radio problems: radio doesnt play any stations...
Old Mar 9, 2008 | 11:30 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
i have a problem with my radio in my 88 gta.... It has the factory radio and the power antenna goes up and down just fine.... everything works except for radio stations.... all i get is static on all stations and can listen to any of them... what could be wrong.... i can play cassettes just fine clock and steering buttons work perfectly..... i just bought a like new factory power antenna so whats up..... what could cause this....
Old Mar 11, 2008 | 03:36 PM
lukn4trbl's Avatar
Car: 2000 SS, M6
Engine: Modified LS1
Re: radio problems: radio doesnt play any stations...
Seems to be a disconnected antenna behind the head unit, or a break in the
antenna line. I would check to make sure both ends are secure.
If you hit scan, the head unit should tune into the strong signals for local
radio transmitters. Does that even happen for you?
Old Mar 11, 2008 | 04:31 PM
Stippy17's Avatar
Car: 1986 Trans Am, 1985 Trans Am
Engine: 400 SBC, H.O. 305
Transmission: TH400, 700R4
Axle/Gears: 10 Bolt/3.73s, 10 Bolt/3.73s
I had an aftermarket head unit that would play CDs but not any radio stations. I ended up replacing the antenna (Was broke off) and I started to get AM stations, but still no FM stations. I replaced the aftermarket head unit with a new one and now everything works fine, so there must have been something wrong with the head unit and receiving FM signals?
For you, your antenna may be disconnected from the head unit. Or, your head unit might be the problem like it was for me and youll have to replace it. Just my two cents..
Old Mar 11, 2008 | 06:35 PM
88fastgta's Avatar
nope... when i hit the scan button it picks up nothing......i checked... everything is plugged up in the back and i just replaced the antenna with a like new factory power antenna... the antenna goes up and down just fine.... so what else is there to check???? could i have a bad radio...
Old Mar 11, 2008 | 07:44 PM
Stippy17's Avatar
Yeah, like I said you might have a bad head unit.
Old Mar 11, 2008 | 11:57 PM
RicksIroc86's Avatar
Car: 84 camaro z28
it probably is the head unit, i would suggest heading up to your local circuit city/best buy and buy a new head unit, and they have dash install kits there that keep it looking stock and very nice. my radio did that in my 86 when i first got it, then i bought the head unit and an antenna adapter and it works fine now.
Old Mar 12, 2008 | 12:19 AM
88fastgta's Avatar
well i found a place online that rebuilds factory delco radios... i want the interior to be as factory as possible.....
Old Mar 12, 2008 | 11:21 AM
Stippy17's Avatar
You mean they will rebuild your head unit you have or you can buy a rebuilt radio from them?
Old Mar 12, 2008 | 08:19 PM
88fastgta's Avatar
they will rebuild my original one......
Old Mar 12, 2008 | 08:46 PM
Stippy17's Avatar
If that's the route you want to go then that should be fine if they know what they are doing. For the price though (I dont know how much they will charge you) you can get a stock head unit from your local junkyard or even in the classifieds on here for about $50. Either way, it doesn't matter which you choose lol.
Old Mar 15, 2008 | 04:25 PM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
I have the same problem. I have a pioneer head unit and it only plays on 1 station. When I first got the car all stations worked with a lot of static. The antenna wire is stretched from the left side in the pod to the right side, cause the headunits antenna socket is on the right side on the back. I have no idea what to do accept replace the whole antenna assembly Any ideas???
Old Jul 3, 2008 | 09:17 PM
briwar454's Avatar
Car: 1985 Trans Am
Transmission: THM 700-R4
Axle/Gears: Stock
Where did you get the unit rebuilt? I bought a UT4 radio for my 85 T/A and I'm having the same problem.
Old Jul 8, 2008 | 10:18 PM
asting's Avatar
there's a post in the interior parts f/s that has a guy giving them away for the price of shipping.
Old Jul 8, 2008 | 10:43 PM
briwar454's Avatar
Car: 1985 Trans Am
Axle/Gears: Stock
That's where I bought my last one. Most of the one's you see for sale are in tough shape. Look for rebuilds. Does anyone know a good place to get your head unit rebuilt? for a good price?
Old Jul 21, 2008 | 02:01 PM
briwar454's Avatar
Car: 1985 Trans Am
Axle/Gears: Stock
No one knows a good place to get your Delco UT4 Repaired?
Old Jul 27, 2008 | 11:08 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Check this place...
http://www.carradio.com/
I think the UT4 must be one of the most looked for stereos out there. I just bought one on ebay for my '87 GTA and I'm embarrassed to say how much I had to bid to get it, it was a lot.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RS Reaper
Oct 17, 2018 07:52 PM
Fireslash
Apr 11, 2016 06:43 PM
Gunner242
Dec 25, 2015 04:49 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
