Do amps usually smell?
Old Mar 15, 2008 | 04:15 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
My audiobahn amp driving 4 speakers always smells like electronics. Doesn't smell like burning, just strong "electronic" smell if you know what I mean. Last one I had did the same thing and it blew. Problem?
Old Mar 15, 2008 | 05:06 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: Do amps usually smell?
Usually a smell is a sign of overheating.
Old Mar 15, 2008 | 07:00 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Its just sitting on the carpet on the rear hump behind the passenger side back seat. No sun, cold day. Not sure what to think.
Old Mar 15, 2008 | 07:31 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
does it smell like a computer room
thats wierd, i had an amp for my radio and my CB in my big truck and never smelled anything, same for my camaro, no smell.....i agree it seems to me that its getting to hot
Old Mar 29, 2008 | 10:55 PM
jw89camaro's Avatar
Car: 1989 I-Roc Z28
Axle/Gears: 3.45
u have to get it off the carpet with no air flow its is very likely to blow again
Old Mar 29, 2008 | 11:14 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Ive run 2 amps on carpet under seats for many of months at a time and no smell or problems.
Are you running correct gauge wiring for the amps?
Old Mar 29, 2008 | 11:53 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Delete
Old Mar 30, 2008 | 12:54 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
he said it's an audiobahn. i'm with stevo, make sure you're running the correct guage wire and check your grounds
Old Apr 3, 2008 | 03:21 AM
duck2292's Avatar
Car: 1992 Trans Am convertible
Engine: 305 tpi
Transmission: auto
Axle/Gears: 373
audiobahn amps stink anyways! lol, for real though are you running the correct load (ohms)? right size fuse? proper power and ground cables? If yes to all, it might be the coating they used on the circuit board(s). <just throwing that one out there. A little boy in Thailand made that amp anyways.
Next time spend a couple more $'s and buy an amp thats built in the USA!
good luck
Old Apr 3, 2008 | 12:51 PM
Calaban007's Avatar
Car: 95 Z28/IROC-Z
Engine: LT1/L98
Transmission: 6 Speed/700R4
Axle/Gears: 3.42/2.77 Boo!
How many Ohm are the speakers? Is it a two or four channel amp? Do you have the amp "bridged" with all four speakers? Is your amp 2 Ohm or lower stable. If you have 4 4 Ohm speakers wired parallel your amp has a load of 1 Ohm. If you had 4 8 Ohm speakers wired the same way you'd have a 2 Ohm load.
I may have messed up a little of the terminology, but that's how it works with the Ohms and stuff. My 2 RF 12's are 8 Ohm because my amp is only stable at 4 Ohms.
The lower the Ohms the hotter the amp will run, possibly burning up your amp.
Good Luck
Old Apr 3, 2008 | 09:28 PM
Aerohokie's Avatar
Car: 84 Trans AM
Engine: 327
Transmission: M5
^^^^^^^^What he said^^^^^^^^^^
Tell us how you have it wired, maybe some pictures. I run my amps on the carpet, no problems. Amp model, speaker model, whatever info you can share will help.
b's90cam
Car Audio
Feb 13, 2006 11:49 AM
stiers
Car Audio
Sep 25, 2003 06:32 PM
Camaro92RScalet
Car Audio
May 31, 2002 10:37 PM
THEISENATOR
Car Audio
Apr 29, 2002 10:49 PM
1986CamaroSC
Car Audio
Apr 6, 2002 09:23 PM
