Will this work?
Old May 12, 2010 | 10:17 PM
joepackersrock's Avatar
Car: 1991 RS Camaro
Engine: 400 Smallblock
Will this work?
I know these questions are probably bordering on general knowledge for most of you guys but I'm on my first time around with car audio and im working with a walmart salary, so I dont wanna mess it up.
So I have a 2 channel amp that puts out 125 watts rms at 4 ohms per channel, so the question is if i hook up two 4-ohm subs that each handle 250 watts rms (which is about double what they would actually be getting) would they still work properly?
Old May 13, 2010 | 06:12 AM
Weffy's Avatar
Car: (sold 85' IROC Z28)
Engine: (89' 305 TPI)
Transmission: Looking for a classic chevy
Re: Will this work?
yes itl work fine
Old May 21, 2010 | 07:10 PM
game1939's Avatar
Car: 91 chevy camaro
Engine: 383
Transmission: 700r4 built with corvette servo
Axle/Gears: posi 3:73
Re: Will this work?
yes
Old May 21, 2010 | 09:33 PM
F A T B O Y's Avatar
Re: Will this work?
Yeah they'll work, but at what ohm load are you wanting to run it?
Are they single 4ohm speakers, or dual 4ohm?
If it's single 4ohm, then sure you'd be putting the amp under a 4ohm load, seeing (virtually) the rated 125watts.
Old May 22, 2010 | 10:01 PM
Car: 1991 RS Camaro
Re: Will this work?
ya they're single 4ohm, what I was wanting to figure out was if the rating meant 4ohms per channel or 2ohms per times 2 to make 4,
but at any rate i got em wired up and they hit fine so thanks guys case closed
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
