Question about an AUX hook up...
Old Jan 12, 2010 | 06:10 PM
3rdGenGuy6792's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 350 TPI
In my 92 Z28 I have an aftermarket Pioneer DEH-1000 Headunit. It doesnt have an AUX plug which sucks. As of now im using the cigarette lighter adapter for my iPod touch which ALSO sucks. My question is, is there like an aftermarket type AUX unit that hooks up to the headunit itself or cig lighter which allows me to use an AUX cable? Thanks
Old Jan 12, 2010 | 06:32 PM
87 WHITE GTA's Avatar
Car: 1987 Trans am (SOLD), 1986 Trans Am
Axle/Gears: Stock
Re: Question about an AUX hook up...
yes
Old Jan 12, 2010 | 06:33 PM
Axle/Gears: Stock
jk....there is an adapter that plugs into the back of your antena(not an fm transmitter)...its gonna run you around $50 bux...
Old Jan 12, 2010 | 06:42 PM
Engine: 5.7 350 TPI
any specific name for this adapter? i keep looking around but still have no luck.
Old Jan 12, 2010 | 06:50 PM
Engine: 5.7 350 TPI
im guessing its just an aux adapter? lol
i just looked that up and looks like theyre about $100. i might as well get a new headunit instead. the deh1000 blows
Old Jan 12, 2010 | 07:03 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
deh 4000 ub ftw
i got mine for 149-169 at walmart
make sure its the one with the usb port in back and you can plug your ipod/zune/thumb drive right in to the back of the unit.
then you can scroll thru menus as if it was the ipod/zune/thumb drive or just put it on random.
it will also charge the device.
a friend of mine got one and plugged an extra 120 gig laptop drive into the back and set it to random.
plus nobody sees anything sticking out the front, so it looks cleaner.
you also have a rear aux port and IIRC a front aux port, but i never use aux for anything so i cant be sure
Old Jan 13, 2010 | 07:19 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
If you're not looking to swap out the deck, take a look to see if it has the option to control a cd changer. I think Pioneer's all use the same IP-bus connector, so you can use something like this instead of changing out the whole deck:
http://cgi.ebay.com/ebaymotors/Pione...item518f254c67
Old Jan 13, 2010 | 07:59 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
My .02's...
Yes, there are options... FM modulator, that sounds like crap, cd changer cables, that I've had a horrible time with to...
Spend a bit extra $$$ and get a deck with Ipod / Iphone controls... Not only will it plug right in and you're able to control it from the deck, but it will charge your ipod / phone too...
Rafael
Old Jan 13, 2010 | 08:52 AM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
Originally Posted by RED_DRAGON_85
deh 4000 ub ftw
that is ssooo hard. i might look into that.
Camarothatcould
Aug 20, 2015 08:49 AM
1985chevydude
Aug 20, 2015 12:29 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
