How much road noise is normal
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
a week after i bought my camari my stereo was stolen and i just got around to getting a new one 5 months later. thing is, i just realized how loud the car is when i am driving around.
the road noise is so bad i am constantly turning up and down the volume.
is this normal? how loud are they supposed be and does dynamat help?
Car: 86 Iroc
Engine: Soon to be LS 6.0
Transmission: Soon to be mn12
Axle/Gears: Strange 9in 4.10
Re: How much road noise is normal
Car: 1992 Camaro RS
Engine: 350 Carb'd
Transmission: 5 Speed
If you are hearing a lot of road noise you may want to look into a few things with your car. First are your seals/wheather stripping good and installed properly. If not this alone will increase the road noise you hear inside that car a lot. Dynamat helps a lot if you are willing to do the work and install it correctly. Thirdgens are famous for being loud inside the car, mine is not too bad but I have recently re-did all my wheather stripping which seemd to help and I also have plans to dynamat my whole car.
Hope this helps
Hope this helps
Car: 85 Camaro IROC
Engine: 5.7 TPI
dj, what are these other options you speak of?
yeah, i guess my weather seals are in pretty bad shape.
i wish some of that stuff was cheaper tho... dang, i mean $250 for trunk weather seal...
im thinking about subframe connectors and i hear that helps a lot, but most of my noise is coming from the back. it sounds like i have a toolbox full of crap rattling around in the trunk.
yes, ive checked the spare tire and its bolted in very securely.
i guess dynamat isnt very cost effective either though...
Car: 1992 Camaro RS
Engine: 350 Carb'd
or just crank up the music bro, its only noise...Best advice is when working on a car or restoring one is to do it in sets. Not everything at once, just start somewhere and work slow to the finish product. Try this website, its www.secondskinaudio.com its like dynamat but it is cheaper. I have heard good things about it and I think thats what I am going to put in my car.
Car: 85 Camaro IROC
Engine: 5.7 TPI
Car: 1992 Camaro RS
Engine: 350 Carb'd
yea bro my bad thats it, but as you can see it is a little cheaper then dynamat.
