crutchfield says polk 4X6's wont fit in the dash
Car: 1991 camaro RS
Engine: currently swapping 5.3
Transmission: 4l60e
Axle/Gears: soon to be 4:11
i went on crutchfield and searched for speakers that will fit into a 91 camaro rs and it says the polk 4X6's won't fit... doesn't anyone have them in a thirdgen dash?
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: crutchfield says polk 4X6's wont fit in the dash
I had some Polks in my dash. I had to clearance the vent tubes to get the magnet to clear.
Car: 1991 camaro RS
Transmission: 4l60e
did you just cut the vent tube? or what?
yep, just cut into them and put electrical tape over the holes.
When you pull the dashpad off and remove the stock speaker, you will see where the vent tube (or should I say AC Duct) runs.
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
You may also have a problem on the drivers side with some structural plastic behind the gauge cluster. I didn't have to cut my air ducts to fit my Infinity 4x6 speakers however I did have to cut out a section of this structural plastic. It's a small enough section that it didn't have any negative effects on the integrity of the dash. It's really easy if you remove the gauge cluster.
Be careful if you grind through that stuff with a high speed rotary tool like I did, it stinks like hell and I'd imagine those particles of ABS or whatever that plastic is that get released into the air can be pretty bad for your lungs.
Car: 1984 Z28
Engine: L31
Transmission: WC T5
Axle/Gears: 10 bolt 3.73
Thats the problem I had with my polks on the driver side front. Theres some plastic shrouding over the instrument cluster. 5 min with a dremel cleared it. No interference with any ducts.
1 Post
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Yep, dremel tool, and they go...im working on 5, and a 1/4's right now...a little more dremel tool, and I think they will go too....
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
The dremel "flex shaft" is a big help in the dash area. If you do not have I highly recommend picking one up.
Car: Camaro coupe
yea they will work deffinetly i put 6" sonys in the wifes car. little buit of work but.... anything for sound
Car: 1989 Pontiac Firebird Mint. cond.
Engine: 2.8L V6
Transmission: factory
Axle/Gears: factory
i have em installed in my dash. i have polk DB's 4x6 in my dash they fit kinda tight on i believe the driver side but i mean i didnt cut anything away but they fit like a charm and sound great
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
An alternative to cutting up the plastic is to carefully use a heatgun.
- Protect the area surrounding the air duct with some damp towels (rags).
- Gently apply heat the plastic so it warms and softens slightly. Don't hold too close or too long in any one area. Test it frequently to see if it will bend.
- Then press and shape the plastic to give you room. A curved wooden block or even a large wooden spoon will work. You only need apply enough pressure to the plastic to give you the room for the the speaker magnet. Generally less than 1/2". Keep the pressure on the plastic until it cools and retaines the shape.
If all you need is just a fraction of room, this work well. I haven't done this for my car (it has a two piece component speaker system with a shallow mount mid-range), but I have done it successfully on a few other rides.
Car: 1987 Z28 camaro
Engine: 305 V8
Transmission: auto
Axle/Gears: 10 bolt pozi
OR..make a spacer, I added a 1/4" on my infinity's and they cleared with no problems
Car: 1987 IROC-Z
Transmission: 700R Auto
I just replaced my system last night Sony head and Polk 6x9 and 4x6s. The 4x6s dropped in with no problem....
BTW I think I am getting old 'cause it is too loud.....
Car: 88 Camaro
Engine: 305 TBI
you can fit pretty much any size 4x6s in it if it has the metal tray that holds it. If it does just jam something underneath to hold it up or bend it to make it wide or narrow enough. Thats what i do when speakers dont fit in mine
i have infinity kappa 4x6 plate speakers up front no problem. (4 inch woofer with a tweeter), the woofer is offset from center so they do fit better, but as a former installer i have to say the heat gun is the best thing to do. no cutting or anything then.
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
which model
ambainb
04-25-2016 09:21 PM
Vintageracer
08-11-2015 08:13 PM
