speaker boxes
Car: 1980 Chevy Stepside
Engine: 5.7L 350
Transmission: TH350
Axle/Gears: 3.73 L-Slip
speaker boxes
exactly how much room does a speaker box take up in the hatch of a 87 trans am. looking into gettin the dual 10'' sub box thats supposed ta be made for the car
Car: 91 RS
Axle/Gears: 10 bolt
Re: speaker boxes
The average box made for our car will take pretty much the whole well...
you should do a search to see how much room they take they pretty much all use about the same amount
Car: 91 RS
Axle/Gears: 10 bolt
Re: speaker boxes
you could take out your spare tire and run your bottle in there or run the bottle inbetween your rear seats...
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: speaker boxes
Here are some pics 2 12's in my 87 Trans Am...
I'm going to put my bottle on the hump between the rear seats... and then in the future, maybe put it in the left hand section of the trunk (inside the panels) with a remote bottle opener...
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
Re: speaker boxes
looks can be Deceiving.....!!!
take kbcobra's pic for instance. Technically if your one of those folks that are constanltly turning switches and ***** on your amp then that same box and amp set up (more so the placement of the amp) is for you.
the deceiving part of it is this. Underneath the box you can mount the amp to the trunk floor to save space. ...... NOW u have space for a bottle!
mounting to the trunk floor does sound scary....so you can use a thick velcro or something to keep the amp in place. (?) <thats the only material i can think of right now...haha
but i will get some pics up of my setup.....i just moved to miami,FL so i gotta find the box i put my digital cam in.
Engine: 5.7L 350
Transmission: TH350
Re: speaker boxes
not a bad idea, but most def, get some pics
Car: 92 Chevrolet Camaro RS
Engine: 3.1L V6
Re: speaker boxes
Engine: 5.7L 350
Transmission: TH350
Engine: 3.1L V6
Engine: 5.7L 350
Transmission: TH350
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: speaker boxes
Put the bottle in the speaker enclosure under the speakers.
Car: 92 RS, 87 IROC, 89 GTA
Engine: LO3, LB9, L98
Transmission: 700R4 X3
Axle/Gears: 2.70, 3.30, 3.27
Re: speaker boxes
you could also mount the amp in the spare tire bay, and have space for your bottle. Lol, a friend of mine took the rear seats out of his camaro and made a sub box for right behind the front seats so he could keep all his toold and stuff in his trunk, actually turned out pretty cool after he worked at it for like 5 months. ill get pics if i can...no camera lol.
