Best place to connect the REM cable???
Old Mar 9, 2009 | 11:10 PM
vargasjc's Avatar
Whats the best place to connect the REM Cable from the amp???
My friend recommended connecting it straight to the 12V battery...but I noticed that would keep it on all the time....So I removed it and I am looking for a better spot ....Where on the radio does it connect so that it would turn on/off along with car?
Old Mar 9, 2009 | 11:15 PM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Re: Best place to connect the REM cable???
You can splice it right into your gauge fuse, it even tucks nicely under the carpet from right there. And it'll turn off when the car is off as well. Just either buy a wire sleeve for the fuse, or be gentle and wrap and black tape it around the blade of the fuse. Plug the fuse back in, voila, you have a remote.
Old Mar 9, 2009 | 11:43 PM
vargasjc's Avatar
you are talking about the fuses on the drivers side?? under steering wheel?? which one is the gauge fuse??
Old Mar 10, 2009 | 12:55 AM
IROCKET4U's Avatar
Car: 1988 IROC
Engine: 5.7 litre
Transmission: Auto--700R4
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
The blue (or blue with white stripe)from your head unit is the amp (or power antenae) remote turn on. Run that wire back to the amp.
Old Mar 10, 2009 | 01:27 AM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
^^^^^^^^^^ What he said
Head units have designated wires for that because if you hook it to the battery the amp will be on all the time, If you hook it to your fuse block you risk damage to the wiring system. I would much rather replace a radio than a car wiring harness or be stranded with a dead battery.
Old Mar 10, 2009 | 11:24 AM
vargasjc's Avatar
Yea...thats my question....which wire do I connect it to??
the blue/blue-white from the radio the other guy said?
Old Mar 10, 2009 | 11:53 AM
cdoyle's Avatar
Are you using a factory deck or an aftermarket deck?
If it's aftermarket then there will be usually a blue/white wire that is used for the amp turn on.
If you're using the factory, then it won't have this. Then you could find an ignition controlled wire, and it will shut off whenever the key is turned off. So you could tap into the wire that turns the stock stereo on/off when the key is turned.
Old Mar 10, 2009 | 12:21 PM
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
On a aftermarket then its blue to blue. If you find a blue wire behind a aftermarket headunit then it is for the remote.
Old Mar 10, 2009 | 07:41 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
go ahead and connect it to the battery. just put a switch in the wire and it won't always be on..
Old Mar 10, 2009 | 11:20 PM
vargasjc's Avatar
Thanks everybody for your input...I found the blue/white cable and I
got my subs working now ..THANK YOU again
Old Mar 12, 2009 | 10:57 AM
-srs-'s Avatar
Car: 1991 Z28 Vert
Just an FYI for later in case you want to do multiple amps. On all of my multiple amp installs I use the REM on the aftermarket head to trigger a relay to supply +12v. Just for extra caution I wire the normally closed side to ground so there is never a chance of the amps trickling the battery dead.
Old Aug 13, 2017 | 09:36 PM
andrewbova88's Avatar
I read through all these replies, but i have a Pioneer DEH-P6600 cd deck and a power acoustik 980 watt/2 channel amplifier. The amplifier has an REM connection receiving piece on the amp and the small blue wire goes to where? The cd deck? Which wire? Thanks in advance!
tglennon11
Sep 23, 2015 05:30 PM
TheTraut88
Sep 11, 2015 05:16 AM
64goatman
Sep 9, 2015 01:09 PM
TheTraut88
Sep 7, 2015 05:22 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
