Help hooking up amp + Subs plz
Old Sep 19, 2007 | 09:34 PM
tigercyberslash's Avatar
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
Hello, i just got a new amp and subs and am trying to hook them up but its not working, the protect light came on for a second on the amp, i dunno what im doing wrong, I hooked up the rca jacks, power, i hooked the ground wire to a small screw behind the seat, only place i could find, and i hooked up the remote wire to the deck as well, i dunno can anyone help?
Old Sep 19, 2007 | 09:49 PM
1984Z28HO's Avatar
Car: 1985 iroc
Engine: 305 H.O.
Transmission: 5speed
Axle/Gears: 3:73
Re: Help hooking up amp + Subs plz
check your ground.. make sure you scrape some paint off the surface.. and check the fuse at the amp and battery... basically check for loose connections...
Old Sep 19, 2007 | 10:42 PM
Engine: V8 350 ci
yea the little screw may be the problem...but its hard to find a good ground with only 12'' of ground wire. So is the fuse that goes on the power wire suppose to be by the amp or by the battery or does it matter?
Old Sep 20, 2007 | 12:05 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
well, also lets consider how much power are you pushing. Obviously the more wattage the thicker the gauge wire should be...For my 1000w amp, I have a 4ga (+) hooked up to the battery and another 4ga for the ground. After you're sure you are sure about the gauge of the wire, then make sure the connections are secure...
Old Sep 20, 2007 | 02:30 AM
Engine: V8 350 ci
Okay...I already have the kit to hook it up and I know what Im doing...I need help with why it isn't turning on...I guess Ill just figure it out on my own.
Old Sep 20, 2007 | 11:19 AM
1984Z28HO's Avatar
Car: 1985 iroc
Engine: 305 H.O.
Axle/Gears: 3:73
check both fuses on the amp and by the battery.. the main thing is to make sure you have a good ground.. i used the bolt by the spare tire... and make sure your hooked to the remote turn on on the radio or amp... different radios call it different.
Old Oct 5, 2007 | 02:17 AM
break85's Avatar
Car: 1988 rs camaro
Engine: v6
Transmission: 5 speed
Ok what you need is a test light you can get one from any parts store. Make sure you have power at the amp test the wire coming from the batt. Then check the remote turn on an e z way is to use a 3inch pice of wire and jump the main power wire and the remote wire if it turns on then it is the remote wire. If it is the remote wire hook it up to the red wire behind the radio. The best way to see if the ground is good disconnect it from the amp and extend your test light wire and hook it up to the pos. Side of the batt. Touch the ground the light turns on it is a good ground. So I hope this all helps. Oh and don't do the jump wire too long I don't know if it is good but I do it all the time it saves a lot of time. I had the same prob with mine it was the remote wire. Good luck
Old Oct 5, 2007 | 09:54 AM
cdoyle's Avatar
OK, you said the protection light is coming on.
Is this with the speakers hooked up? Try unhooking the speakers, and trying again. If it turns on, and stays on check your speaker connections. You may have them wired up wrong.
If it still goes into protect mode, you at least know it's not because of that.
I would then check your ground wire, then your main power and then the remote.
Do you have a multimeter? You can use that to check to make sure you have 12V at your power and remote connections.
Is this a new amp or a used one? If it's used, there is always that possibility that there is something wrong with it.
After rereading your post, I would really check that ground. It sounds like you're not getting a good ground.
Old Oct 5, 2007 | 11:09 AM
break85's Avatar
Car: 1988 rs camaro
Engine: v6
I was told my amp was bad but it was remote wire that was bad so check all the wires first befor you say the amp is bad. I get a lot of people saying the amp sux and it doesn't work when I check it they hooked it up wrong and most of the time it is the remote wire. So good luck on finding the prob. I also used a bolt in the spare tire area as a ground.
Old Oct 5, 2007 | 12:51 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Something to go along with that, make sure you're not presenting too low impedence for your amp. If your amp is 2 ohm stable and you have your speakers wired to present something less, the amp could very well go into protection.
Old Oct 5, 2007 | 02:35 PM
Engine: V8 350 ci
Thanks, I figured it out awhile back and they work now
Old Oct 5, 2007 | 05:23 PM
cdoyle's Avatar
What was the problem, so others who search this thread with similar problems have a place to start.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
raymondandretti
Sep 27, 2015 06:43 PM
