head unit power?
Old Dec 2, 2008 | 09:00 AM
smgseanmicheal's Avatar
Car: 86 z28
Engine: 305ish
Transmission: 700r4-kickdown cable
Axle/Gears: ill figure out when i pull it apart
head unit power?
i have a head unit from 2000 that stopped working and i cant figure out why i just hooked up two jl audio subs and a jl amp and the amp is gettin power but the head unit wont turn on anymore i took it to a shop and it powers on so would anyone know where i could get the power wires and how to hook it up....... its a panasonic head unit any suggestions on gettin a new one?
Old Dec 2, 2008 | 11:06 AM
87transGTA's Avatar
Car: 87 GTA
Engine: 350 Tune port
Transmission: 700r4,2500 stall
Re: head unit power?
i can email you a wiring diagram of the connecter its self off the original connecter off the factory radio and u can go to the panasonic site and it will give you an online manual of the headunit and if your connections are right you might have just blown a fuse in the back of the headunit or an acc fuse
Old Dec 3, 2008 | 08:41 AM
Car: 86 z28
Engine: 305ish
i checked all the fuses in the fuse box and they all seem to be fine but i replaced them with new ones anyway... the wiring diagram might be a help but i think that its color to color as far as the wires go
Old Dec 3, 2008 | 09:09 AM
BMR Sales's Avatar
Former Sponsor
You might find an authorized repair center for panasonic, just depends on how much its going to cost to repair vs buying a new one. I had an Alpine head unit that I screwed up but it was only 100 bucks to fix it so I thought it was worth it.
Also try a jumper wire to power it up when all your other stuff is hooked up and see if that does anything?
Old Dec 3, 2008 | 02:51 PM
87transGTA's Avatar
Car: 87 GTA
well its only color to color if u have the adapter if u try doing color for color with the original connecter that might be why it isnt workin and then again it might just be dead, there is also another fuse inside the unit that might be blown
Old Dec 3, 2008 | 04:14 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Make sure you hook up the 12v, ACC, and Ground right. with those 3 wires hooked up, it should be working. You can test the 12v and ACC lines to see if they have juice.
Old Dec 4, 2008 | 08:36 AM
Car: 86 z28
Engine: 305ish
the head unit works i took it to a shop and he can get everything working the amp works the subs work the head unit works and if i could get the car to the shop id have him wire it in but i cant so im 17 im not that brilliant when it comes to wiring stuff in expecialy when i dont have the wires i need would anyone know what gauge wire is the power to the head unit if i can figure that out i should be able to wire it in somehow
Old Dec 4, 2008 | 12:07 PM
BMR Sales's Avatar
Former Sponsor
Head unit power wire should be 16 to 18ga. Do you have a meter? You could check for a hot wire in the dash and use that for testing it.
Old Dec 4, 2008 | 02:10 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
You can do it man Like the post above said, get a meter, test the lines, to see what speaker is which you can take a double A battery, connect the speakers wires to this battery and you should hear static.
Old Dec 4, 2008 | 07:02 PM
Civerus's Avatar
Yellow = 12v constant (for clock and memory)
Red = 12v Ignition (for when the key is on, radio works, functions)
Black = Ground (common)
Most head-units now require an antenna to be plugged in to turn on. Try this.
GM vehicles have all those factory.
Gray is Illumination, Orange is the Dimmer for headlights, aftermarket units most of the time do not use these, they are only needed for factory radios really, so if it doesn't call for it, ignore those wires.
the Yellow, Red, Black, and Antenna should all be hooked up before it will turn on.
The blue wire is either Power Antenna or Amplifier Remote, the blue/white striped wire could also be either of those, I do not remember.
I'm not sure if you know or not, but make SURE the remote is hooked up to the remote on the amplifier, and not the +12v, the +12v is for the large wire coming from the battery, sorry I used to work in a car stereo shop, so I have to ask/tell you this.
Old Dec 5, 2008 | 09:05 AM
Car: 86 z28
Engine: 305ish
remote wire is blue right? and i think its the red power wire i need to replace so im gonna go talk to the guy at the shop about that and see what i can find out
Vintageracer
Jan 10, 2020 05:33 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
ZsTransAm
Aug 11, 2015 07:30 PM
