mtx or Boss 6x9s?
Old Nov 24, 2010 | 07:26 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
mtx or Boss 6x9s?
has anyone tried either of these 6x9 speakers? i have sony xplods in the rear now but i think i blew them in only 4 months so i need something better, the mtxs are
MTX XT693
# Peak Power 640 watts total (320 watt each speaker)
# RMS Power 160 watts total (80 watt each speaker)
# Impedance: 4 ohms
# Injected polypropylene cones
# Rubber surround
# High temperature aluminum voice coil with kapton former
# 13mm Mylar tweeter
# 2 1/4" Midrange
# Oversized magnet
# Grilles included
# Frequency Response: 36 Hz - 22,000 Hz
# Sensitivity: 93 dB
and the Boss speakers are
Boss Audio CH6940
Boss Audio Chaos Exxtreme Series 6x9" 4-Way Car Speakers
500 Watts Power Handling Each
250 Watts RMS Power Handling Each
Red Poly-Injection Cone w/Butyl Rubber Surround
1.25" High Temperature Aluminum Voice Coil
2.5" Polyimide Cone Midrange
1" Polyimide Dome Tweeter
1/2" Super Piezo Tweeter
80 Oz. Magnet Structure
Frequency Response: 50Hz-20 kHz
Sensitivity: 92dB @ 1 Watt/1 Meter
Impedance: 4 Ohm
Mounting Depth: 3-3/16"
Old Nov 24, 2010 | 08:03 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Re: mtx or Boss 6x9s?
Consider what I'm doing and putting a 6.5 component set in the sail panels. I'm going all out with the premium speaker wire and dynamatting the inside of tha sails but you could just grab a couple pieces of MDF board and make yourself a new plate to replace the stock 6x9 plates and use the eisting wire without the dynamat.
Of course, the sound quality and low frequency reproduction won't be as good.
Old Nov 24, 2010 | 08:07 PM
Engine: L31 350
im just wanting to stick with the 6x9 set up, thank you for the idea though!
Old Nov 24, 2010 | 08:50 PM
Car: 1985 Z28
Are you trying to drive them straight off the head unit or amp them?
Old Nov 24, 2010 | 08:58 PM
Engine: L31 350
just off the headunit, like the factory speakers, all i did when i installed my sonys was i just the stock connectors off from the factory speakers and added my new speaker connectors.
Old Nov 24, 2010 | 09:10 PM
Car: 1985 Z28
Yeah. The 6x9s from a PO I took out were OK like that until I drove them on an amp. Be very leary of speakers that advertise that much wattage for <$50
Old Nov 25, 2010 | 08:39 AM
Engine: L31 350
found some new ones im leaning towards, rockford fosgate R1693 PRIME speakers
Old Nov 25, 2010 | 08:55 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
If you're looking for good cheap speakers I would just get a set of Pioneers. Sometimes you can pick up a used pair for $30-$40.
Old Nov 25, 2010 | 09:00 AM
Engine: L31 350
i was looking at a set of those actually untill i came acrossed the fosgates. i think im going to get them. my buddy has a set in his 88 camaro and they sound good and he hasnt blown them yet and he plays his music louder than me.
tmellott89
Oct 14, 2015 02:06 PM
sandman92084
Sep 12, 2015 10:27 PM
zayne0
Aug 24, 2015 07:22 PM
RED82TA5.7L
Mar 25, 2001 09:57 PM
