole pile of phase issues still remain.
Lbibb
May 5, 2016 12:00 AM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
