My new sub...
Old Mar 28, 2010 | 02:01 AM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
My new sub...
So I was home alone today and bored. I had a marvelous idea and decided to take the ported subwoofer off of my parents 5.1 surround sound home theater system that hasn't been set up in 8 months, and try to put it inside of my GTA! My goal for the audio is to appear stock, but sound great. Not to be heard from blocks away, or rattle the car to pieces. What I have done today is accomplished my goal, and even surpassed it.
My system goes as follows
Sony CDX GT330 Xplod head unit with HD radio tuner
4x6 three way pioneers in the dash
6x9 4 way pioneers in the sails
and a 4 way 600 watt Sony amp that previously powered all of the speakers dash, and sails.
Now what I have done is taken that subwoofer and put it in the spare tire compartment of my GTA. I then bridged my 600 watt amp so that it delivers 300 watts to the sub, and 150 watts to 2 other channels. What I am going to do is make 150 watts go to my each of my 6x9s, and then power the 4x6s in the dash off of my head unit. I am going to move my amp to the drivers side and hide it underneath the lock box ,then cover the sub on the other side so everything is completely hidden.
here are a couple of pics and a video of the system.
In the video I have the 6x9s running off of the head unit, and the dash speakers still on the amp because I was too tired to take off the dashpad to swap the wires, so it will sound a lot better when that is done. This video doesnt do it justice, it sounds amazing from inside the car, all nice clean bass and it hits hard. I had to go and turn down the bass on my head unit so I could hear the words in songs, and it was rattling things on the walls in my garage.
http://s73.photobucket.com/albums/i2...t=100_0648.flv
I posted this to give you guys ideas, and because im excited about how it turned out. I will post a better video when its light out and all put together correctly.
Old Mar 28, 2010 | 06:18 AM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
Re: My new sub...
I am going to guess the sub will last maybe 12 and half mp3's....
Old Mar 28, 2010 | 11:02 AM
BigBadGTA's Avatar
Engine: 350TPI
Axle/Gears: 3:27
Re: My new sub...
Well we shall see. I listened to it for a good hour and a half yesterday and I turned the bass down so its at a safe level even when blasting music which I don't do often.
Old Apr 10, 2010 | 09:06 PM
matt1970pon's Avatar
Car: 1987 iroc z
Engine: 305 tpi
Transmission: MM5
Axle/Gears: 3.45 g92
Re: My new sub...
hey I maybe wrong but check was ohm the sub is running at. Most home subs are 10 ohm..cars 4 or 2. That will kill the sub quick.The best idea would be to get a car sub thats the same size and install it in the inclosure.
Old Apr 11, 2010 | 12:53 PM
TheMuskr's Avatar
Car: 89 IROC Z28 Vert
Re: My new sub...
I would suggest getting a real sub woofer. but whatever floats your boat. I dont think that will last long.
Old Apr 11, 2010 | 05:20 PM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
Re: My new sub...
i blew my sub once by putting it on the home stereo before i knew about ohms. home stereos run 8/10/16 ohms very high in other words, auto speakers rarely use more than 4 ohms. you'll blow something quick, and that looks expensive
Old Apr 11, 2010 | 11:16 PM
Get Bit's Avatar
Re: My new sub...
You can ruin a sub and amp by running them at the wrong impedance.
Old Apr 12, 2010 | 12:33 AM
BigBadGTA's Avatar
Engine: 350TPI
Axle/Gears: 3:27
Re: My new sub...
Well I looked up the manual for the system the sub came off of and it said that it was ran at 4 ohms. I looked up the manual to my amp and it said that the when bridged 300 x 1 like I have it puts out 4 ohms as well. I think its going to be fine. Its been over 2 weeks I have had it in the car and it still sounds great!
Old Apr 13, 2010 | 11:20 AM
87 WHITE GTA's Avatar
Car: 1987 Trans am (SOLD), 1986 Trans Am
Axle/Gears: Stock
Re: My new sub...
Just watch the gains and u should be fine then...if u dont play that shizz too loud u should be ok
Old Apr 13, 2010 | 12:39 PM
Stephen's Avatar
Car: 87 GTA
Re: My new sub...
A bit off topic but.....
You have TTA back seats in your GTA?
Old Apr 13, 2010 | 12:41 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: My new sub...
dude!!!! usps dropped my 3hp neo motor !!!
Old Apr 13, 2010 | 09:02 PM
windowrattler's Avatar
Car: 92 RS, 89 Formula, 84 Iroc
Engine: Carb 350, TPI 305, TBD
Transmission: T-5, 700r4, TBD
Axle/Gears: 3.42 Posi, 3.08 Posi, Moser 3.73
Re: My new sub...
As far as wrecking stuff impedence only matters for the amp. The sub is a constant load (not really but for our purposes it is). Home audio generally uses 8-16 ohm speakers and car uses 1-4 ohm. Now why does this matter? I'll give an example.
Lets say there is a car amp and it is 100 x 2 at 4 ohms or 400 x 1 briged at 4 ohms. If you hook up an 8 ohm speaker the amp is effectively 200 x 1 so it produces half the power which is half the work load so no problem for the amp.
Now if you take a home stereo it will be something like 100 x 2 at 8 ohms or 400 x 1 bridged. If you hook up a 4 ohm speaker its half the resistence so the amp will try to do 800 x 1 which is double the work load double the heat etc. Not saying it won't work but the potential to break is there.
Old Apr 13, 2010 | 11:08 PM
BigBadGTA's Avatar
Engine: 350TPI
Axle/Gears: 3:27
Re: My new sub...
This is why
But It now looks like this
Old Apr 13, 2010 | 11:13 PM
BigBadGTA's Avatar
Engine: 350TPI
Axle/Gears: 3:27
Re: My new sub...
Yeah that is what I plan to do. It sounds damn good inside the car, the bass is amplified by the rear hatch glass and sent up the front. You cant really hear it out side the car either, the tail lamps rattle a little bit, but I will fix that easily.
Stephen's Avatar
Car: 87 GTA
Re: My new sub...
Originally Posted by BigBadGTA
This is why
Ah. I could tell in the pic in the earlier post, that it was a standard hatch, not a Notchback hatch.
boldguy
Car Audio
Nov 22, 2009 07:28 PM
85TransAmDude
Car Audio
Oct 31, 2006 12:42 PM
UCF1Slider
Exterior Parts for Sale
Oct 22, 2006 06:10 PM
383 Smoka
Car Audio
May 1, 2002 03:13 PM
