sub placement options?
Old Aug 26, 2009 | 11:03 PM
mongoosekeith's Avatar
i want to add boom to my car but i want 2 15's and idk if there would be enough room for em in a well box any ideas?
Old Aug 27, 2009 | 12:15 AM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: sub placement options?
there is enough room there. but if u want it car be put on the hump or back seats...
Old Aug 27, 2009 | 09:33 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
If you're creative with MDF and fiberglass, you've got more than enough room. If you want to make it a bit easier on yourself, there are plans kicking around for a dual 12" box. Couple of good subs and that will more than make noise.
Any reason in particular you want 15s?
Old Sep 2, 2009 | 09:37 PM
i just like the way 15's sound, i have 2 p1 rockford subs a suv box and an eclipse amp avalible to me for around 500
Old Sep 3, 2009 | 02:54 AM
godjackass's Avatar
Car: 1987 iroc
Engine: blown up for now
Axle/Gears: 10 bolt/stock
http://cgi.ebay.com/CAMARO-FIREBIRD-...d=p3286.c0.m14
Old Sep 11, 2009 | 01:33 AM
mechanic1992's Avatar
Car: 1987 IROC-Z
I built one for two p1 12s and put it on the hump where my t top bag is and im scared someone is gonna steal my stuff, ive been wanting to put them in the trunk. Youll get better sound from them on the hump, but they are a hell of a lot more visable.
Old Sep 11, 2009 | 11:51 AM
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
in our cars u are actually supposed to get better sound by putting the sub woofers in the well
Old Sep 11, 2009 | 11:55 AM
Car: 1987 IROC-Z
alright then, why is that? cause the sound will bounce off the back glass?
Old Sep 11, 2009 | 03:30 PM
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
not sure why i remember seeing some theads over this, im guessing the small gap between the hump and the hatch creates sort of a directional port when the subs are place in the well.... btw ive had my subs in the well hum and back seats, and they sounded much louder in the well
Old Sep 11, 2009 | 03:46 PM
RamAirZ's Avatar
Car: 1999 Camaro Z28
Engine: 5.7
Go 2 12" L7's, will give you more than enough bump in the hatch. This was my old setup:
Old Sep 11, 2009 | 05:16 PM
Car: 1987 IROC-Z
Aahh ok, gotcha. Ive been meaning to put them in the well to get them out of the t top bag area and so they are less visable i just havent gotten to it yet.
Old Sep 12, 2009 | 05:48 PM
Car: 1987 IROC-Z
what do you guys recommend for building a box in the well? going with MDF or FG?
Old Sep 13, 2009 | 02:37 AM
RamAirZ's Avatar
Engine: 5.7
I went MDF and made a cover for it all. Depends on how good you are with fiberglass and what your design calls for.
Old Sep 13, 2009 | 06:49 AM
AKATDOG's Avatar
Car: 84 Z28
make sure you get 15's that dont require a whole lot of airspace, i have a box now that takes up alot of the trunk and its under 5 cubic feet... if your good with wood use birch its lighter than mdf but i little pricier
Old Sep 16, 2009 | 03:13 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
The box in the link above is designed for 1.8 cu.ft. per sub. That's NOT a lot of air.
Also remember that two 15's is like having FIVE 10's in the back. That's a LOT of air moving.
15's will hit low but not hard/tight.
Up to you....buy ear plugs
Old Sep 16, 2009 | 03:26 PM
lmao i like the low hard rumble that only 15s can produce
Old Sep 16, 2009 | 03:56 PM
AKATDOG's Avatar
Car: 84 Z28
like i said watch for the recommended air space when you buy your sub, im a stereo freak myself, i have 2 12" rockford T2's in my trunk right now, the box takes up ALOT of the trunk not just the back well, and its just enough for the minimum airspace recommended for my subs, 1 good 15" in a proper encloser will give you more than enough rumble trust me...
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
gixxer92
May 18, 2017 11:20 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
