Lets see your iPod setups in your cars!
Old Feb 17, 2008 | 07:05 AM
BigBadJohn's Avatar
Thinking of soldering a headphone input into my equalizer radio and I was thinking either modifying a black home audio iPod dock to fit somewhere or just using a black dock wire and hide the iPod somewhere since if its visible it could make my car a target to theft.
I need to see some iPod installations in your cars for ideas
I need a setup that can charge the iPod and play music using the dock connector
Old Feb 17, 2008 | 08:59 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: Lets see your iPod setups in your cars!
Old Feb 19, 2008 | 06:45 PM
Legal Disaster's Avatar
Car: 1986 Iroc-Z
Sorry no pics but mine is just simply hooked up to the back of the radio, routed under the console and back into the center console through a hole i drilled. I have my ipod mounted to one of the sides using velcro strips that are also on the back of my ipod case. Simply done and out of sight.
Old Feb 19, 2008 | 07:23 PM
90BlackGTA's Avatar
Car: 1990 Trans Am GTA
Axle/Gears: 3.42's
Hey I just bought a deck with an aux port and I just run a cable from that port to the headphone jack on the ipod...works great...
Old Feb 19, 2008 | 07:52 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I did what 90BlackTa did, i had AUX ports in the back of my headunit and i bought a Ipod cable thats about 6 ft too long lol to plug my Ipod into the head unit. works good
Old Feb 19, 2008 | 08:59 PM
thirdgenfcarnut's Avatar
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 4L60
Axle/Gears: stock 3.23
I have the pioneer dehp860 with the ib100 ipod interface. The ipod lives in the center console out of sight, always charged, and I never have to touch it because the entire catalogue is accessed through the pioneer headunit...<br>
Old Feb 19, 2008 | 09:53 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
wow i wish i could access my IPOD songs thru the headunit and not deal with selecting songs on the ipod
Old Feb 19, 2008 | 09:56 PM
cameron7710's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
heres my super simple setup
Old Feb 19, 2008 | 10:41 PM
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 4L60
Check the pioneer website... www.pioneerelectronics.com for an entire line of pioneer am/fm/cd headunits that have direct control of IPOD. These units are not expensive, sound GREAT, and have a very easy control of your IPOD. It is the best sounding way to listen to the IPOD in your car. My setup is older and searching for artists and song is arduous, but the newer stuff is way better. For those of you who are not Pioneer fans, the other companies that have direct control for your IPOD are, Alpine, Panasonic, and Kenwood.
Old Feb 20, 2008 | 07:27 AM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
No pics since I sold the car. But I rna a 6 foot 3.5 mm cable form the aux on the HU to my ipod. I took apart thte center console and ran the wire under it so it didnt look bad. Drilled a hole on the bottom of the center console glove box and ran the wire back otu the top. Looked clean but took some effort
Old Feb 20, 2008 | 04:32 PM
xsupermann69x's Avatar
Car: 1991 Chevy Camaro RS
Engine: V6 3.1L
Transmission: automatic
anyone ran the wire up threw the ashtray and had the ipod just chillin standin up in the ash tray or made anything to flow with the center counsol.
Old Feb 21, 2008 | 10:01 PM
KonArtist's Avatar
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
I bought my car with the ipod wire already ran, just a single wire from the back of the headunit with a plug for the bottom of the ipod.
My problem though is that I unhooked the battery the other day to install a sensor and now its uninstalled that wire and I have no idea how to reinstall it? Any Ideas?
Old Feb 21, 2008 | 11:59 PM
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 4L60
Your avatar is Buddy Jesus.. thats awesome!! What is the make and model of the head unit in your car? It is possible there is a tiny reset button on or behind the face of the unit, something you would need a pick tool or a toothpick to press on. This would reset the unit's micro processor which may get scrambled when power is disconnected then reapplied. Other units require going into the setup menu to activate the auxillary or Ipod input. Give me as much info about your head unit as you can... I should be able to help you figure it out.
Old Mar 27, 2008 | 01:48 AM
OS3Fleming's Avatar
Car: 1984 Camaro Z28
Engine: 357 SBC
I had a ashtray mod installed. I ended up putting my window switches there and and extra outlet due to having an old POS Sony. It works good, got an IPOD holder/transmitter/charger there.
Old Mar 27, 2008 | 08:45 AM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
Mine comes from the bottom of the center counsel on the passenger side and is mounted to the passenger side just below the top lip. This is a picture from my cardomain to give an idea. When I get home I mite put better picture up of the whole think because you can't see how it mounted. I throw my Ipod in the center box to hide it from view or just take it with me.
Edit: The second picture is what it looks like on the passenger side.
Attached Thumbnails Lets see your iPod setups in your cars!-2903821_6.jpg   Lets see your iPod setups in your cars!-iplug-001-small-.jpg
Old Mar 27, 2008 | 06:54 PM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
is that a dual? if so, how did u hook up the the i plug wiring and the plug itself?
Old Mar 29, 2008 | 02:24 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
the iplug is the plug it hooks in the back of the head unit. i just plug up the same cord (that has the two plug in ends) that you use for the aux to the iplug. plug it in the iplug and in to my ipod or mp3. Dual also has the just plain ipod connecter for this but it was $50 and the iplug was free with the radio.
Old Mar 29, 2008 | 05:28 PM
Engine: V8 305
I also have a dual, I just was never sure on how to hook the iplug up. What model is urs?
Attached Thumbnails Lets see your iPod setups in your cars!-dual-1.jpg   Lets see your iPod setups in your cars!-dual-2.jpg
Old Apr 5, 2008 | 02:58 AM
hellsatan's Avatar
Car: 89 IROC
i did it the same as thirdgenfcarnut. Nice and simple and no1 can see it and it wont fall on the floor and get stepped on and such. Not like your gonna show it off wooo its a ipod! (buy a cheap 20gig or even 10gig and thats more then enough for music and your set)
Old Apr 5, 2008 | 06:00 PM
90 Camaro's Avatar
Car: 1994 Chevy Blazer S10..1990 Camaro
Engine: Blazer - 4.3L..Camaro - 3.1L
I have the same head unit in my Blazer...its very simple to hook up the iplug. You need to take the head unit completely out...there are 2 RCA wires hanging there...take the iplug, and plug those RCA cables together, then install the head unit back into the car. Then go to radio shack and get one of the male/male headphone cables to plug into the iplug and ur ipod. http://www.radioshack.com/product/in...entPage=family
Old Apr 5, 2008 | 06:41 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I have a Kenwood with the Ipod adaptor and just have the box mounted behind the radio area and the cable going up the side of the console and then into it.
I just plug my ipod in and control it through the Kenwood.
Old Apr 6, 2008 | 01:02 PM
Engine: V8 305
Thanks, I will try to hook it up when my car comes out of storage.
Old Apr 8, 2008 | 04:26 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
i have this same set up in my t/a
Old Apr 8, 2008 | 09:21 PM
redfirebirdman8's Avatar
Car: '89 Trans Am
Engine: 305 T.P.I.
Axle/Gears: 10 bolt 3.73’s
i have the kenwood unit in my car (pics tommrow hopefully), and it has the aux set up on the front with a cable running to my console. very simple, works great.
Old Apr 12, 2008 | 12:59 AM
JB4's Avatar
JB4
That is some seriously sweet stuff. I really like that too, not having to use the ipod to control it.
Old Apr 14, 2008 | 12:25 AM
Chris Knight's Avatar
Car: 1986 Iroc-Z
Engine: Orig. TPI + 305ci small block.
Transmission: Orig. factory 700R4
Axle/Gears: 3.23 G80
Well I made a mod for my ashtray that sorta does a few useful tricks for my car. The cigarette lighter is where I stick in a Griffin Fm transmitter, so no cords or anything, and it looks legit. Don't have a picture of the transmitter but you can get the idea.
Attached Thumbnails Lets see your iPod setups in your cars!-tgo-ashtray-mod-pic.jpg
Old Apr 14, 2008 | 09:11 AM
Engine: V8 305
Some people have alot of complaints about the duals, but for me , so far, so good.
Old Apr 14, 2008 | 09:33 AM
Ep1nephr1ne's Avatar
i pluged mine into the back of the stereo, ran the cord out the back side with the AC wires and velcrowd the ipod under the dash, that way i can reach it. and its out of site out of mind. if they steal the radio they will most likely be too stupid and not even see the $300 super ipod.
Old Jul 17, 2008 | 12:27 PM
Engine: V8 305
Awesome thanks.
Old Jul 31, 2009 | 11:38 PM
Chicken-Bird's Avatar
Car: 1989 Pontiac Firebird Formula
Engine: 5.0L 305
Axle/Gears: 3.73 posi
my sony head unit has an auxillary input in the front so i cut part of the console out and put in the ipod dock shell that came with my ipod bought a patch cable at walmart glued one end of the cable on the bottom of the dock ran the rest of the cord under the console, came out by the ashtray and plugs into the head unit.
cant figure out how to put a thumbnail of it up but theres an interior pic in my album on my profile where you can see it
Old Aug 7, 2009 | 11:04 AM
Schwinny's Avatar
Car: 1987 Firebird
Engine: 2.8l V6
I did a job last week on a ford ranger.
he had a JVC radio that had Ipod interface.
I was super jealous. I need one now.
Old Aug 7, 2009 | 12:48 PM
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
dude you need clean out your consol kinda yucky.
Tony.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
onefreakz
May 14, 2018 12:15 PM
L98GTA87
Aug 11, 2015 06:55 PM
squiggy2
Aug 9, 2015 09:30 PM
