New head unit.
Old Sep 20, 2009 | 11:30 PM
cspear1's Avatar
Car: 1985 Z28
New head unit.
A few days back my dad and i pulled the stock radio out and replaced it with a new headunit with a HUmount kit. Just got a few pictures today thought id post what it looks like!
Day (not lit)
Day (lit)
Night
We also ran the ipod cord through to the center console so its not in the way of anything and out of site.
Now i am wanting to put subs in, but neither me or my dad know anything about installing subs or an amp. A couple questions, do you have to build your own box to fit or is there somewhere out there you can buy one? Would fiberglass or wood sound better? Like i said earlier neither me or my dad know anything about subs and would like opinions on some subs/amps that sound good for not all that much money. I dont mind spending a few bucks but im not looking for competition grade equipment. Keep in mind i still have the stock speakers in the car, not sure whether or not that will make a difference.
Thanks, Chris
Old Sep 22, 2009 | 10:52 PM
cspear1's Avatar
Car: 1985 Z28
Re: New head unit.
Bump. Still looking for input. Also i am looking at a Q-Logic box, anyone else had one or know anything about them?
Thanks, Chris.
Old Sep 22, 2009 | 11:16 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: New head unit.
here was my solution:
https://www.thirdgen.org/forums/car-...mp-us-old.html
I get plenty of deep sound, without a big heavy box. Unless you want to rattle the windows of all the houses in the 'hood, a cheap amp/sub combo from like Pep Boys can do wonders. My entire setup including this little amp and one 10in sub and materials for the shelf I built might add up to $200. Being young, you may want more, but I throw it out there for your consideration.
JUST PLEASE DON"T run the large + wire for the amp through the door opening - the opening/closing of the door wears on the wire until it shorts - I've bought several parts cars that had this, and the resulting fire is why they were parts cars.
Old Sep 22, 2009 | 11:37 PM
cspear1's Avatar
Car: 1985 Z28
Re: New head unit.
Thanks for the response. I'm not looking to shake the entire neighborhood, just my car.I ordered 2 Rockford Fosgate P1 10's. and im thinking about getting this amp http://www.bestbuy.com/site/olspage....=1218063832403
As for a box im looking at a Q-Logic box since it seems to be the only one around aside from building one that fits flush with the top of the well. Anyone know of any other pre-built boxes that fit flush?
Old Sep 22, 2009 | 11:46 PM
mechanic1992's Avatar
Car: 1987 IROC-Z
Re: New head unit.
If you wanted to spend the money, you could buy a RF p300-1 amp, itll run your subs easy, and then if you decide to upgrade to 12s or P2s or whatever, that amp will run them. Or the P500-1 or P1000-1 amps also. They will run any RF subs you get and most likely any subs for that matter.
Old Sep 22, 2009 | 11:48 PM
cspear1's Avatar
Car: 1985 Z28
Re: New head unit.
thanks again for the response, ill check into those amps. Any suggestions on the enclosure though?
Old Sep 23, 2009 | 12:47 AM
Car: 1987 IROC-Z
Re: New head unit.
Do you mean whether or not to have it ported or sealed? or placement? With my P1 12s i was told sealed sounded better, but idk about yours. But placement wise, i have been meaning to get a box built for the back well, its supposed to sound better because itll bounce off your back glass and give it better sound. And im getting mine custom built for only $100 from a local audio store, im sure you could get the same price where you are at. Or you could build the box yourself, if thats your plan heres the link to the dimensions forum https://www.thirdgen.org/forums/car-...l-sub-box.html and the guys building mine are going to use 1/2 MDF. A box in the well looks alot better than this
Old Sep 23, 2009 | 01:49 AM
ThePain's Avatar
Car: 1992 RS
Transmission: Automatic
Re: New head unit.
I LOVE you. Your Humount, those are the yelllow lights correct? Not red... I'm wondering because i want to it to match the stock dash lights at night. Looks sick!
Old Sep 23, 2009 | 03:22 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: New head unit.
The install looks great. You should just go ahead and make a sub box. Follow the intructions on the sticky on the top of the Audio Forum. It explains everything on making a sub box. Those are the directions I used to make my box and it fits in the well perfectly. Wiring the amp and subs is very easy. Your headunit was harder to wire than the subs and amp. Normally an amp will have the + and - for the subs (each one). The + and - to power the actual amp and a 12v+ input to turn on the amp. And lastly RCA/Component inputs. That amp should do fine and it'll come with instructions aswell. Let us know if you have any more questions. But if you still have your factory 20y/o speakers, you might want to replace those instead, that will make a big difference...
Old Sep 23, 2009 | 01:41 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Re: New head unit.
Ya, amps are pretty straight forward when installing. Just don't run your power and rca's on the same side of the car. SUPPOSEDLY it makes static interference.. Dunno if its true but i ran mine separate just in case..
Old Sep 23, 2009 | 02:29 PM
HCR13's Avatar
Car: 1987 Trans Am
Re: New head unit.
Originally Posted by V6F1R3BRD
...Dunno if its true but i ran mine separate just in case..
same here. I already had the carpet pulled up, so why not!
Old Sep 23, 2009 | 03:14 PM
Christal_Z28's Avatar
Car: 1992 Camaro Z28 Heritage Edition
Engine: 5.7L 350; check out my VGarage :-)
Transmission: 700-R4
Re: New head unit.
Wow... looks neat and matched. and the Single DIN plate with Camaro Z28 written on it pulls it all together quite nicely. Do it yourself or did you buy that somewhere?
Old Sep 23, 2009 | 03:33 PM
cspear1's Avatar
Car: 1985 Z28
Re: New head unit.
Thanks for all the responses! The LED is actually red but in that picture it looks kind of yellow.Ill keep the tip about separating the wires in mind when hooking my amp up. I might check around town to see if anywhere can build a custom box for me. Any suggestions on speakers? I have been looking around on crutchfield and the responses there are mixed. And we bought the kit from a company in Canada but hooked it all up ourselves.
Chris
92projectcamaro
Jan 18, 2016 08:00 AM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
z28guy134
Sep 1, 2015 11:50 PM
stalkier
Aug 21, 2015 01:54 AM
beast94
Aug 20, 2015 06:44 AM
