sterio stopped working
Old Sep 17, 2007 | 11:09 AM
xsupermann69x's Avatar
Car: 1991 Chevy Camaro RS
Engine: V6 3.1L
Transmission: automatic
okay so i am running 2 amps 1 that powers my sub and 1 that powers my componets i have polk interior and mtx subs both mtx amps. 4 channel running the iterior. for some reason my speakers started cutting out and i would turn the radio off and then on and they would work for a little bit then cut off again did that for a little bit then it wouldnt come back just lost all power to the speakers the radio is still working on and goes on the tracks and is playing but no sound what so ever. help me out thanks
Kurt
Old Sep 17, 2007 | 11:32 AM
cdoyle's Avatar
Re: sterio stopped working
Do your amps still have power when this happens?
Check all your connections, sounds like you have some loose RCA's, or bad ground, or loose power wire connector.
Check everything out, and see if everything is connected securely.
Old Sep 17, 2007 | 04:19 PM
Engine: V6 3.1L
it was actually none of those. the fuse that my power wire has on it the metal started to melt the glass but the fuse didnt blow it just wasnt having a constant flow so it wouldnt work new fuse fixed the problem.
Old Sep 17, 2007 | 07:03 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
most people would check the fuse first . ????????????????
Old Sep 17, 2007 | 08:05 PM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
not if it was cutting in and out.. i would check the fuse, but it would be after i check my wires. if it went completely dead then id check the fuse first..
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
