4x6 Spacer?
Old Apr 19, 2011 | 10:20 PM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
4x6 Spacer?
I need to raise the front driver 4x6 speaker to keep my Kappa's from hitting the internals of my dash. I raised it up enough to make it fit with some washers (I was on a time crunch), but I need more secure way of doing this.
Right now the speaker rattles on the plastic it sits on. I've searched everywhere that I can on a government network and I can't find anything. Everything seems to be an adapter of some sort.
If anyone can point me in the right direction or give me some insight on how you raised the front driver 4x6 up, I would greatly apprecaite it.
Thanks in advance!
Old Apr 20, 2011 | 04:02 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 4x6 Spacer?
a lot of the stereo guys recommend grabbing the composite (plastic, etc) cutting boards you find at Walmart or Target and cut em out to the shape you need. Low cost, easy to find, and cut easily
Old Apr 20, 2011 | 04:04 PM
Engine: L69
Transmission: A4
Re: 4x6 Spacer?
Interesting idea. Thanks a lot for the help.
By the way, the weatherstripping and power window motors you sold me work like a charm!
Old Apr 20, 2011 | 04:38 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: 4x6 Spacer?
Some 4x6s come with the spacer that mount between the flange and the dash. I know my old Alpines did. Once the cones sun rotted I replace them with some Memphis 4x6s. They didn't have a spacer but I reused the Alpine spacers without issue. Maybe call around to some car audio stores in the area see if they have any spacers?
Old Apr 22, 2011 | 05:36 PM
Engine: L69
Transmission: A4
Re: 4x6 Spacer?
I called around to every car audio place in Wichita Falls today. EVERYONE said they just take a butane torch and soften up everything underneath the dash to conform in to the speaker. Hell no!
The only other suggestion I got was to cut out the plastic and cover it with duct tape. Again, no.
I also called Alpine to get the 4x6 spacers that Fireturd is talking about. A customer service rep and a tech guy both had no idea what I was talking about, but I do know for a fact that they exist.
Old Apr 22, 2011 | 09:22 PM
Engine: 383 SBC
Re: 4x6 Spacer?
Well in that case you could just do what 1ADan said and make your own. It shouldn't be hard to cut a piece of wood or plastic that's 1/2" or so to give you the desired spacing.
Old Apr 23, 2011 | 12:11 AM
SportsCoupe85's Avatar
Car: 1985 Camaro Sports Coupe
Engine: 2.5 liter " Iron Duke " (:
Transmission: automatic
Re: 4x6 Spacer?
Heres a little picture for ya , trace the pattern on a peice of osb or whatever wood you have . Self explanitory really
http://s1236.photobucket.com/albums/...nt=speaker.jpg
Old Apr 23, 2011 | 12:16 AM
Re: 4x6 Spacer?
Old Apr 23, 2011 | 07:31 AM
Engine: 383 SBC
Re: 4x6 Spacer?
Here's one the Alpine spacers pictured. I tell which one it is. If I remember right one is plastic and one is metal. http://a248.e.akamai.net/pix.crutchf.../500SPS406.PDF
Old Apr 23, 2011 | 08:31 PM
Engine: L69
Transmission: A4
Re: 4x6 Spacer?
I swung to an independent audio store today. His advice, melt the plastic..... After a lot of talking he said hold on, and came back with a set of 4x6 spacers that came from a Clarion set a speakers. Gave them to me for free!!!
I installed them earlier today and they worked flawlessly!!!!
Old Apr 23, 2011 | 08:44 PM
Engine: 383 SBC
Re: 4x6 Spacer?
Congratz! Glad to hear your spacing is fixed now.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
