Power Ant. Upgrade
Old Oct 17, 2006 | 09:46 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
Transmission: 700R4, lots of Mods
Power Ant. Upgrade
Hey all,
I have a '89 Bird and would like to upgrade to the Power Antenna. I was wondering if anyone has done this and how easy was it. and if there is anything additional I must buy besides beer
Thanks in Advance
Brad
Old Oct 17, 2006 | 10:03 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
ive searched some threads and found somthin and a maber got from radio shack that is "an invisible antenna" like some how you put it on the top of your windshield if im rong then sry. im lookin for one 2{ antenna power } miine broke b4 i had my car
Old Oct 20, 2006 | 02:41 PM
85TransAmDude's Avatar
Car: 1985 Firebird Trans Am.
Engine: 305 H.O. 4bbl
Transmission: 700R4.. I think
Axle/Gears: Not Sure, 3.73?
I installed the power antena in my 85 TA...hardest thing about it was hooking it up to the wires and stuff in the deck so that it only comes up when you turn the radio on...i diddnt do it myself i got my father to do it...but its deffinitally possible..and worth it...beats havin your antena cut off by some punk with wire cutters in a parking lot...they do that a lot around here...that and roll condoms down your antena LOL!
Old Oct 20, 2006 | 06:41 PM
Jza's Avatar
Jza
I found that my 89RS, which didn't have the power antenna option, actually had the wiring inside for it. The connector was taped up in the harness, and plugged right into a power antenna unit from a vehicle that has it. It was a grey three cavity connector with pink and orange wires. There is continuity from the radio connector to this antenna connector.
That's one option anyway! Hope it helps.
Old Oct 20, 2006 | 09:10 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
I think I will just buy the antenna assembly from GM parts direct. How does the antenna mount, and how do you get to it?
Old Oct 21, 2006 | 02:55 AM
Jza's Avatar
Jza
Yes, if you get the GM power antenna assembly, it should be plug and play!
It's pretty nasty. You pretty much have to remove the passenger-side fender. You'll have to remove the fender-well lining and remove/loosen most of the fender bolts to make room to get the assembly in. You'll need a special wrench to get the antenna bezel off and on (I have a $25 Snap-On version as well as a $6 AutoZone version, the main difference is the cheap version feels like it's made of pewter The package says "lead-hazard" anyway ).
You'll also take apart most of the passenger-side underdash area.
The antenna motor is held on by the bezel at the top and a bracket at the bottom.
Let me know how much that sucker sets you back, I may need a new one if it turns out mine is not functional.
Old Oct 21, 2006 | 12:31 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
you will breake some of the lil clips from the fender off so you will need new ones the part # direct from gm is 88891017 heres a link for ya GM Parts Direct: Your direct source for Genuine GM Parts
and then lil clips are #20664092
and if you just want the antena repair kit you gotta look it up your self..soryy dono that one
now my question is wat part of the dash do your take apart and does anyone have pics opf this ?
Old Oct 22, 2006 | 12:49 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
sorry for the link not working the part#are there so you can use both
gta90
Sep 15, 2015 04:00 PM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
InfinityShade
Aug 22, 2015 08:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
