are stock speakers okay with subs?
Old Jun 18, 2011 | 12:20 AM
abu1421's Avatar
Car: 1986 Chevrolet Camaro
Engine: V6
Transmission: Automatic
I got stock speakers (i think) in the car, that i know of. I just bout 2 10' JL audio subs to put in the car, ill my stock speakers be able to handle the watts that the amp is going to send to them, or will they blow easily? let me kno. Thanks
Old Jun 18, 2011 | 12:30 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: are stock speakers okay with subs?
just because you're running a sub doesn't mean you have to amp the speakers; just use the amp for the sub and leave the stock speakers on the deck power until you upgrade them. or if you must, you can turn the gain down on the speaker channels to limit how much power is going to them
Old Jun 18, 2011 | 12:31 AM
abu1421's Avatar
Engine: V6
advise taken. thanks a lot !
Old Jun 18, 2011 | 03:17 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Yes, your subs should be run off their own amp, that will have nothing to do with the stock speakers.
Old Jun 18, 2011 | 07:59 PM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
a sub will completely overshadow any mid-high ability. when you finish listen to classical music and listen for clarity it should feel like the soundstage is in front of you and it should be very clear not bassy and muffled. if it is you should get better front 4x6 speaker but leave the rears stock so that they dont steel the soundstage from the front
Old Jun 22, 2011 | 05:37 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
as stated above your sub amp wont affect your speakers, you will be over done with bass though, im guessing you went with w1's or w0's, even with them your bass will be higher than the factory speakers, personally i wasnt satisfied with my audio until i put polk speakers in all around and then amplified them, my type r was way too much bass, it creates a much better balance when your speakers can put out a better and higher range of sound to compliment the new bass
the biggest downside to stock speakers un amplified with subs is that you can only turn it up so much before your subs get to be too much, i couldnt turn mine up on certain songs because the bass was way too much and the stock speakers couldnt even compete
Old Jun 23, 2011 | 05:00 PM
abu1421's Avatar
Engine: V6
i agree with just about everybody here.. I have not rly been able to "BLAST" my subs cuz i cant even hear my speakers after a certain point and that gets to be annoying. I'm gonna have to go out n get a decent set of pioneer speakers or somethin
Old Jun 23, 2011 | 05:39 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
id go with some infinity reference series, they have more highs and mids so it eill even out the sound range very well
Genopsyde
Oct 7, 2015 08:35 PM
Reddeath210
Oct 6, 2015 08:20 AM
89lsc
Aug 14, 2015 04:58 PM
