Single Sub Box
Old Dec 11, 2010 | 08:07 PM
aqualordx93's Avatar
Car: 1986 Camaro Iroc Z
Engine: V8 305 TPI
Single Sub Box
Ive been looking around for sometime now for a Sub Box for the Well area of the trunk for our thirdgens. i have found alot of Double subs either 10' or 12'
i was wondering if anyone has ever found a box that just fits one, but is the same length as a double. any help will be greatly appreciated!!
Old Dec 11, 2010 | 10:14 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Single Sub Box
i took a 10" prefab box i got in a scrap car and modified it, i just cut a sheet of 3/4" MDF to match the existing top, sealed the entire box because theyre garbage in that aspect with some caulking inside and out, then i cut out the driver side on the box to fit a 12" type R in (verrrryyyy tight squeeze, almost touches both walls front and back) then i glued the mdf i cut onto the top, used some wood nails to secure it, carpeted it and called it a day, i used the passenger side which is now an empty shell pretty much to run my wires through up underneath my amp and i carpeted it to match my interior, for a free box and a bit of my time it was worth it
your only other real option is to build one which is a pain since we have more unusual angles than other boxes, I build cutsom boxes every week and i still hated doing mine lol problem is you have to cut the panels with an angle on certain parts, then get the other attaching panel to match, if you have a wood shop and some determination you can build one
Old Dec 12, 2010 | 09:33 AM
Engine: V8 305 TPI
Re: Single Sub Box
true, ive also thought about getting one with 2 sub holes in it, and then just filling one in and puttin the amp there somehow. you did a good job tho, grats.
Old Dec 12, 2010 | 12:59 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Single Sub Box
If you have the time, money and resources, you can have a custom box made. Or, if you're good with MDF and fiberglass, you can build your own. This one I had built, I left the car at the shop and drove my 89 while having the work done. My installer used as much of the design in the stickies at the top of the forum as possible and came up with a very nice box for a single 12" Memphis MOJO.
https://www.thirdgen.org/forums/car-...amp-build.html
Old Dec 13, 2010 | 03:22 PM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Re: Single Sub Box
I built a box for mine...Took some time to cut and recut but in the end Im very happy with the end result...(1) 10 inch JBL sub and it sounds perfect! I couldnt be any happier.
Old Dec 13, 2010 | 10:43 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: Single Sub Box
Tho only problem with your setup is the OP wanted a 12, IIRC the bottom of the well is 12" front to back and with 3/4" mdf you would only really have 10.5" internal, so it would be impossible to fit a 12, he could buld a box that sits on the shelves and goes up, or he can do the original box plans in the sticky and modify it like I did except the extra mdf wouldn't be needed
Old Dec 13, 2010 | 11:47 PM
GanymedeElegy's Avatar
Car: '83 Z/28
Engine: 350 TBI waiting to be test fired
Transmission: Stock 700R4 with TCC switch
Axle/Gears: 3.23 non posi
Re: Single Sub Box
Ive Seen A Single Box That Goes In Where The Lock Up Box Goes, They Cut Out The Plastic Part And Formed An MDF Box To Take Its Place And Look Almost Flush. I Kinda Like It Cus You Can Keep Your Trunk Space
Old Dec 14, 2010 | 12:08 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: Single Sub Box
That's a ppossibility but it limits you on dimensions and subwoofer choice, the point of building a custom box is to provide the optimal air space for the subwoofer you choose, and if someone wanted to port that they'd be screwed, ported applications are sometimes double and more of a sealed enclosures dimensions, also hatches and upfiring boxes go hand in hand, the soundwaves have a larger space to travel instaead of shooting across and bouncing back, up firing it hits the glass and dissipates forward
If youre not a huge bass nut you could do the side box, but personally id glass it and angle the sub forward and up at an agnle a bit
Old Dec 14, 2010 | 12:18 AM
Car: '83 Z/28
Re: Single Sub Box
I Like That Design Cus Of The Space, But I Have Hand Built A Box For My Friend's 90 Firebird And Even Old Pioneer IMPP 400s Sound REALLY Good (: The Box Is Even On The Small Side Too. I Was Sure The Upfire Sound Was Bouncing Off The Hatch ^^
Old Dec 14, 2010 | 07:52 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Single Sub Box
here's an old one I did a few years back (CAMp3RO was my old sn). Its unfortunately long gone, but there are some measurements that you may be able to play with.
https://www.thirdgen.org/forums/car-...96786-box.html
Old Dec 14, 2010 | 12:07 PM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Re: Single Sub Box
Where do you see that the OP wanted a 12?? He only says he wants a single sub.
Old Dec 14, 2010 | 04:23 PM
Engine: V8 305 TPI
Re: Single Sub Box
i was looking for any kind of single sub box really, but i decided to go double 12'. thanks for all your help though guys, and pics.
BluFBdy- thats a wicked box.
Old Dec 14, 2010 | 05:15 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: Single Sub Box
Thank you, I'm glad you found something your happy with, what subs/amp are you running?
Old Dec 14, 2010 | 06:13 PM
Engine: V8 305 TPI
Re: Single Sub Box
im will be running ( once installed and get them all together)
Alpine MRP-M500 amp
2 12' kicker comps (got on sale, buy 1 get 1 free)
sub box from sub thump
4 alpine speakers, 4X6/6x9
alpine head unit
Old Dec 14, 2010 | 06:28 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: Single Sub Box
Old Dec 16, 2010 | 10:11 PM
Engine: V8 305 TPI
Re: Single Sub Box
well the amp is only powering the Subs, so it should be enough
Old Dec 16, 2010 | 10:57 PM
rivershark2005's Avatar
Car: '87 Camaro Z28
Engine: None
Re: Single Sub Box
If you want, I can make you a box. Just offering. Contact me with the info on the sub and I'll figure up a price for the box. Don't know how much shipping will be, though. These are things to keep in mind, but I don't mind building you one.
Sorry, didn't pay attention to who OP was. LOL I guess we ginally got the system down, so should I plan on building the box?
Old Dec 16, 2010 | 11:12 PM
Car: '83 Z/28
Re: Single Sub Box
loL That Was Funny, I Look At Riversharks Car, 87 Camaro, Engine: None loL
Old Dec 16, 2010 | 11:14 PM
Car: '87 Camaro Z28
Engine: None
Re: Single Sub Box
LMAO It's the truth!!! For now, atleast. Bought a donor car today, so as soon as I get everything moved to my storage unit, I'll be doing a changeover.
Old Jan 5, 2011 | 08:50 PM
camarito's Avatar
Car: 84 Z28 / 11 genesis coupe
Engine: 355/210 heads/275deh/Proform 750 DP
Transmission: 700r4/B&M 2400
Axle/Gears: 02, allu.axle, 3.42, posi
Re: Single Sub Box
i like building my own, a good single 12" in a properly built enclosure sounds so good, and they are allot of fun to build.
this one took me over 6 hours to build including calculations and measurements but it payed off big time the sound and output is incredible for a single 12 with only 400 watts
Old Jan 6, 2011 | 08:45 PM
87350IROC's Avatar
Car: 87' IROC
Re: Single Sub Box
That's a good setup, look into a little monoblock amp to add on later, I've seen the mrpm500s spread too thin across the whole system but that is a pretty damn good start
The M500 is a monoblock amp.
Old Jan 6, 2011 | 08:48 PM
87350IROC's Avatar
Car: 87' IROC
Re: Single Sub Box
A 12" fits down there.
Old Jan 6, 2011 | 11:03 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: Single Sub Box
My bad you're right, edited it, a 4 channel would be what you need next
Old Apr 14, 2011 | 06:14 PM
38snipshow's Avatar
Car: 89 Camaro RS
Engine: 305 TBI (TPI heads)
Axle/Gears: stock
Re: Single Sub Box
If anyone is interested in keeping the trunk space in their Camaro's and also a much more affordable route in regards to car subwoofer systems i recommend Bazooka Tube subwoofers........you can get passive models which require an amp like a regular sub or a amplified bazooka tube which has a built in amplifier. I have one and installation was unbelieably easy, no wires had to go to the battery just one set of wires goes to the stereo and taps into factory wires, ground the sub and 4 skrews to mount it and your done!!!! Check out how clean & simple my set up looks
Attached Thumbnails Single Sub Box-riverhawks_013.jpg   Single Sub Box-riverhawks_014.jpg   Single Sub Box-riverhawks_020.jpg
Old Apr 14, 2011 | 06:32 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: Single Sub Box
I prefer bass. If you want trunk spaqce look into alpines new type R slims, they're only 3 inches deep and they only need a quarter of a cubic foot, build a box to go across the shevles and you still have your trunk space.
No amp or sub running off a deck is going to be worth jack considering most decks only put out 18 watts after thermal loss, which is why we have amplifiers and connections at the battery
Check out jlaudio.com for some schooling
Old Apr 22, 2011 | 03:18 AM
lizzybenny's Avatar
Re: Single Sub Box
Looks so awesome!
Old May 31, 2011 | 07:27 PM
86_sportcoupe's Avatar
Car: 86 Camaro Sport Coupe
Axle/Gears: stock
Re: Single Sub Box
https://www.thirdgen.org/forums/car-...l-sub-box.html
Here is a thread for building your own. All you would have to do is only cut one hole.
Old Mar 17, 2012 | 09:04 AM
83SilverBerlin's Avatar
Re: Single Sub Box
Hey do you have the dimensions to this by chance still? This is exactly what I'm looking to do!
Old Apr 13, 2012 | 09:12 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Re: Single Sub Box
This is exactly what I want to do with my 91!!!!! Could you give me the dimensions of that box? I'm getting an audiobahn 10 inch that would work perfect for this.
Old Apr 19, 2012 | 03:39 AM
BlackBandit007's Avatar
Car: 91 Z28 Vert
Transmission: Automatic
Re: Single Sub Box
^^ I would like those dimensions too!!
Old May 31, 2012 | 07:04 AM
kcgperformance's Avatar
Car: 88 RS Camaro (Z28 Clone)
Engine: LS6, Vengeance VRX5
Transmission: T56, LS7 Clutch
Axle/Gears: Moser 12 bolt 3.73:1 ratio
Re: Single Sub Box
I'm going to be making a custom fiberglass enclosure for a single 10 to go there. I may be a couple weeks til I get to doing it, but I already have a custom audio shop ready to make molds of it if there's enough interest after I have it done. My intent is a single 10 that fits like it could have been a factory piece, without taking up any trunk space at all.
-Kevin
Old May 31, 2012 | 09:39 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Single Sub Box
Mounting a sub either on that side or where the spare tire is supposed to be has been an idea of mine for a few years. Just never took the time to actually make it happen. I'd be interested in the exact dimensions you come up with as well. For now, I have a Bazooka RS 10" down in the sump. Sounds great without being visible.
Old Jun 3, 2012 | 05:10 AM
KingsHustleLA's Avatar
Car: 1986 Camaro
Axle/Gears: 411
Re: Single Sub Box
Nice! Hey How Does Just A Single 12" Type-R Sound In Your 3rd Gen? Do You Like It Better Compared To Any Other Subs You May Have Heard In A 3rd Gen?
Old Jun 4, 2012 | 01:20 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: Single Sub Box
I'm currently running 2 10w1's from JL and they sound worlds better, the type r was a free sub so I just modified what I already had to use the sub. This setup is long gone I enjoyed the type r but it wasn't enough bass for me the 2 JL's are doing great though
Old Jun 10, 2012 | 04:31 PM
Car: 1986 Camaro
Axle/Gears: 411
Re: Single Sub Box
Well Of Course JL's Are The Shiettt LoL I Like That Idea Of Cutting Out Another Top Board For 1 12", I'm Thinking Of Doing That As Well & Cutting Out The Board In The Middle Inside The Box That Separates The 2 12's So I Can Get More Air Space For A Single 12" To Hit, I'm Thinking Of Going With A 12" W3 & Later Maybe A W6. Does 1 12 Still Sound Good In That Box Even With It Still Being Sealed And Not Ported?
Old Jun 10, 2012 | 06:23 PM
LivinLarge's Avatar
Re: Single Sub Box
How hard do those W1's hit? And how do they respond to heavy metal bass rolls?
Old Jun 11, 2012 | 01:31 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: Single Sub Box
You need to be mindful of your airspace, too much and bass response is lost and the sub is likely to be damaged because the voice coil will have poor control, best thing you could do would be to get your box ready and then get your sub, check the air space requirements and compare it to your box, measure the internal volume if the box and if toire close to the right number then you're fine. Subs are touchy too much air and they sound like crap too little and theyre fighting the box to hit properly, both can be remedied but if your sub wants .3 cu ft sealed don't throw it into a 1.25 cu ft box ya known? As far as the port goes having a ported box in these cars isn't the greatest due to the shared space, there's no trunk to drown out the port noise so for me it drives me nuts sealed boxes do just fine especially when you shoehorn the bass in the back
The W1s hit plenty hard for me I have my amp tuned lower than normal because of the design of box I have it was too much bass for me, they do great with 5FDP, I range from techno to country to rock and rap they hit all the notes properly, nothing spectacular on the super low end but I tuned the box that way for the spectrum of music I listen to.
In both of these cases the two points that matter the most are the box, because you need to have a box built for what you're gonna use it for, and the amp, cheap jensen amps and Walmart buy amps are nothing compared to a true rated alpine or jl or rockford amp. Too many times I've heard people knocking a very nice sub because it sounds like crap but they're running it on a jensen 4 channel bridged down... No kidding it sounds like crap I wonder why?? When you step into good subs your other gear needs to be on point, low end amps have horrible dampening factors and fake ratings a Sony 1000 watt usually puts out 300 on a good day.... Problem with that is ubderpowering a sub means the coil isn't getting enough power so it can't properly control the excursion or throw of the sub and sooner or later it will go too far and short. On the other end of the spectrum if you run a super high amp like a rockford t1000 on a single w1 or even a w3 you will burn up the voice coil. The entire process is a touchy thing and you gotta get your stuff matched or you will blow it apart and be out xxxx amount of money
Back on point w1s are good little subs for the price, when I blow them or get bored I'm going to a w3
Old Jun 11, 2012 | 03:54 AM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Re: Single Sub Box
Working on a fiberglass one now
https://www.thirdgen.org/forums/car-...s-sub-box.html
Old Jun 11, 2012 | 11:00 PM
Car: 1986 Camaro
Axle/Gears: 411
Re: Single Sub Box
[quote=BluFBdy;5298766]You need to be mindful of your airspace, too much and bass response is lost and the sub is likely to be damaged because the voice coil will have poor control, best thing you could do would be to get your box ready and then get your sub, check the air space requirements and compare it to your box, measure the internal volume if the box and if toire close to the right number then you're fine. Subs are touchy too much air and they sound like crap too little and theyre fighting the box to hit properly, both can be remedied but if your sub wants .3 cu ft sealed don't throw it into a 1.25 cu ft box ya known? As far as the port goes having a ported box in these cars isn't the greatest due to the shared space, there's no trunk to drown out the port noise so for me it drives me nuts sealed boxes do just fine especially when you shoehorn the bass in the back
Yeah I Get What You're Saying, Hmm Do You Think One 12" W3 Would Be Cool By Itself Using The Whole Box As Airspace Or Do You Think 2 W3's Would Be Better?
Old Sep 2, 2012 | 09:12 AM
brand54's Avatar
Engine: Original 305 5.0L V8
Re: Single Sub Box
Just starting to do sounds for my car who built your. Box and how do I reach them?
Old Sep 2, 2012 | 11:02 AM
brand54's Avatar
Re: Single Sub Box
I know this is a old thread but did you ever find a subwoofer box for just (1) 12inch sub? If so, can you please send me the info. I need one for myself.
Old Feb 2, 2016 | 11:22 AM
  #42
liva687's Avatar
Car: 1987 Iroc-z
Engine: 350HO
Axle/Gears: G92
Re: Single Sub Box
Hey guys, I am looking to build a Sub Box for the Well Area of the Trunk of my car, just like a few users have done here, and i'm wondering if anybody has a set of plans drawn up yet or if somebody would be looking to fabricate one for me for some $$ ? Thanks in Advance!
Old Apr 23, 2016 | 04:18 PM
  #43
Teskey29's Avatar
Re: Single Sub Box
Old Apr 23, 2016 | 04:21 PM
  #44
Teskey29's Avatar
Re: Single Sub Box
i really like this box. Very clean and a nice fit. You wouldn't happen to have the dimensions of it? I have a single 12 inch L7 and would like to do the same thing in my 88.
Old Apr 24, 2016 | 07:35 AM
  #45
camarito's Avatar
Re: Single Sub Box
I do not have the dimensions, I was measuring and building, but it's 3 feet wide and the port is 3x6.5x15, it also uses the smaller section if the trunk so there is allot of cuts, brad nails, screws, glue, it's not that hard but it takes time
Old Jun 4, 2016 | 09:51 AM
  #46
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Single Sub Box
All you have to do is a simple search.
https://www.thirdgen.org/forums/car-...ell-width.html
This is the small enclosure I made and I included dimensions.
If you want to use a 12" then just make it taller or angle the top up so a 12" fits, assuming its the correct air space.
Boxes for thirdgens aren't hard to make, the guys complaining about them being difficult are just used to making boxes for trucks and suvs that have no restrictions.
Old Jun 24, 2016 | 10:54 AM
  #47
a62belair's Avatar
Car: 88 Firebird, 87 Formula
Engine: 2.8, 5.0
Transmission: both 700R4
Axle/Gears: 3.42,3.45
Re: Single Sub Box
I made a shallow box to fit 2 12" subs- difference is, that only one is active. I was given 2 MTX subs, and found only one worked... so I removed the magnet assembly from the bad one; sealed the box with insulation, and installed the subs. It hits good and hard, and sounds good, sonic-ally. As the powered sub moves one way, the other responds the opposite way. Mono Sony 1000w/600wRMS amp powering.
IMG 20130103 132937[1]
Old Jun 24, 2016 | 10:55 AM
  #48
a62belair's Avatar
Engine: 2.8, 5.0
Re: Single Sub Box
I have since cleaned up the box. Covers coming...
Old Jul 4, 2016 | 01:55 PM
  #49
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
Re: Single Sub Box
You can kinda see mine in this pic. It's a custom built sealed box carpeted to match and it has a 10 inch solo Barac L5
$750 L98
Feb 1, 2025 02:25 PM
Night rider327
Oct 9, 2015 09:25 AM
loud91rs
Oct 5, 2015 10:05 PM
tattmann
Sep 27, 2015 05:20 PM
Dragonsys
Sep 25, 2015 03:51 PM
