Laptop Utilization
Old Nov 1, 2006 | 09:09 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
Laptop Utilization
So I have this really really nice laptop. Ive got a hard wired FM modulator hooked up so I can play music through my car stereo. I've been using winamp with keyboard shortcuts "ctrl+space" for next song in playlist and "ctrl+z" for previous song in playlist, and I put on random play.
Well, I feel like im not fully utlizing my laptop like I possibly could. Ive been thinking about buying a usb gps unit so I can get road maps and such while im driving, and also for wardriving .
I feel as if there is a whole world of possibility that im not even thinking of.
I would use it to tune my car but I run a carbeurated setup.
Is there any form of sensors that I can install on my car that I can hook up to my laptop to get data such as acceleration g level, braking power, etc? I love the idea of having a laptop in my car, and I feel like im really not using it to its maximum potential by just listening to music.
What do you guys think?
Old Nov 1, 2006 | 09:31 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
Not out of the realm of possibility, but most lap tops(and the software) are used for adjusting certain components,mixtures,timing,measuring ect. and are used while the car is parked; usually for modification or repair reasons not for continuos monitoring while actually driving. Although having a monitor with a on board, CPU which monitors your vehicles status sounds cool, but I already have my GUAGE CLUSTER to do the monitoring and me to do the reading.
I would however, like to see my transmission temp, rear axle fluid temp,tire PSI,brake fluid level, air temp (inside the air cleaner and ait tunnels) outter enviroment tempature, and a cool digital compas.
Old Nov 2, 2006 | 09:59 AM
MaineIrocer86's Avatar
Car: 1986 Z28
how do you have the laptop set up in your car? is it just sitting on the seat? got any pictures?
Old Nov 2, 2006 | 05:18 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
Yeah at the moment its just sitting on my passenger seat, if I hvae a passenger, then they get the privledge to place it gently on there laps and caress it.
No pictures at the moment.
I will eventually be building a stand for it, ive seen custom laptop stands that use hot water heating bendable coper tubing.
Old Nov 3, 2006 | 07:25 AM
Car: 1986 Z28
good deal....well when you get something let us know I would love to see it!
Old Nov 3, 2006 | 03:52 PM
Zyth01's Avatar
I was thinking about how to go about doing this as well, is there a program that can run through the OBD1 connection and show you statistics? Or is that just for reading trouble code only?
Old Nov 3, 2006 | 06:12 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
Im not really sure, if you have a fuel injection setup then its totally in the realm of possibility.
Old Nov 3, 2006 | 11:03 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
i run tunerpro on my carputer. gives real time engine data, graphs, virtual dash... its's very nice. Plus, I never have to wonder why my check engine light is on.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
customblackbird
Oct 1, 2015 04:30 PM
CORV3TT3
Aug 23, 2015 11:26 AM
jRaskell
Dec 30, 2000 12:33 AM
