Wiring Help
Old Apr 11, 2010 | 10:49 AM
FireInMe17's Avatar
Car: 1990 Camaro RS
Engine: 355 Vortec TPI LT4 Hotcam
Transmission: TH700-R4
Wiring Help
Ok so a while back I installed new Pioneer Speakers in my car in place of the old ones, and I put in 200 watt 3-way speakers in the dash, and 300 watt 4 way speakers in the rear. And now I'm trying to wire in an dual sub 600-watt system in its own box that fits perfectly in the well of the trunk.
But for me to do that, I need to get an amp because I'm still running my original head unit, and getting an after market one is out of the question.
So I can understand splicing a wire to make an extension into the trunk for the subs in the trunk, but now how will these new speakers effect my amp set up?
http://www.walmart.com/ip/DP-Audio-2...200.5/12347328
Is this what I need?
And once I get an amp I need to get an install kit for it, but would I need an install kit for the subs?
When it comes to this kind of stuff I just get confused...
Thanks for any help!
Old Apr 11, 2010 | 11:26 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Wiring Help
Not sure you can run a sub off the OEM head unit - the amp needs a remote on wire from the headunit to operate, as well as it's own inputs for sound from the head unit. If you simply (for example) splice into the rear speaker wires to send the sound to the amp, then you'll be changing the resistance of the output to both the rear speakers and the amp. In other words, speakers are set for certain resistance in ohms, and the resistance assumes single wiring from head unit to those particular speakers.
I'm no car stereo guru - but I don't think you can do what you want without a new head unit that has RCA outputs for the amp and a remote on wire for the amp.
In addition, that amp you're looking at will not drive 2 10" subs very well - heck mine is an el cheapo no brand model and it's 1000 watt. It states 240 watt x 5 speakers (or channels) - you'll only have 2 10" subs - you need more watts and less channels for your subs. UNLESS you thought you'd run the subs AND the rear speakers off that amp - then you would need more channels - but the subs aren't going to be very effective at that wattage, and more watts would blow your rear speakers.
Make sense?
You need an amp for the subs that's a stand alone - high wattage, 2 channel. If you want to amplify the other 4 speakers, then taht walmart amp you were looking at would be good for amplifying the other 2 front and 2 rear speakers.
And I don't think the factoruy head unit is going to have the outputs necessary for any amp.
BUT - like I said - no expert here - let someone else chime in!
Old Apr 11, 2010 | 12:17 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: Wiring Help
this should work for what you are looking for.
Old Apr 11, 2010 | 12:29 PM
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: Wiring Help
shoot forgot the link
http://cgi.ebay.com/ebaymotors/ws/eB...null&viewitem=
Old Apr 11, 2010 | 12:30 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Re: Wiring Help
haha never mind I posted this thinking you said that amp would be ok. But now that I see the link....
Old Apr 11, 2010 | 12:32 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Re: Wiring Help
Ok so once I get that plug and play adapter, how does the amp come into play, and how do I plug that up?
Old Apr 11, 2010 | 01:29 PM
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: Wiring Help
after you wire the adapter as shown, you will plug in the rca that goes to the amp into the adapter, and the blue wire into the amps remote( after wyou have the amp wired properly of course)
Old Apr 11, 2010 | 04:40 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Re: Wiring Help
Originally Posted by ellocojorge
(after wyou have the amp wired properly of course)
Thats the part that I'm wondering about.
Old Apr 11, 2010 | 07:17 PM
Car: 1992 RS
Engine: Carbed 350
Re: Wiring Help
You'll need an amp install kit - it's basically a really thick red wire, with a huge fuse inline, about 20ft long, and a slightly smaller black wire. Red goes directly to battery terminal, and gets routed through the car to the amp, black connects to ground anywhere.
The big red wire - this sucker draws alot of juice - thus it's size. Make triple quadruple sure that it will never short out on anything! Where I drilled holes to t=run mine through the firewall (under the pass side kick panel), I got a piece of fuel line with an inside diameter equal to the outside diameter of the amp wire, ran the amp wire through 4 inches of this fuel line, and then drilled my hole the size of the outside diameter of the fuel line - that way I had a nice extra 3/16ths of an inch rubber fuel line as insulatore to make sure the red wire never would rub through and short.
The reason for the safety precaution ... two parts Camaros I've bought for cheap were on fire when that wire shorted out because someone was in a hurry and didn't protect it - it shorted the battery, causing it to explode, and thus set the car on fire. One of them (a nice 1985 Z28), the resulting fire got so hot under the hood that the carb actually melted on the intake!
Old Apr 11, 2010 | 07:29 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Re: Wiring Help
Oh my god.....
How did you route that wire then to the back of the car for the amp?
And then once I get the amp, the install kit, and the inline plug and play adapter all I do is get the RCA cable to connect it and walah?!
Old Apr 11, 2010 | 07:36 PM
Car: 1992 RS
Engine: Carbed 350
Re: Wiring Help
I drilled my one and only hole through the sidewall close to where the ECM wires run through - the wire then runs through the fenderwell and to the battery. To the rear, it runs under my carpet between the pass seat and the door sill, under the carpet all the way to the rear of the car - coumes out under the bottom edge of the plastic panel in the rear that holds the spare tire.
My remote wire runs from the back of the head unit and under the center console, under the carpet between the rear seats, and under the rear cargo carpet. I basically removed the carpet from the car to run it.
Old Apr 11, 2010 | 08:14 PM
spbird92's Avatar
Car: 1982 pontiac firebird s/e
Engine: rebuilt anemic 2.8
Transmission: 200c
Axle/Gears: 3.08 or 3.21 info anyone?
Re: Wiring Help
you can get a whole wiring kit from wal mart with everything you need
Old Apr 11, 2010 | 10:15 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Re: Wiring Help
Sounds like I'm going to have some work to do once I get everything that I need, it shouldn't be too bad, plus I like to do that kind of stuff anyway.
Yes sir I know, I was looking at the kits today, but until I get the amp, its worthless to buy.
Old Apr 12, 2010 | 12:21 PM
Pug89's Avatar
Car: 1989 Pontiac GTA
Engine: 5.7 TPI L98
Transmission: 700 R4
Axle/Gears: Not Sure
Re: Wiring Help
it might not be a bad idea to have this professionally installed or trying to find someone that has done this before to help you through it. It is not difficult but if you dont know what you are doing you could screw up your whole system and cost you more in the long run rather than having it installed
Old Apr 14, 2010 | 08:43 PM
84blacktransam's Avatar
Car: 1984 trans am
Engine: 1979 350
Transmission: 1972 TH-350
Axle/Gears: 7.625 in/3.23
Re: Wiring Help
nevermind, I found my answer elswhere
Old May 1, 2010 | 04:10 PM
birshking's Avatar
Car: 1985 camaro iroc z-28
Engine: 5.7L
Re: Wiring Help
you could also purchase the amp kit and a in line level converter and as for the remote for the amp. you can tap the yellow wire thats behind the radio. there's two yellow wire one is a little thicker than the other one. the thicker on is the one you want. or tap the radio or ignition fuse for the remote wire
Old May 3, 2010 | 10:19 AM
tylerrentays's Avatar
Car: 1987 Z28 Camaro
Engine: TPI 5.9
Axle/Gears: 3:11
Re: Wiring Help
run two sepreate amps, subs normally cant be run off of the same amp speakers do
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
