New to the audio world!
Old Jul 19, 2010 | 10:10 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Hello all, i just picked up 5 subs and an amp and i need to know how to wire up the amp, the amp im hooking up is an 800 watt mono pioneer amp and its going to be pushing my two 12" sony xplod 1300watt subs, so what do i need to know and to do to hook up this amp? also will i need to pick up a cap, if so what brand.
Old Jul 20, 2010 | 09:33 PM
slow305rs's Avatar
Re: New to the audio world!
check out page 2 for a wiring diagram
http://www.dormanproducts.com/flipbo...nductTite.html
Old Jul 20, 2010 | 09:48 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Hang on you picked up 5 subs but are only going to run 2 with the amp If what you want to know is how to hook up an amp and how to wire up subs try this site www.the12volt.com
Old Jul 20, 2010 | 10:09 PM
Engine: L31 350
yeah, i dont think i can run 4 12" subs and 1 10" sub lol
Old Jul 20, 2010 | 10:35 PM
Engine: L31 350
what kind of amp wire do i need? and also do i need a cap?
Old Jul 20, 2010 | 11:58 PM
87_TA_GTA's Avatar
Car: 87 T/A GTA
Engine: 5.7L TPI
Axle/Gears: 3.27:1
id say buy a kit like this. http://www.sonicelectronix.com/item_...K4+-+ZCK4.html you can get them cheaper other places probably.
Old Jul 21, 2010 | 08:50 PM
Car: 1988 camaro
Engine: cammed 3.1
For an 800 watt amp you should be ok with a nice 4 gauge amp wiring kit maybe 2 gauge if you ever plan on getting a stronger amp. You should be fine without a cap I'm pushing around 900 watts through 2 12's at 4 ohms and the lights don't dim or anything.
Old Jul 21, 2010 | 10:45 PM
Engine: L31 350
Walmart has something like that , but im sure not buying from walmart lol,
Old Jul 22, 2010 | 12:19 AM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I've gotten a couple Amp wiring kits from Wal-mart, and they work great!
Only problem I have had with it is that the Power wire isn't quite long enough.
Old Jul 22, 2010 | 11:46 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Do yourself a huge favor - make dam sure that amp wire from the battery to the rear of the car is greatly protected. I've seen too many idiots try and run that wire through the pass door, where it gets crimped every time the door is closed - eventually it cuts the insulation and shorts, causing the battery to short, overheat, and explode - this makes a really nice hot fire under the hood that melts everything including carbs!
I ran my amp wire through a hole I drilled close to the connector that runs the pass side wiring harness out of the cabin and into the fender. I got a 6 inch piece of 3/8 rubber fuel line, cut it lengthwise, and wrapped that around my 2 guage amp wire - then I drilled a hole large enough to hold that (like 5/8), filed it down really smooth, and I worked the amp wire with the fuel hose around it through that hole - that way I have an extra 3/16 of insulation around that amp wire where it runs through the firewall - it will never short with all that protection around it.
You can buy any guage amp wire from any local stereo shop by the foot - it's much cheaper than the kits, and you get what you need that way. Make sure you also run a fuse very close to the battery - mine has a 100 amp fuse within 1 foot of the battery.
No need to run a ground all the way from the front - connect the ground for the amp anywhere to the body at the rear of the car.
Old Jul 22, 2010 | 12:13 PM
Engine: L31 350
Was going to ground it where my spare tire is, i went to my local stereo shop and they only has monster? wire and it was already packaged....i was going to run the wire under the carpet near the passenger side and take it through the firewall under the passenger kickpanel
Old Jul 22, 2010 | 12:15 PM
Engine: L31 350
might add that i picked up a cap, i got a boss 2 farad cap2r
gt4373
Oct 8, 2015 10:37 AM
Nick Locking
Car Audio
Sep 30, 2015 04:24 PM
Damon
Sep 26, 2015 04:29 PM
-=Z28=-
Sep 24, 2015 10:21 AM
scottmoyer
Sep 7, 2015 07:06 PM
