A good combo?
Old Nov 10, 2009 | 08:37 PM
musclecar201's Avatar
Car: 87 Camaro
Engine: 2.8l V6
A good combo?
I have been searching endlessly for new speakers for my camaro. I have the original speakers with a sony cdx-l350 deck in my car. I have been looking at a pair of these kicker speakers, and seem to have heard good things about them.
DS460
4x6" Coaxial 2-Way Speakers
Max Power: 50w
RMS Power: 25w
Impedance: 4 ohm
Tweeter size: 1/2"
DC Resistance: 3 ohm
Sensitivity: 88 dB @1w/m
Effective Frequency Range: 50-20k Hz
Mounting Hole Diamater: 4x6"
Top Mount Depth: 1 7/8"
Bottom Mount Depth: 2 1/8"
Tweeter Protrusion: 3/16"
Tweeter Magnet material: neodymium
Tweeter Dome material: PEN
Tweeter Design: Balanced Dome
Woofer cone material: Polypropylene
Woofer surround material: ribbed polyfoam
DS6930
6x9" Coaxial 3-Way Speakers
Max Power: 140w
RMS Power: 70w
Impedance: 4 ohm
Tweeter size: 1/2"
Sensitivity: 92 dB @1w/m
Effective Frequency Range: 30-20k Hz
Mounting Hole Diamater: 5 15/16 x 8 3/4"
Top Mount Depth: 3 1/4"
Bottom Mount Depth: 3 3/4"
Tweeter Protrusion: 3/8"
Speaker Grilles Included
They seem like some of the middle of the road speakers without going over board. I listen to mostly an arrangement of rock music so bass isn't really a major concern.
Any comments as to how the speakers are?
Old Nov 10, 2009 | 09:35 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: A good combo?
I am gonna subscribe since i am looking for the same thing
Old Nov 10, 2009 | 09:50 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: A good combo?
the 4x6 are good speakers, but they sit too high, u would have to use spacer, and ur dash would be raised a bit
Old Nov 12, 2009 | 01:33 PM
Car: 87 Camaro
Engine: 2.8l V6
Re: A good combo?
Two high as in it will hit the dash pad? There is no way you can just bend the plates a little so it sits lower?
Any good suggestions for a good combo of 6x9 and 4x6 that are middle of the road as far as quailty and price, don't need anything super fancy.
Old Nov 12, 2009 | 10:36 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: A good combo?
drop the 4x6's...get tweeters...and those 6x9's are great if u have an amp hooked up...
Old Nov 14, 2009 | 08:30 AM
Car: 87 Camaro
Engine: 2.8l V6
Re: A good combo?
I see your point but how easy would it be to hook up in place of the speakers? and would it sound as full with just the 6x9 and tweeters. I was also thinking about then just making it a 6 speaker system and putting two midwoofers in the trunk with an amplifier if nessecary.
Heres another look at my speakers
Pioneer TS-A6963R (sail panels)
6"x9" 3-way car speakers (pair)
injection-molded polypropylene woofer reinforced with basalt, graphite, and Aramid fibers (rubber-coated cloth surround)
3/8" PET silver film dome tweeter
2-1/4" treated paper cone midrange
power range: 2-40 watts RMS (270 watts peak power)
frequency response: 31-37,000 Hz
sensitivity: 91 dB
top-mount depth: 2-7/8"
PIONEER TS-T110
120W TWEETERS (pair)
KEY FEATURES:
    Old Nov 14, 2009 | 10:48 AM
    Broc's Avatar
    Car: 1988 Chevy camaro I-roc z-28
    Engine: 350 tpi
    Axle/Gears: stock
    Re: A good combo?
    what kind of money are you looking at spending?
    Old Nov 14, 2009 | 12:04 PM
    Car: 87 Camaro
    Engine: 2.8l V6
    Re: A good combo?
    Around 200, but no more than three.
    My borhter has a nice pioneer system in his ranger and it sounds nice, and my dad has pioneer in his trucks and they hav enever given him a problem unlike his old inffinitys. Basically all I really need to know is the pricess of hooking up these tweeters and if I will need an amp for the 4 6x9's or if I should just go wtih the midwoofers for the 6x9 in the rear and just keep a 4 speaker system.
    polaris91's Avatar
    Car: 88 camaro z28
    Re: A good combo?
    i have those same kickers in my dash and my buddy has the 6x9s in his truck they sound awsome and i had no clearence problems in the dash they bolted right in
    Old Nov 14, 2009 | 01:04 PM
    Car: 1991 camaro rs
    Engine: 305 tbi
    Transmission: t5
    Axle/Gears: stock
    Re: A good combo?
    on my 91 they didnt.... well they did bolt up, but also raise the a little over a 1/4 inch
    Old Nov 14, 2009 | 03:22 PM
    Car: 87 Camaro
    Engine: 2.8l V6
    Re: A good combo?
    Yep I'm pretty sure to go with the pioneer setup, but my question is, do you mount up tweeters just like regular speakers where the original 4x6's went?
    I can see how bass in the dash can be bad, my dash rattles enough already.
    Old Nov 16, 2009 | 02:10 AM
    danziger's Avatar
    Car: 1991 Formula Firebird
    Engine: L98 with headers/exhaust
    Axle/Gears: 3.23 10-bolt
    Re: A good combo?
    I had Polk 4x6s, but the surround tore, so in went some Memphis Audio 4x6s. When putting in the new speakers a little silicone caulk in key areas really eliminated the amount of sqeaks/rattles. Then again, my dash didn't rattle much to begin with...
    Old Nov 17, 2009 | 09:24 AM
    Broc's Avatar
    Engine: 350 tpi
    Axle/Gears: stock
    Re: A good combo?
    if it was me i would go with memphis or rockford fosgate. that is what we had at my old job and man we put in sum badass systems. they are a little pricey but well worth it
    customblackbird
    Aug 15, 2021 10:16 PM
    IMissMy86TA
    Aug 31, 2015 08:40 PM
    nuggie
    Aug 25, 2015 01:27 PM
    theurge
    Aug 21, 2015 12:46 PM
    NufNuffZ28
    Aug 14, 2015 09:12 AM
