Which gauge wire would be good for my 1600 watt amp??
Old Sep 15, 2007 | 01:16 AM
tigercyberslash's Avatar
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
So I got a new Volfenhag 1600 watt amp + 2 12" 1000watt subs today for only $135 I know a great deal huh? Anyway, was wondering which gauge would be the best for this setup someone at Best Buy told me the 4 gauge would be the one to go with...but man they are expensive there like $105 for the amp install kit! Anyway..let me know!!
Old Sep 15, 2007 | 11:53 AM
aceman1's Avatar
Car: 1989 camaro
Engine: 2.8
Re: Which gauge wire would be good for my 1600 watt amp??
i would go with 4 gauge
Old Sep 15, 2007 | 12:06 PM
archemedes's Avatar
Car: 1997 Grand Prix GTP (for now)
Engine: 3.8 sc
I agree 4 gauge best buy doesn't seem to have a huge selection of install kits either. Also please let me know what you think of the Volfenhag one of my reps is trying to get me to buy it, and never has much to demo for me
Old Sep 15, 2007 | 12:17 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
Go to walmart and get the "1000 watt amp kit". It comes with 5 gauge wire and everything you need and if memory serves right it's less than 35 bones. That'll be fine for that amp.
Old Sep 15, 2007 | 12:38 PM
Engine: V8 350 ci
Hmm all right Ill check that out later today, and yeah Ive never used Volfenhag nor had I heard about it before getting these, but they go for a lot so Im sure it'll be worth it. Oh yeah I also have a optima battery in my car in case anyone was wondering..
Old Sep 15, 2007 | 04:25 PM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
since that amp is probably putting out only like a 1000watts 4 gauge will be fine.. but to be completely honest with you wolfenhag isnt the worst but its pretty bad.. some think its good stuff but majority say its garbage
Old Sep 16, 2007 | 02:30 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
thats what I did for my 1000w Legacy amp powering 2 12" 1000w Kickers...
Old Sep 16, 2007 | 08:56 AM
cdoyle's Avatar
Well to be honest Volfenhag is not the worst out there, but it's pretty darn close. I put it in the same category has pyle, pyramid, audiobahn etc.
What is the RMS rating on that amp?
If it were me, I would save up and buy better equipment. It beats buying this now, and a year from now having to buy all new stuff again.
Old Sep 16, 2007 | 12:20 PM
TheBandit's Avatar
Engine: Poncho 350
Originally Posted by cdoyle
It beats buying this now, and a month from now having to buy all new stuff again.
fixed
Old Sep 16, 2007 | 01:15 PM
Engine: V8 350 ci
They work great for me...have very deep bass and is very clear, i never heard any problem with this brand, my uncle had the same setup for at least 3-4 years now, nothing ever went wrong with them. This brand is pretty pricey and i think i got my money's worth. No point in saying go buy another....obviously i have this.......
Old Sep 16, 2007 | 02:01 PM
cdoyle's Avatar
I'm just saying that there are plenty of members on my forum, that have problems with them and brands like them. So it's always best when someone asks for a recommendation on them, to let them know both sides.
Also what is the RMS rating on the amp. What is the fuse size on the amp too. If they put in a small current fuse, then you know it's not drawing the amount of power it's claiming.
wait, I thought you said you never heard of the company before, or ever heard their equipment.
But in your last post, you said they have a clean/deep bass, and your uncle has them?
Old Sep 16, 2007 | 02:13 PM
Engine: V8 350 ci
This is what info i found on the amp. Also has a #80 Fuse.
Product Description:
* Maximum Power Output 1600 Watts
* 2-ohm Stereo Stable
* Tri-Mode Capable
* Fan Cooling System
* Variable Bass Boost: 0-18dB
* Variable Bass Frequency: 30Hz - 100Hz
* Channel Separation: >60dB
* Signal-to-Noise Ratio: 97dB
* THD: 0.03%
* Frequency Response: 20Hz - 20,000Hz
* High Pass Crossover: 50Hz - 1,000Hz
* Low Pass Crossover: 30Hz - 250Hz
* Adustable Sensitvity Range: 0.1V - 1V
* Dimensions: 11.1"W x 2.32"H x 16.89"L
Old Sep 16, 2007 | 04:31 PM
cdoyle's Avatar
That's sort of what I figured, they don't list the RMS rating.
I'm not trying to put down your selection, and I believe that's what you thinking I"m doing. I'm really just trying to help, or help others who read this post later on.
It's that 'max power output' it really means nothing, it's basically a number they made up. It could have reached that output, but the failed to mention that the amp burst into flames in the process.
RMS is the rating to look for, and I just went to Volfenhag's website, and they dont' even list those ratings for any of their amps. They talk more about the blue colored lights thier amps have, more then anything else. They have 3 lines in the description about the color of the lights.
Old Sep 16, 2007 | 05:54 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I check the fuses on it. Those don't lie. If it's got 40A of fusing, picture it drawing *maybe* 35A. 35x14.4 = 500W. I think 4AWG is good enough for 500W, so you should be fine. I usually buy welding cable from an industrial supply house, then buy the crimp on ends there as well. Buy a set or two of RCA's from wherever, and you've got a "kit". Oh, and a fuse holder.
But that walmart kit is damn cheap, that's hard to beat.
5AWG?? that's a new one on me.
Old Sep 16, 2007 | 06:58 PM
Engine: V8 350 ci
Yes i checked out walmart most of there stuff is sold out...and the kit is 8G not 4G ...seen s kit that had 4G but it was around 90.00$
Old Sep 16, 2007 | 08:33 PM
HCR13's Avatar
Car: 1987 Trans Am
I remember paying about $20 for my 1000w (4ga) kit, but I had to look around for it...
Old Sep 16, 2007 | 11:20 PM
Engine: V8 350 ci
Hello, I found this, i was going to buy this 1500W Kit, check it out to see if I SHOULD NOT GET IT? or go ahead. Thanks for da help.
http://cgi.ebay.com/NEW-1500W-4-GAUG...QQcmdZViewItem
OR this more better quality one, with extra cables
http://cgi.ebay.com/NEW-2000-WATT-CA...QQcmdZViewItem
Old Sep 17, 2007 | 08:18 PM
TheBandit's Avatar
Engine: Poncho 350
tbh i wouldnt buy either of them, maybe the power wires dont matter but id buy a good rca cable cause that effects the sound. and if you paid that much for wolfenhag than you got ripped off, not trying to be an *** but its not the best stuff out there, it may work for you but when you hear a nice sub youd be surprised
Old Sep 17, 2007 | 10:23 PM
Engine: V8 350 ci
yea thats what ive been hearing here is that they aren't the best but Im not here trying to say that they are better..and Im pretty sure I didn't get ripped off as they go for much more than that on Ebay and such. but for your intput.
Old Sep 18, 2007 | 04:40 PM
TheBandit's Avatar
Engine: Poncho 350
np, whast the rms rating on those subs btw?
Ghettobird52
Jul 5, 2024 11:18 PM
rocn7roc
Sep 21, 2021 02:16 PM
Reddeath210
Oct 6, 2015 08:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
