Breaking hatch / windows from loud sound
Old Nov 13, 2006 | 07:41 PM
Gangstajpimpin's Avatar
Car: 25th Anniversary Camaro RS (1992)
Engine: 3.1 V6
Is this possible? My father is saying that if i install subs and better speakers my windows will bust if i bump it while the windows and hatch are closed....please help and dont flame
Old Nov 13, 2006 | 07:52 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
it is posible i busted one in a comp that i was in i aslo was running 9 SUBS
Old Nov 13, 2006 | 08:22 PM
Engine: 3.1 V6
holy crap...what about just 2 12" subs and an amp...
AMP: Kicker ZX650.4
Subs: Kicker CompVR 05CVR124
Old Nov 13, 2006 | 08:23 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
your car would have to be sealed pretty tight with no air coming inor out and you would have to have crazy bassbeing pushed through your subs, the glass in our cars is pretty strong though, especially the hatch.
Old Nov 13, 2006 | 11:51 PM
GTAfanatic's Avatar
you have nothing to worry about with two 12's in the hatch and yes you do have to have the car sealed real good. i also had the 3 12 faceing the glass that was hitting it hard you could see the window flexing it was the best $20 i spent on a window.
Old Nov 19, 2006 | 09:04 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Transmission: 700R4,700R4
Axle/Gears: LSD,LSD
theres nothing to worry about...even tho with my sealed 15" L7 with a lame 500 watts could flex the hatch glass just a little bit
Old Nov 20, 2006 | 08:58 AM
wannafbody's Avatar
Car: 88 GTA
Axle/Gears: 3.27 9bolt
i seen a guy with a VW that busted out the back glass with 4 15's 4500 watts
Old Nov 20, 2006 | 10:28 AM
kcr357's Avatar
Car: S10
Engine: 383
Transmission: th 400
Axle/Gears: Stocker 10 bolt w/4:11's
I did that with 2 xplod 12's and a lanzar 800.1. They sent of chunk of hatch glass into my buddies mom's porch. She was pissed
Old Nov 20, 2006 | 10:50 PM
Zyth01's Avatar
The direction the speakers are pointed makes no difference, the only thing that matters is how much pressure is in the car and the condition of the glass. You can bump as many subs as you want pointed at your hatch but it'll never blow if you have your door open.
Old Nov 21, 2006 | 02:21 PM
wannafbody's Avatar
Car: 88 GTA
wow thats insane from 800watts
Old Nov 21, 2006 | 05:18 PM
1991ON20's's Avatar
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
anything is possible....especially if your glass is old.
Old Nov 25, 2006 | 09:14 AM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
mythbusters made a 48 inch sub powered by a diesel engine that put out 168 decibels at 18hz and all it did was blow out the sunroof. glass did not shatter, just bent the tracks...
Old Nov 25, 2006 | 12:19 PM
MavViper's Avatar
The pressure is going to go through the point of least resistance. My guess is the pressure will go through your seals before it breaks the glass
Old Nov 30, 2006 | 07:47 AM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
I've never heard of a car blowing a hatch without insane pressures... and yes, it will definitely blow through all the other holes in your car first... your seals, your t-tops, vents, undercarriage holes, etc...
you have absolutely nothing to worry about. other than horrible rattles...
Old Dec 7, 2006 | 11:18 AM
airjordan6906's Avatar
Car: 1988 camaro rs
My 1988 camaro with two JL 10' with 500 w kenwood amp and my hatch keeps coming lose how do i fix tht one?
Old Dec 7, 2006 | 11:36 AM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
^^ what he said... my car rattles like a ****.. i hate it
Old Dec 7, 2006 | 12:54 PM
ScrapMaker's Avatar
is it motorized?
if so, then sometimes bad wiring can cause problems
also, if the wiring is having problems even on a non-motorized one, it can trigger the trunk-release relay...
if it's PHYSICALLY causing it to open, then you need to readjust your locking mechanism, since that's pretty damn dangerous...
Old Dec 10, 2006 | 10:32 AM
jpk91rs's Avatar
Car: 91 RS, 00 TA Ram Air, 86 IROC
Engine: 305 tbi, LS1, 355
Transmission: 700R4, 4L60E, 700R4 NonLU
1 ea, 10" L7 Solobaric with 1100 RMS in a ported box and lots of Dynamat. No glass breakage of any kind. Will make your ears ring, though.
Old Dec 13, 2006 | 08:23 PM
Car: 1988 camaro rs
yah like it keeps makeing the screws come lose and then it move down and won't close right
Old Dec 15, 2006 | 11:16 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
That either never happened, or it was when either the crappy subs or the crappier amp literally blew up; smashing the glass.
Old Dec 16, 2006 | 10:14 AM
ScrapMaker's Avatar
I'd be surprised if that lanzar 800 could even blow a single 6x9
Old Dec 16, 2006 | 10:19 AM
jmoney843's Avatar
Car: 89 Iroc Z
Engine: 350TPI
I agree...not to mention Xplod subs...I kind of just thought... and kept reading on
Old Dec 16, 2006 | 10:20 AM
ScrapMaker's Avatar
yeah, I usually just skim over crap like that... but since he brought it up...
Old Dec 16, 2006 | 10:36 AM
Bill/T/D/Y's Avatar
Car: 90 R/S camaro 3.1L stock,
ok can believe it now that hatch can blo out from subs.Saw my buddies escalade blow out the back side glass and spiderweb/flex the windshield last night first hand.Still need to ask him what all he's runnin so i don't blow up my R.S..But his system is stout enuff that not maxxed out(b4 the windows popped out)it was blowin my hair back standin in the open door.The windshield is a total loss(guess i'm lookin for 1 for him at the bone yards.)but the back side glass didn't hit the ground as we were standing there with gloved hands holding them incase they blew.They just poped out at the seals but the windshield flexxed and spiderwebbed and i mean FLEEEEXXEEDD .It looked for all the world like it was made outta plastic wrap.LOL
Old Dec 16, 2006 | 10:54 AM
ScrapMaker's Avatar
Yeah, that's on a (I take it,) relatively-new Escalade... the seals are actually tight enough to cause damage...
on a car like ours, the air will escape in all sorts of places before damaging a window..
hell, the air will just rush out of the window seals, since we don't have an upper door frame. That's how thieves get in so easily, well, one way.
Old Dec 28, 2006 | 07:54 AM
brians88gta's Avatar
Car: 88 gta
Engine: 350 HSR
Axle/Gears: 3:27 borg warner 9 bolt
138.5dbs doesnt blow my window out so you shouldnt have any problems thats 2 jl 12s and a 500 watt bazooka mono block
Old Jan 4, 2007 | 02:22 AM
kcr357's Avatar
Car: S10
Engine: 383
It was a joke Took longer for you guys to call me on that than I thought .
Old Jan 4, 2007 | 09:15 AM
Irving_90Ircz28's Avatar
I i have two jl; w6 13" and two precision power amps pcx-2200 600 rms each, 2 , 6"1/2, 2 6x9" Alpine type R, its like more than a thousand rms , will the bass do any damage to my windshiel or hatch?? my car is an 1990 iroc z28 w/ttops
Old Jan 4, 2007 | 10:49 AM
ScrapMaker's Avatar
if you welded your doors shut, welded the hatch shut, and your car could retain water without leaking, then MAYBE, just maybe, you could break a window or hatch... assuming some other panel didn't blow off the car first...
Old Jan 4, 2007 | 02:25 PM
sLoW'n'StEaDy's Avatar
i had a pair of 10s with kevlar cones running at 1000W @ 1ohm RMS and didnt do much, as they said the window would flex a little but that was about it. By the way they where facing the window
Old Jan 4, 2007 | 02:38 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Mythbusters did a whole episode on this... they made a HUGE sub powered off the car's engine and it blew the sunroof off before windows broke!
Old Jan 4, 2007 | 06:56 PM
Car: 88 gta
Engine: 350 HSR
thank god for safety glass
Old Jan 4, 2007 | 09:08 PM
Turbo's Avatar
You cant in a Camaro - there are two vents right behind the rear tires under the rear bumper cover - all cars have this - cept like cars from the 40's and earlier - but these vents are what makes the the doors shut - if the car didnt have an escape for air the doors would never shut - like pluging a tire pump and trying to pump it. Plus if you look in the spare tire area - there are some many hole that you can see the ground through lol - Plus i have 2 12" Type-Rs 1400 watts 2 6" 4" 6x9 and 2 6" subs which are ran from a 300 watt amp plus two TVs, DVD, and Playstaion 2 (has nothing to do with the window breaking but i just wanted to throw that in)
no window flex or anything
Vintageracer
Jan 10, 2020 05:33 PM
xxx3man`
Sep 23, 2015 10:37 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
db057
Sep 4, 2015 07:57 AM
db057
Aug 22, 2015 08:17 PM
