front dash speaker HELP!
Old Aug 15, 2009 | 09:23 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
okay so i bought a pair of 4x6 performance technique 400w 2way speakers.. the mounting depth is 43mm (1.69")
will they fit?
do i have to chop a bit?
help please
thanks
Mikey
Old Aug 15, 2009 | 09:46 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
Re: front dash speaker HELP!
TTTTT
Old Aug 15, 2009 | 10:36 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
=/ help....
Old Aug 16, 2009 | 10:46 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
Old Aug 16, 2009 | 03:18 PM
MaDeNMiAMi305's Avatar
Car: 92 CaMaRo RS
Engine: CARBED 350 5.7
i havent tapped into my camaros system quite yet but if i was you i would call your local high end retailer or go to crutchfield.com. they have all kinds of fitment information on thier site. worst case give them a shout. please post once you figure out the max depth it will allow with out fabracation or cutting. good luck.
Old Aug 16, 2009 | 06:26 PM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
I think they will fit, i used alpine 4x6, they were really tight. give me a few hours, and i'll check the depth on them to let you know. If mine are deeper yours will Fit. if mine are shorter your speakers will not fit......Mine have 0 clearness to the dash pad, and sitting on internal plasic, I can't see anything bigger or deeper fitting without cutting.....
Old Aug 16, 2009 | 06:31 PM
Car: 87 T-Top GTA
Alpine SPS-406, top mounted depth is 1 3/4" (1.75")......Your speakers SHOULD fit without cutting......Good luck....
Old Aug 17, 2009 | 11:54 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
they didnt fit...not even close! >
Old Aug 17, 2009 | 03:34 PM
Car: 87 T-Top GTA
most speakers come with a mounting bracket, did yours? And did you try to use it? I can't remember if I used mine! Your mounting depth seems fine! Maybe its the diameter of the magnet!!!!!! Or you may need to use some small washers as spacers! Like I said my speakers were a tight fit too.! Nice Looking Car Though....
Old Aug 18, 2009 | 03:01 AM
87 WHITE GTA's Avatar
Car: 1987 Trans am (SOLD), 1986 Trans Am
Axle/Gears: Stock
I have some pioneers(TS-A4657) 4x6 that I had in my T/A (I dont like bass in the dash so I installed some tweeters instead)The mounting depth is 1.75 as well..If u want them i can get them to u for.... 20 bucks shipped?...does that sound good? =] (I'd give em to u for free but Im saving up for my speeding ticket =[)the built in mounting bracket is beat up but I was able to screw em down with no problems and no rattle
Old Aug 18, 2009 | 11:25 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
pm sent to 87whitegta......
and no they didnt come with a mounting bracket....and i think its the diameter of the magnet...there pretty big...idk..it was dark when i tryed it..ill try doing it again.
Old Aug 18, 2009 | 03:44 PM
Car: 87 T-Top GTA
See the depth is fine, 87 white gta also had the same depth with his speakers. Therefore its the diameter like you and I said. You can buy and try those speakers from 87whitegta, or try taking back those you bought, even w/out the receipt you should get store credit and switch for something with a smaller magnet. My Alpine sps-406 fits tight.....But does Fit. If you don't like Alpine, at least at the store you can use its spec's as a guide line for fitment.....................and find something you do like.......
Old Aug 20, 2009 | 10:09 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
okayy..so mine actually fit now...after some hacking and stabbing on the drivers side....got it..lol..its like a 2" diameter magnet...maybe 2.5"
Old Aug 20, 2009 | 10:16 PM
Car: 87 T-Top GTA
Did you cut up the plastic????
Old Aug 21, 2009 | 11:48 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
yup...the a/c plastic....but i NEVER use it so...yeah..whenever i turn it on it just causes problems..and i like driving with my windows down anyway
Old Aug 21, 2009 | 01:59 PM
19Chevrolet84's Avatar
Car: 1984 Berlinetta,'82 and '86 Camaro
Engine: Rebuilt 350
Transmission: Automatic. =[
Axle/Gears: Stock
Well at least it was an option in your car...It gets hot without it...
Old Aug 22, 2009 | 10:10 AM
Axle/Gears: Stock
I thought u got a ticket..lol... u are a terrible liar dude... FLAKE OUT! lol
Old Aug 23, 2009 | 05:22 PM
mtwlkn122's Avatar
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
WOAH! wait a min here guys.
If it doesnt fit dont cut up your AC! You will have to do some finessing on the ducts. This has been covered on how to do this in the past. Do a search and youll find it.
IMHO either buy ones that fit or do the heat-and-finess techinque. Either way dont cut up your ac ducts guys! If you dont want AC then remove all the ducts and all the AC under the hood and save yourself all that weight. Either way dont cut up the ducts!
Old Aug 23, 2009 | 09:07 PM
Car: 87 T-Top GTA
That's a really good trick (heat and finess), never thought of that, good advise....But I think your too late. It sounds like "itsMikey" alresdy cut up his A/C cup. But others may read this and now will know....buy small magnet or use heat.
Old Aug 24, 2009 | 11:31 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
lmao...think ima just take out the whole a/c now =P dont need it..dont want it.
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
Street Lethal
Aug 14, 2015 08:25 PM
89lsc
Aug 14, 2015 04:58 PM
