RCA's fall off head unit - solution?
Old Sep 28, 2006 | 11:21 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
My RCA's seem to come loose and fall out, at the connection at the back of the deck. The deck has the RCA's come out as cables, with about 6" of slack, then it connects to the RCA cables going to the rear.
Is there a solution? I figured if I epoxied them together, that would be bad 'cuz i'd never be able to remove it.
What i'm thinking now, is some 3/8" dual wall heat shrink. Connect 'em, heat shrink it, and it'll "glue" it together. If/when I have to remove it, an exacto should make short work of it.
I figured i'm probably not the first to have this problem, so I was wondering what others have done, perhaps a better method then what i'm thinking?
Old Sep 29, 2006 | 12:35 AM
CarterCarbureto's Avatar
Car: 1987 Z28 camaro
Engine: 305 V8
Transmission: auto
Axle/Gears: 10 bolt pozi
As redgreen would put it;
DuctTape ^_^
Old Sep 29, 2006 | 07:41 AM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
On the male connector, just bend the outside ring inwards.
Old Sep 29, 2006 | 07:55 AM
thaforce's Avatar
Car: '91 Z-28 Hardtop
Engine: 5.7L TPI L98
Yep, I would take a pair of pliers and bend the outside contacts in slightly then securely wrap them in black tape.
Old Sep 29, 2006 | 08:10 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Old Sep 29, 2006 | 06:28 PM
Sonix's Avatar
Car: 1982 Trans-Am
good idea! Can't believe I didn't think of that..
And it appears to have worked. Right on, thanks guys.
Old Sep 29, 2006 | 09:59 PM
StevenK's Avatar
Car: 91 Z28
:-D
Same thing applies to the slip on Coax connectors for TVs, thats where I originally got the idea.
sweet_87_iroc
Sep 25, 2015 10:01 PM
87iroctheo
Wheels and Tires
Sep 2, 2015 03:29 AM
86White_T/A305
Aug 17, 2015 12:16 AM
ZsTransAm
Aug 11, 2015 07:30 PM
