Help Me Identify This Stock Radio
Old Dec 23, 2007 | 11:39 AM
kuulkatdadieo's Avatar
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
I have no idea what year this radio came from, but I do know that it is from a 82-92 Camaro/Firebird. So can you identify it??
<<FRONT>>
<<BACK>>
Old Dec 23, 2007 | 11:51 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Help Me Identify This Stock Radio
Seems like you already have.
It's mid to late '80s anyway, the eariler ones were generallly more of a mat finsih, not glossy like that, and there is the extra plig that I don't recall what it does at the moment.
Old Dec 23, 2007 | 12:26 PM
Thanks. I'm trying to get the range of years this one came in, so I can sell it. Then when the buyer has a question of what it will work in, I will have an answer.
Old Dec 23, 2007 | 01:11 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
http://www.delcoradiotek.com/
Scroll to the bottom of the page. You can send them the model number (if it's still on the radio), and they'll e-mail you with what it came from. Took about a week for them to respond to my query.
Old Dec 23, 2007 | 01:17 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
My 87 coupe had this same one.....be carefulwhen you ell this, I had a guy try to say the one I sent didnt work wen I knew it did....
Old Dec 23, 2007 | 05:30 PM
I would but it doesn't have model number sticker on it.
Thanks for that info. I will be careful, but if they say it won't work I will simply return their money.
Old Dec 23, 2007 | 07:30 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
it should fit most gm's with the large radio until 89 or 90.
Old Dec 23, 2007 | 07:51 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Looks identical to the factory radio in my `88 Iroc. It still works great.
Old Dec 23, 2007 | 07:57 PM
So the concensus is that this is a radio for camaros/firebirds between the years of 87-90. That is the conclusion that I've come to. Do you guys think it would be in 91's and 92's, too??
Old Dec 23, 2007 | 09:34 PM
Tehsocks's Avatar
Car: 85 Camaro Z28
Engine: 6.0L LS
Transmission: T56 Magnum
This radio wasnt used in 87-90. Much more wide then that, It became availble in 84-92, **Radio, stereo, tape, clock, s/s, equalizer**
Old Dec 23, 2007 | 09:43 PM
85irocz355tpi's Avatar
Car: 85 IROC-Z
Engine: 355 TPI
Transmission: 700R4w/Shift Kit
Axle/Gears: B/W 9 Bolt-3.45
Most any 80's gm cars had that radio available in them. My 85 iroc had one just like it when I bought it. It was top of the line back then. It will only work until 89 for camaros and firebirds. In 90 they switched the plug style and went with a smaller antenna plug in. You can go to wal- mart to get years it will fit in. Go look for a wiring harness adapter for an 89 camaro and on the back will give you the make, model, and years that used that plug. My moms 92 s10 blazer used that plug too. Hope that helps.
Old Dec 23, 2007 | 09:55 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Well I wuld ahve jsut done that too, but they told me there original radio wouldnt work right and then they had a shop look at mine I sent and it was opened up and stuff, out of fairness thats not right for me to take something abck thats been disected ya know, Plus I beleive they where going to send there radio back and pass it as the one I sent
Old Dec 23, 2007 | 10:20 PM
THANKS. That is the kind of info. I was looking for. I'm trying to get the years available, and you gave it to me.
THANKS for that info. also. Another very interesting piece of information, thanks. I will include all of this info. in my sell. I will also try the wal-mart idea.
That sucks man. I'm sorry the buyer did you like that. So what ended up happening?
THANKS GUYS!!!
KEEP THE INFO COMING.
Old Dec 23, 2007 | 11:50 PM
1984Z28HO's Avatar
Car: 1985 iroc
Engine: 305 H.O.
Transmission: 5speed
Axle/Gears: 3:73
my 84 had the same radio too
Old Dec 24, 2007 | 12:32 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
can anyone identify that extra wire coming out the back, looks like a plug of some sort and it's got me curious...i got mine outta '86 bird and it didn't have that extra wire/plug.
Old Dec 24, 2007 | 04:05 AM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Its a real long story from october to about a week ago, but to make it short, I basically told him its not fair to me to take it back if its been taken apart and been inside of and that I know he had a problem with his previous radio so he needed to look into his cars wiring. He supposivly got his original radio he had to work and still went on to say I sent a bad radio, which wasnt true i used to use it in my car. He ended up giving the other half on my money and with some nice words we went our seperate ways.
Old Dec 24, 2007 | 09:09 AM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Power antennae
Old Dec 24, 2007 | 09:58 AM
84redta's Avatar
that was my thought, but i wasn't sure.
Old Dec 24, 2007 | 11:17 AM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
That radio wasn't originally installed in a third gen. It has a glossy face and chrome buttons and should have had chrome ***** too. It was originally from an olds or buick or something similar and I think that extra wire was for the "Concert Sound" in those models. My guess is the stock radio died and that was a used replacement and the person simply installed the original black ***** on it.
Old Dec 24, 2007 | 11:20 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
The separate 2 wire plug is for the clock/radio memory.The antenna lead wire(pink)is built into the main plugs.And the '84-'92 use in all GM products is correct(my '83 Z28 came with it but I'm sure not original).Some had the chrome/brushed bright trim and others had either black or grey buttons.And Pontiac used the red/amber lighting which is the color of the lens in the front panel.
Old Dec 24, 2007 | 12:56 PM
Thanks for confirming that.
Well, I'am glad that you got it worked out. I wouldn't take back something that had been tampered with either.
I do think it is for the clock and radio memory also. So, this one most likely came in a Camaro or a Buick, something along those lines, but not a Pontiac.
THANKS GUYS!!!
Old Dec 25, 2007 | 12:08 AM
ynk1121's Avatar
Car: 90 IROC, 95 Vette
That will not fit anything 1988 or newer. that has the older connections on it. That pigtail coming out is Brown: lights dimming and Orange: clock
Old Dec 25, 2007 | 09:03 PM
So this radio is for GM vehicles besides Pontiac between the years of 1984 and 1988. Any objections from anybody?
Thanks again guys, you have been a big help.
AND
MERRY CHRISTMAS!!
Old Dec 26, 2007 | 08:04 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
AND
MERRY CHRISTMAS!!
'84-'87, it won't fit an '88 car due to where the wiring goes into the back.
Old Dec 26, 2007 | 03:22 PM
Thanks Klortho. So guess it is final, 84-87. THANKS EVERYONE
Old Dec 27, 2007 | 09:28 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Not so fast there... it's not final yet, lol! I hate to throw more confusion into this, but...
One person said it won't fit '90 and newer, and another said it won't fit '88 and newer. But they each missed the change by a year. Actually, the harness and antenna connections changed with the '89 model year. So it will fit up to, and including, 1988 cars. However, with harness and antenna adapters(available at auto parts stores and installation locations), it will work in '89 and later cars, too.
But like 86blackiroc mentioned, that isn't likely to have originally come in a thirdgen(from the factory). Its glossy face and brushed metallic buttons indicate that it's either from a more luxurious GM car line(Olds, Buick or Caddy), or it's a Delco dealer replacement. So it was most likely a swap, for whatever reason.
And one more bit of info, the EQ radio was available as early as '83, but in Trans Ams, not Camaros. I first saw them in 1983 TAs. So when I ordered my '83 Z28 HO, I wanted that radio, but it wasn't an option for the Camaro. But I foundout I could get one through a GM source, so I ordered the car with the base model radio, and I swapped in the EQ radio when I got the car.
So there ya go: '83-'88 GM cars(but would fit '82 also). Now it's final!
Old Dec 27, 2007 | 09:33 PM
So there ya go: '83-'88 GM cars. Now it's final!
THANKS man. Thanks for going into that kind of detail. I'll say that it will fit GM cars between the years of 83 and 88. That was the kind of concrete information I was looking for. &
How much do you think this thing is worth?
Old Dec 27, 2007 | 09:46 PM
LAFireboyd's Avatar
I have no idea what it's worth. When it was new, it was prolly about a $400+ option. Purchased through a dealer, it might've cost about the same. But used, at its age, I doubt it's worth very much, so take whatever you can get that still lets you make a little money.
But looking at your pic again, I see it has AM Stereo and Auto DNR. AM Stereo was the 'new thing' in the mid-to-late '80s, but I'm not quite sure exactly when it began. That '83 EQ radio I mentioned didn't have it, but the touch control EQ radio in my '87 has it. And that touch model radio was first available in '85, I believe. So that's that prolly when AM Stereo first hit the air waves.
So to re-finalize it: the EQ radio was first available in 1983; it'll fit any '82-'88 GM car; but that particular radio in your possession is most likely from an '85-'88 GM car(again, doubtful it was originally a thirdgen).
Old Dec 27, 2007 | 09:55 PM
84redta's Avatar
to be blaintant, probably 10-15 bucks...i just scooped one up for $5, but would've been charge $10 if i didn't know the guy, mine is identical but made for a firebird (gray *****), but it doesn't have that special wire so, past that i can't really guess, if someone is trying to restore the car back to original and it's not show, then you might make $20, but really...in this age...tape players don't get much value. For your sake i hope you can get more, but just telling you what i'm seeing in junkyards near me.
Old Dec 27, 2007 | 09:59 PM
That's cool man. I was thinking like $30-$40 maybe. I will definately clean it a lot better. You can tell where I tried cleaning it, but didn't do a very good job as the flash from the camera reveals.
Old Dec 27, 2007 | 10:02 PM
84redta's Avatar
yea like i said...then again it's believe to be a higher gm model, buick olds or something of that nature...so you might get something like that, but between on here if you tried it on the site...i don't think you would get much more...you never know, i don't know what the bose stereo's looked like but it might be compatable, and locally, i think he's liberal, if it's an old stereo that is working on over 20 years old...he doesn't do more than $10 so that he doesn't have to worry about if they don't work, probably $15 for 10 year old, and then it varies if they are under 10 years old. So he's kinda liberal, you never know...but good luck!
Old Dec 27, 2007 | 10:09 PM
I agree with you there. I think I will hope for $20. I just looked on ebay and that seems to be the norm.
Heres a link to a guy selling a 89+ for $6. I'm screwed.
http://cgi.ebay.com/ebaymotors/89-96...QQcmdZViewItem
Old Dec 28, 2007 | 07:43 AM
coolram62's Avatar
Engine: LU5 305 CFI
Thank you LAFireboyd for the info on '83 EQ radio.My Z28 is a June '83 build so it's a slim possibility to be factory but most probably a dealer swap.But then again in the 22 years before I got her who knows.
Old Dec 28, 2007 | 08:40 PM
Engine: that I like
I'll throw some more confusion into the mix. Not all GM's got the newer connector in '89. I have an '89 Celebrity and a '91 S-10 that have the old style connectors in them. I was not sure about the third gens though, as my '89 and '92 Camaros both had the original connectors cut off when I bought them.
Old Dec 28, 2007 | 09:05 PM
Fyrstorm's Avatar
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
I would have guessed pre-85 just by what my own radio looks like in my 86 Trans Am. Definately the up-scale radio by Delco though. I also would have guessed Camaro only by how the trim looks on it. Going by memory I've never seen that radio in a Trans Am/Firebird that I'd been in back in or peered through the window dreaming about having one back in High School **cough**dates himself**cough**
Edit:
Went downstairs and got my old 86 Trans Am radio out of a box and snapped some photos to compare:
Old Dec 28, 2007 | 10:51 PM
Nater2491's Avatar
its the exact same stereo i have in my 86 iroc , came with the ers sound package. ill trade you my broken one for yours
Old Jan 3, 2008 | 03:04 AM
ynk1121's Avatar
I stand corrected. So it looks like 92 camaros and 91& 92 birds got a different harness too?
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Linson
Aug 21, 2015 02:12 PM
Winchester1094
Interior Parts Wanted
Aug 19, 2015 05:01 PM
arod231
Aug 16, 2015 02:51 PM
