subwoofer box
Old Nov 17, 2007 | 11:26 PM
alvarez91's Avatar
subwoofer box
ive seen the boxes that fit in the trunk where the ttops go. can anyone give me a like with a box that they are sure will fit well? i have a '92 camaro rs
Old Nov 18, 2007 | 10:47 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: subwoofer box
WELCOME to the board.......
Look at the sticky post "Dimension for well sub box" on this page.
Old Nov 24, 2007 | 09:20 AM
85camarojunkie's Avatar
Car: Camaro coupe
Re: subwoofer box
This is the cheapest i found. they do work.. i made my own a long time ago...
http://www.hifisoundconnection.com/S...id/0/SFV/30046
Old Nov 24, 2007 | 10:55 PM
megtom2's Avatar
Car: 1989 Pontiac Formula 350
Engine: 350 tpi
Transmission: 700
Re: subwoofer box
Does that box fit inside the rear recess or sit on top of the deck?
Old Nov 24, 2007 | 11:09 PM
Car: 89 IROC
Re: subwoofer box
It fits inside the "trunk" area. Just slide it in.
TIP...Might want to put two handles on the top if you buy it so you can lift it out with ease when needed
Old Nov 25, 2007 | 12:41 AM
camaro91's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: strange s60 4th gen width - 3.73
Re: subwoofer box
you really should! i got one in my rs and with subs it weighs bout 200 lbs! and it bein wedged back there don't help either!
Old Nov 25, 2007 | 12:56 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: subwoofer box
Firsthand experience. The one I just removed in favor of a custom fiberglass and MDF box weighed nearly 100 lbs and was wedged in. I had to stick my arm down its port to remove it.
Old Nov 28, 2007 | 09:30 PM
yellow92bird's Avatar
Re: subwoofer box
me and a buddie built a custom box to fit two 12 fits oerfectly inside my truck i also placed a soild 1/2 inch cherry wood top my dad had laying around it was just long and wide enough to fill the whole back area. I stained it and made the top half a amp rack and it looked great but after 2500 watts per speaker i craked the side pannel out but after replaceing i weighed them empty at 275 pounds and loaded at almost 400 so its a hugh boat anchour but sounds great
Old Nov 29, 2007 | 01:53 AM
aceman1's Avatar
Car: 1989 camaro
Engine: 2.8
Re: subwoofer box
handles are a bad idea! it is not only good for you, but also for that nice stranger who decides to borrow your set up!
Old Dec 4, 2007 | 08:12 PM
megtom2's Avatar
Engine: 350 tpi
Transmission: 700
Re: subwoofer box
I just got this box in today. My car is being delivered Friday and I will spend the weekend jamming up the stereo. I am very impressed with the box from hifisoundconnections. It looks nice.
Old Dec 5, 2007 | 07:18 PM
the phoenix's Avatar
Car: 1985 Pontiac Trans Am - PROJECT
Engine: 412 c.i. SBC / 6.75 L
Axle/Gears: Borg Warner 3.27
Re: subwoofer box
Hmmm... over $100 for a box where you have no input on how it works... Or check out the sticky and buy a piece of MDF from Lowes for $22 and design it yourself based on the specs in the sticky... Up to you
Old Dec 5, 2007 | 10:55 PM
BigSpraguesRS's Avatar
Re: subwoofer box
were is the stick post located???
Old Dec 6, 2007 | 12:20 AM
Re: subwoofer box
Ask and you shall get stuff... haha
https://www.thirdgen.org/forums/car-...sub-box-2.html
Old Dec 7, 2007 | 03:22 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
Re: subwoofer box
i have one of these boxes just sitting around i need to get rid of. but i live in daytona beach, fl. so unless someone is willing to bring the money over and pick it up...lol
Old Dec 7, 2007 | 06:03 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: subwoofer box
I've had a few different combinations in my car as you can see in the pics and my favorite by far is this one:
It is just the right amount of bass and is easily removed, and everything in the back is still accessible. Also is very well hidden with the cover closed.
I'm also giving away the dual sub box with subs in it if anyone local wants it.
Attached Thumbnails subwoofer box-more-iroc-003.jpg   subwoofer box-more-iroc-015.jpg
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Zell1luk
Sep 29, 2015 10:36 AM
