No Sound???
Old May 4, 2009 | 01:12 PM
Eustace16's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
No Sound???
I hooked up my JVC HU into my 1989 Camaro RS and got no sound please tell me whats wrong.....all the wires are connected properly and i cant figure this out.
and i do have the bose stock speakers
Old May 4, 2009 | 02:19 PM
87350IROC's Avatar
Car: 87' IROC
Re: No Sound???
If you have BOSE then thats why its not working. Bose speakers are not compatible with any old receiver. You either need to retain bose or get rid of it all.
Old May 6, 2009 | 10:51 AM
Knight98's Avatar
Car: Trans Am
Engine: 350 L98
Re: No Sound???
Is there Bose Amps as well? Can i just swap speakers with deck or do I have to rewire it all?
Old May 14, 2009 | 09:04 PM
Eustace16's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Re: No Sound???
Again....can you just swap out the speakers, or do you have to do something else???
Old May 15, 2009 | 07:20 AM
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
Re: No Sound???
Go through Crutchfield and get the adapter for the the Bose set up and you can use your JVC head unit. I know I also have a JVC head unit and that is what I had to do.
Old May 15, 2009 | 01:40 PM
88TransAmFreak's Avatar
Car: 1971 Camaro
Re: No Sound???
I thought 87350IROC made it pretty clear in post #2 , but I'll explain it a little easier.
You need to just replace the bose speakers with aftermarket and run new speaker wire from the radio (bypassing the factory bose amps) to the aftermarket speakers.
Or get the adapter from crutchfield...but if your bose amps fail, your back to square one, bypassing the factory amps keeps it simple.
Easy as that
Old May 20, 2009 | 12:17 PM
Eustace16's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Re: No Sound???
K now i understand, but could i just buy the Bose adapter and then install new aftermarket speakers and still get sound?
Or does that just make no sense?
Old May 20, 2009 | 01:16 PM
Knight98's Avatar
Car: Trans Am
Engine: 350 L98
Re: No Sound???
I just took a few hours and rewired. All good now and sounds way better. No poping or static. Thanks again for the help.
Old May 20, 2009 | 01:28 PM
Eustace16's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Re: No Sound???
Ill do that then, thanks
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
