Can you mount amp to box?
Old May 19, 2011 | 02:49 PM
1991z28camaro's Avatar
Car: 1992 RS Convertible
Engine: 5.0 L 305 TBI
I would like to know if you can mount you amp to sub woofer box , I was told it could damage it due to vibration , is this true ?
Old May 19, 2011 | 04:37 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Can you mount amp to box?
Depends on the amp and thats only half true, if youre running an old xtant amp with the micro switches they can shake off but it wont cause damage, since ive only seen one of those beasts in such a great while im doubting thats what youve got.
Also unless youre pushing retarded power thru some high end subs you cant shake it apart like 2 w7'S lol mount it on the box youll be fine ive got my dbdrive amp pushing around 600 watts thru my type r 12 with the amp on the box and no problems.
There will be nay sayers but things have changed with the audio game, things are much more durable now
Just for kicks what are you running?
Old May 19, 2011 | 06:04 PM
I just have some crap I am throwing together ,
Head unit ....Panasonic CQ-DFX983U 50w x 4
Sub............Kenwood KFC-W3514DVC (peak power 1500 w)
Amp............Crunch pza 1500.1 or I have a Kicker KX 1200.1
I found plans for a box on this site , but my subs are too big so I am going to run one only.
Old May 19, 2011 | 06:15 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
It'll be fine - heck all I have is a shelf built acreoss the back, with one 10, one 'empty' grill, and the amp is mounted to the underside out of sight. No problems after 2+ years like this.
Old May 19, 2011 | 06:32 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
I did it, only cut one sub hole and use the other side to run wires inside put a hole in the top and mount the amp over it
Old May 19, 2011 | 09:42 PM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
I custom built my sub box and mounted the amp On top of a rubber coated mat surrounded by dynomat. The amp shakes a bit but not enough to do any damage at all
Old May 20, 2011 | 07:09 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
unless the amp is built extremely poorly, you wont have any issues. however, it does make things a little easier for thieves to steal.
Old May 20, 2011 | 01:31 PM
czombie11's Avatar
You could mount it straight or use a mat as dylanjessy said, but electronic stores also sell small rubber squares for computers ($5 American) and they're about as think as your ring finger, won't melt... at least when I used them. They're great for dampening vibration for cheap.
Old May 20, 2011 | 04:06 PM
I will check it out and give them a try .
Old May 30, 2011 | 12:06 PM
Willsmith305's Avatar
Car: 1989 Camaro RS
Engine: 305 Carb
Transmission: 700R4 Mild shift kit.
You won't damage your amp unless it's extremely poorly built. I have my kicker amp mounted on top of my twin 12's and it flexes my doors and my amp has no problems, your definitely in the clear on this one.
Terrell351
Jun 13, 2021 01:13 PM
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
tc7761
Aug 30, 2015 09:45 AM
