2 subs, one box, one travels way more than the other
Old Mar 17, 2008 | 10:03 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
i have two rockford fosgate 10" ps 4ohm shallow mount subs, and the coresponding rockford amp that i had hooked up to the in my truck. i put them in a custom box in the z, and the left sub (further from amp than the right sub so has longer wire) travels alot more than the right sub, as in movement of the speaker cone. i have no idea why, does anyone? thanks, alex
Old Mar 17, 2008 | 10:27 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: 2 subs, one box, one travels way more than the other
could they be out of phase? they werent b4, and they are wired up EXACTLY the same way, so i doubt that's it, i just hope one isnt blown.....
Old Mar 17, 2008 | 11:18 PM
popballz's Avatar
Car: 89 firebird
tried switching the wires and see what happens?
Old Mar 17, 2008 | 11:24 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
not yet, i dont wanna have to take my subs out lol, but i will tommorrow if no one can shed light on why this is happening. i mught also call the local audio store and see what they have to say, they sound good, but move different so i donno
Old Mar 19, 2008 | 05:01 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Possible that the one not moving as much the wire came off? So it's not really playing but just the back pressure from the other sub is making it move?
Old Mar 25, 2008 | 06:18 PM
86irocguy's Avatar
Car: 1986 Iroc-Z
Engine: 350 4-Bolt Main
Transmission: Rebuilt 700R-4
Axle/Gears: 3:42
try turning on ur stereo and unhook one channel at a time and see if the sub thats still hooked up to ur amp is playing then hook it back up and unhook the other channel and the other sub should play if not then u have a wire unhooked.
Old Mar 26, 2008 | 02:14 AM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
thanks for all the help guys! i figured it out. apparently, the positive and negitive signs on the sub itself are backwards? because when i hooked positve up to positve like your supposed to, nothing happens, but if i go positive to negitive and vice versa, its all good.wierd i kno, i was like maybe i did it wrong, but i looked at it for an hour, the markings are backwards lol. ahhh quality control..... but anyways, i took these same exact subs and amp from a ported box, and moved them to a non ported box with almost twice the airspace of the original box, and wow do they hit harded, id say an easy 60% improvement. odd thing is, the old box had the correct airspace for the subs, and was ported. so i donno but i like it! thanks again guys
$750 L98
Feb 1, 2025 02:25 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
91 SrS
Oct 7, 2015 04:32 PM
raymondandretti
Sep 27, 2015 06:43 PM
efiguy
Sep 27, 2015 01:30 PM
