Kicker
Old Apr 27, 2009 | 03:53 PM
HarmonyCamaro's Avatar
Car: 83 Z28 Camaro
Transmission: 5 Speed manual
Kicker
has anybody had any good experience with kicker subs?
i was going to buy 12" sq kicker solo-X subs... if there was a way i would buy the 18" ones but doubt they could fit anywere in the hatch
here the specs of the 12 inch solo x
ModelS12X
Size (IN.,CM)12, 30.5Weight (lbs.,kg)47, 21.3Max Rec Amplifier Power (WATTS PEAK/RMS)*5000/2500Sensitivity (dB 1w/1m)87.7Frequency Response (Hz)20-100Mounting Depth (IN.,CM)8-9/16, 21.7Mounting Cutout, Square (IN.,CM)11-1/4, 28.6
Old Apr 27, 2009 | 04:03 PM
87350IROC's Avatar
Car: 87' IROC
Re: Kicker
Are you really planning to give that sub 2500 watts RMS?
If not, I wouldn't bother. The square Kickers have a reputation for lots of noise with decent sound quality. The question is do you want noise or music?
Old Apr 27, 2009 | 04:19 PM
Car: 83 Z28 Camaro
Re: Kicker
lots of noise reputation as in? and yes im planning on buying one amp for each sub try and find a 2500 watt amp
Old Apr 27, 2009 | 06:11 PM
87350IROC's Avatar
Car: 87' IROC
Re: Kicker
The square Kickers are loud but only ok in sound quality.
Are you looking to compete in SPL competitions? or just get your car bumping? or what?
2500+ rms watts is way to much to have balanced music. The only reason to run that much power is for competition. Have you ever heard a setup with that much power?
Old Apr 27, 2009 | 06:20 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Transmission: 700R4,700R4
Axle/Gears: LSD,LSD
Re: Kicker
i have a 15" L7 with a 2000w rms amp on it...that thing is plenty loud...i had it in my camaro with a 3.5 cube box slot ported..and the box was so big it sat on my seats that are folded down..was a pain to see out back..i would stick to twelves at least..unless of course you're going competition...
Old Apr 27, 2009 | 06:22 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
Re: Kicker
with that set up i hit 145 db...
Old Apr 27, 2009 | 06:55 PM
Car: 83 Z28 Camaro
Re: Kicker
yea my friend had two 15's kickers squares same as yours in a cavalier and i loved the bass and bump to it good for a back massaging tbh lol
Old Apr 29, 2009 | 05:50 PM
DarrensCamaro's Avatar
Car: 1992 Camaro RS
Engine: 350 Carb'd
Re: Kicker
I run 2 12 inch Kicker CVR's and absolutely love them. I used to run 2 L7's in my Jimmy and those sounded great too. I have had nothing but good experiences with my kicker subs!
Old Apr 29, 2009 | 07:03 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
Re: Kicker
Been running 2 Kicker comp 10's mounted in my fold down shelf for 4 years now and love'em. Now I all about 1 cubic foot per, but easy install great sound, light weight and cheap. I also have a Bazooka 10in in my IROC. Again cheap/light and effective. Motor'in, whats your price for flight...........
shawn
Old Apr 30, 2009 | 09:50 AM
dualquadcamaro's Avatar
Car: 1983 Camaro Berlinetta
Engine: 383 stroker with 2 4bbls
Axle/Gears: 9" 4.56 full spool
Re: Kicker
im a big kicker fan as u can see by the pics. they are 3 kicker l5's 600 rms ea. ive got a kinetik bat/cap with a interstate battery up front. the amp is a rockford fosgate T1500-1bd 1500rms amp, pioneer cd/mp3 head unit and all four doors have 6" pioneer speakers and it bumps some serious bass.
Shot with CU720 at 2009-04-30
Old May 1, 2009 | 09:18 PM
Car: 83 Z28 Camaro
Re: Kicker
yea im going kickers for sure i just hope i can fit 15" in the hatch which i know i can.... going to get a custom box though and maybe a custom thing that goes over the hump thing for the two amps or one and a capacitor
Old May 12, 2009 | 02:13 AM
pyrocuervo's Avatar
Car: 1990 rs tbi soon to be lsx
Engine: 305 soon to be ls out of a 03 vette
Transmission: 700r to be 4l60e
Axle/Gears: stock to be posi
Re: Kicker
that should work just fine. I have a 15" L7 in a custom box ibuilt myself. It bits hard as hell.
Old May 12, 2009 | 04:50 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Kicker
Just remember that the more bass you make, the more the panels shake.....
Make sure you sound deaden first or all you will hear is your car rattling.
Why not look at some JL 12w7's they would hit low and hard.
92GTA
Apr 9, 2016 07:39 AM
RedLeader289
Sep 23, 2015 06:50 AM
JP84Z430HP
Car Audio
50
May 1, 2001 08:25 PM
JP84Z430HP
Car Audio
Oct 15, 2000 09:18 PM
