Stupid speakers.. need help with +- AB
Old May 14, 2007 | 05:51 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
I'm hard pressed to find some 4x6's to actually fit in the front of the TA .. but for now im going to put the factory speakers in .. im removing my stereo. and i had kick panels in .. but now going back to factory (thinking of selling) ... so i have a set of factory 4x6's which say A B on them.. not necessarily out of the TA but are GM ... anyone know what is + and what is - ? .. of course wiring was pre-hacked so i have no connector on the harness end.
Thanks.
Old May 14, 2007 | 07:47 PM
2kflhr's Avatar
Car: '68 396 SS/RS, '02 SS
Re: Stupid speakers.. need help with +- AB
Thanks.
I was told you could put 12 volts on the speaker and if the cone raised the polarity was correct. If the cone retracted the polarity is rolled.
Old May 14, 2007 | 09:31 PM
RocsRose86's Avatar
Car: 1986 Irocz28/04 GMC Yukon
Engine: Ram Jet 350(*TPI*)
Transmission: Turbo 400 w/1500 stall
Ur right u can also just use a cordless drill battery up to 18v and works just as good!
Old May 15, 2007 | 05:55 AM
cub and Matt's Avatar
A 9volt battery works as well. I made a polarity tester for speakers using one.
Old May 15, 2007 | 06:35 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
perfect.. thanks.
Old May 17, 2007 | 07:58 AM
Slow2.8's Avatar
I believe A is positive, this is true for all the models that have A/B stamped on the speaker/plug. Double check using a 9 volt for certainty.
Old May 17, 2007 | 02:41 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
This is an honest question...
Does it really matter?
I know for subs you have to worry about polarity if they are in the same enclosure, but how would small speakers, far from other speakers be affected?
Old May 17, 2007 | 04:22 PM
2kflhr's Avatar
The sound will be distorted somewhat at certain ranges. No more than it take s to wire them correctly why would you not?
djmarch
Oct 2, 2015 10:41 PM
83ho87gn
Sep 26, 2015 08:49 PM
spartanreaper
Sep 25, 2015 07:22 PM
83ho87gn
Sep 24, 2015 08:58 AM
gta892000
Sep 16, 2015 12:37 AM
