Rear speaker questions in 86 TA
Old Mar 26, 2010 | 06:55 PM
Mikes86transam's Avatar
Car: 86 Trans AM LG4 5spd
Well my new TA didn't come with a head unit in it so I figured since I was going to buy a new radio I would get the speakers also. I was thinking I was going to go with 6X9's in the rear but when I took the cover off I found this (see picture). They are a 4X6 and a 5in. I really like the bass a 6X9 puts out though. What would I need to do to mount a 6X9 in there? Or should I stick with a 4X6 and 5in on each side? Also the dash speakers are 4x6 from the factory correct?
Can anybody tell me what this is? It was in a box of parts I got with the car. Is it a factory amp? It also has a switch on it.
Old Mar 27, 2010 | 03:35 AM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: Rear speaker questions in 86 TA
i think you have the bose package. crutchfield sells the adapter to fit 6x9 in the rear. theyll give it to you when u buy speakers from them. your going to want to run new wire from your deck to the speaker since it was factory amplified. 16 gauge will do you shouldnt need more than a 50 foot roll( its 10 dollars at walmart)
Old Mar 31, 2010 | 04:52 AM
MrMaro92's Avatar
well if you goin for aound quality and alot of highs id go with the 4x6 and 5 but if you want better all around sound go with the 6x9 set up im runnin 2 rockford fosgate punch 6x9s and i have a fosgate 300 4 channel pushing them and they sound great and ellocojorge is right thats a factory amp (crappiest thing ever made) id just run new wire from the cd player or amp ur call
Old Mar 31, 2010 | 09:41 AM
Where can I get the mount for the 6X9 speakers since my car didn't come with 6X9's from the factory? I looked at crutchfield and didn't see a mount for 6X9. Maybe a junkyard?
Old Apr 1, 2010 | 11:05 PM
MrMaro92's Avatar
most 6x9s come with the brackets and u can just drill into the mounts u have the new speakers should come with mounts cutouts and marked places to drill also try www.sonicelectronix.com
Old Apr 2, 2010 | 01:49 AM
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
did you imput your car model? itll basically replace the black plastic piece were you current speakers are mounted, with one that has a 6x9 hole( btw these do not come included with the speakers, they are a separate purchase, but crutchfield usually trows them in under a free install accessory.)
Old Apr 2, 2010 | 11:50 PM
WS6LOVE's Avatar
Car: '86 T/A
Engine: Vortec 406sbc-carbed
Transmission: 700r4-vette servo/B&M shift kit.
Axle/Gears: Ready to splode
You'll have to take the black box the 2 little speakers are in out of the hole and the 4 mounting holes for 6x9's should be there if I'm remembering right. No adapter needed. Pull the top of the box out first, it goes down into the hole a few inches.
Old Jul 7, 2010 | 05:10 AM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
In my car,i bought 2 4x6 Alpine Type SRS-406's and they fit,then for the the sub i bought 6 1/4 inch Legacy subs and it sounds badass!
Yes it has a factory 300 W amp,the mostly go out. So youre lucky urs still works! The speaker box that holds your speakers are rare( I have it too=]) so keep that! Just do what i did. It sounds great now!
and yes the dash speakers are 4x6's,but theyre a pain in the *** to get to
so i wuld just leave it man
I got an 88 T/a And just got done with my system. All my wiring was disconnected so i had to rewire everything
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
89lsc
Aug 14, 2015 04:58 PM
