is my amp done? help.
Old Feb 21, 2006 | 11:03 AM
sgt0704's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
Axle/Gears: what ever stock is
i have a 300 wt crunch amp. something odd happened. when ever i turn on the car, my amp automatically goes to protect mode. like something is shorting it out or something. so i unhooked all the spkrs going to it, and i hooked up the power connections from my other amp to it, and same thing is happening. there's nothing that i could see shorting it out. i even unhooked the rca plugs just to be sure. and it just keeps going to protect mode. wtf?
Old Feb 21, 2006 | 11:18 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
If you have just the power connections made (no RCAs or speaker outputs) and it is still going into protect, there is a problem with the amp. You can sent it to Rockford for a flat rate repair.
Old Feb 21, 2006 | 03:41 PM
blackroc68's Avatar
He said crunch, not punch
Old Feb 21, 2006 | 04:30 PM
sgt0704's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
any other ideas how to fix it with out sending it out somewhere?
Old Feb 21, 2006 | 08:13 PM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
Are you running bridged? Something I ran into a while back...Check your sub with a multi-meter to see what kind of ohms it is presenting to the amp. I had a 2ohm stable amp but the sub...(bought off e-bay...nice) was presenting .95 ohms to the amp. It went in to "protect" immediately.
Old Feb 21, 2006 | 09:53 PM
sgt0704's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
it's pushing my mids and highs. as it has for the last 2 yrs.
Old Feb 22, 2006 | 07:15 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
My bad .
Probably not worth fixing. Me thinks it's time for a new amp.
Old Feb 22, 2006 | 04:10 PM
lockchad's Avatar
Car: 88 camaro, black, T-tops
Engine: 305 5.0L
If with no speakers connected it is still going into protection, you have a powered paperweight.
Did it ever fizzle, or let the magic smoke out? Or was their no warning?
Old Feb 25, 2006 | 09:50 PM
sgt0704's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
there wasn't much warning. it would make a weird "zoop" sound. almost as if it had some kind of interference. but would stop after about 2 sec..
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
