amp wire
Old Mar 29, 2010 | 07:47 PM
GND-646's Avatar
Car: 1989 firebird
Engine: 350 tpi
amp wire
where did you guys all run your amp power wires and where did you connect the ground?
Old Mar 29, 2010 | 10:11 PM
DJ Delsym's Avatar
Car: 86 Iroc
Engine: Soon to be LS 6.0
Transmission: Soon to be mn12
Axle/Gears: Strange 9in 4.10
Re: amp wire
For the power wire, I ran through the passenger kick panel into the fender and routed it to the bay with the computer wires. As for the ground, I drilled a hole in the spare tire area than used a couple star washers and bolted it in place.
Old Mar 30, 2010 | 12:35 AM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: amp wire
lol that exactly what i did. except i got the wire to the engine compartment, trought the tube that connects the door wiring to the body.
Old Mar 30, 2010 | 10:21 AM
GND-646's Avatar
Car: 1989 firebird
Engine: 350 tpi
Re: amp wire
thanks for the help but this morning i went out and i seen on the driver side a hole in the firewall where the washer fluid wire goes and i pull that out drill the hole a bit bigger and put that wire back in and the power wire with it. as for the ground i found a bolt in the back near the marker light and just ran it there but thanks for the help
Old Mar 30, 2010 | 03:54 PM
DJ Delsym's Avatar
Car: 86 Iroc
Re: amp wire
But isn't your battery on the passenger side? are you going to go across the firewall than down wheel well? thats a lot of extra wire. I used a wiring kit and I only had about a foot and a half left over so you might be better off buying by the foot if you go this route. good luck with the install.
Old Mar 30, 2010 | 06:46 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: amp wire
Just make sure that anywhere that + wire runs through metal, it's really really protected! I ran mine similar as above (through pass side), and I encases the wire inside a piece of fuel line with an inside diamter large enough to encase the amp wire, and drilled my hole large enough for the outside diameter of the fuel line.
I have had the privilage of buying several 3rd gen parts cars because some idiot ran their amp wire through the pass side door without protection, and it eventually wore the sheathing off, grounded, shorted, exploded the battery, and burnt the car past repair before the fire trucks arrived! I car I got burnt this way, so bad that the carb actually melted into as puddle on top of the intake!
So unless you want me to get another parts car - protect that amp wire to the extreme!
Old Oct 5, 2013 | 08:24 AM
CHEVYDAWG254's Avatar
Re: amp wire
as im cruising thru forums i find this very helpful
Old Oct 7, 2013 | 12:03 PM
Re: amp wire
does anyone have pics im a visual learner
Old Oct 7, 2013 | 12:22 PM
Re: amp wire
Old Oct 7, 2013 | 12:48 PM
Re: amp wire
RazorN8
Jan 7, 2022 11:44 AM
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
ZsTransAm
Aug 11, 2015 07:30 PM
