Rear Speakers for a Convertible?
Old Jun 10, 2001 | 02:33 PM
duffdry's Avatar
Hello. I just picked up a 1989 Convertible for my wife. It has been several years since I owned an F-body and it was not a convertible. Anyway the car is very low mileage and 100% original. I want to keep the entire wire harness complete and uncut.
What size are the rear speakers in the convertible? I know the hatchbacks were 6X9’s. I have one of the 45 watt GM size Pioneer head units installed. Any speaker recommendations? I will not be adding an external amp or subwoofer. All help and advice would be greatly appreciated.
Thanks!
Scott
Old Jun 10, 2001 | 07:23 PM
Pete92TA's Avatar
I think the stock opening is only big enough for a 4*6? its been a while, I had a custome setup done for mine about 4yrs ago. I wanted a 6*9 and they said it probally would not fit. This doesnt mean you cant modify it yourself though. Take it too a local shop and tell them what you want see what they can do for you. that would be my advice.
http://sites.netscape.net/bulldogfrazier/stereo
http://sites.netscape.net/bulldogfrazier/homepage
http://www.fracoinc.com/
Keep your ride shinning with pride
Old Jun 11, 2001 | 12:06 AM
EdgeCrusher's Avatar
Car: 91 Camaro 'vert
in my 91 it takes 5.25. i tried doing the 6x9's i have a really good pair of Cerwin vegas that were from my old car, i tried and tried, but there is NO WAY of putting 6x9's in the rear(of course the vegas have a really huge magnet) This topic was discussed a few months ago, i believe one guy was able to do it..but the panels stuck out aobut an inch.
what i may do is get 5.25 components or mayb 6.5" components and try to put them back there, casue as is...5.25 cant handle much bass at all, and that is with good speakers i put in. well good luck...steve
Old Jun 21, 2001 | 03:59 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I'm the guy that had 6x9s in a few months ago. It wa s royal PITA getting then wedged in there and i still ended up w/ the trim pushed in an inch, lol. When i had the trim off again running wiring for the amp i didn't even pretend to put the 6x9s back in, wasn't worth it.
You can easily get a 6.5" speaker on the factory plate, you just need to drill new screw holes, and if you feel like it, cut the center hole larger. You'll see what i mean once you have the trim off, basically, the speakers are mounted to plastic plates that are mounted by studs from the speaker grilles.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Jun 21, 2001 | 08:27 PM
Ragin'87's Avatar
the rear speakers in my friends 92 convertible were 6.5"s... at least that what the audio shop put in it..
Anthony
previous ride: 87 Camaro LT
350, A4.Comp Cams 268H, Edelbrock Preformer intake, Hedman Headers and y-pipe, gutted cat, No AIR/smog pump. 14x3" Open element K&N, Q-jet w/ D hanger and DA rods, adjusted AV spring tension and quick can.
Current ride: 1992 Camaro RS, K&N, Flowmaster, 305, T5, Black, T-tops, 76k miles.
Old Jul 1, 2001 | 08:03 PM
camaro 22's Avatar
i put 6x9's in my 91rs cnvt with not problem or mod. i didn't have any speakers in there when i bought the car, and since my 89 rs has the 6x9's in the back, i just assumed that the convertible had the same.
Old Jul 3, 2001 | 06:58 PM
91DropTopTA's Avatar
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
So camaro22, who makes the 6x9's in your car?
Old Jul 4, 2001 | 10:57 AM
camaro 22's Avatar
PIONEER
Old Jul 8, 2001 | 12:21 PM
Axle/Gears: Drums?
I'll have to try to find a pair and get them in asap. Do you have the specs for them. Like the mounting depth etc??
Old Jul 14, 2001 | 10:38 PM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
I put the 6x9's in the back of my 88 convertible. They were great until they were ripped out and stolen, compeltely ruioned my side panels in the rear, oh well :-(
Good luck
James
Old Jul 15, 2001 | 11:42 PM
jm91rs's Avatar
6.5s should go in no problem. That is what I put in my car and they look like the same size as the stock ones.
Jeremy
91 rs, convertible, K&N, Edelbrock open element cleaner, 3.73, B&M mega-shifter, goodmark cowl-induction hood,tinted windows,MacEwen Overlays
Coming soon...non red interior with 4th gen charcoal/grey seats
Old Jul 16, 2001 | 06:00 AM
duffdry's Avatar
Do they fit behind the stock speaker grill? Also what holds the grill on? I started working on removing them but I was afraid that I may break them.
Thanks,
<font face="Verdana, Arial" size="2">Originally posted by jm91rs:
</font>
Scott
webmaster for:
www.retrogameroom.com
Old Jul 17, 2001 | 03:54 PM
Ed Maher's Avatar
Car: 04 GTO
Once you have the rear side panels off, getting the speakers out is easy. There are 4 studs that come out the back from the speaker grille that have buts holding the speaker plate one. Once you have the speaker plate off, you just unscrew the speaker.
Like i said above, putting a 6.5" speaker on the plate is cake, all you need is new screw holes. I suppose if you had a shallow enough 6x9 you could get it in there, but the cerwin vega 6x9s i had (which were relatively shallow) did not even remotely fit correctly in there no matter how i positioned them and pushed the panels out noticeably.
...ed
Old Apr 17, 2002 | 10:08 AM
camaro6spd's Avatar
the owner ripped out my brakets before me.....could someone get me a picture of them...i am gettn a pair ok 6.5 kappa CMMDs from my friend to try and see if they fit....hopefully they will, my Kappa CMMD 6x9s from the old coupe....i am not even gonna try lol.
Old Feb 28, 2008 | 06:51 PM
allgood's Avatar
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Re: Rear Speakers for a Convertible?
Anthony
my 92 ta have 6'5 too what brand and model did you used
Old May 22, 2011 | 04:05 PM
spain91camro's Avatar
Car: 91 CAMARO CONVERTIBLE
Engine: STOCK,305 TBI 5.0
Transmission: 700R4 TRANS
Does any one know how to pop off the rear speaker covers it's on so good I feel like I'm breaking it,does it pop off slide off any help you can give any advise would be great thanks...,.,
Old May 23, 2011 | 04:17 AM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
I think you have to remove the whole panel that it mounts to and it has something holding it on from the rear. As well as I remember.
Old May 23, 2011 | 02:00 PM
Thank you yankeecarman for the help...
Old May 28, 2011 | 07:34 PM
mudd746's Avatar
Car: 89 IROC Convertible
Engine: 305HO
I got 4" focal comp in mine
Old May 28, 2011 | 07:36 PM
mudd746's Avatar
Engine: 305HO
https://www.thirdgen.org/forums/conv...ar-panels.html
Old Jun 16, 2011 | 08:56 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
I have 6X9 in the rear of mine it is a 91 Firebird I did have to trim off some of the metal that is behind the speaker to make it fit but O was it worth it
Old Jun 23, 2011 | 09:54 PM
limitlessfbody's Avatar
Car: 91 RS CONVERT.
Engine: 5.0
Transmission: AUTO
ive got the 91 rs since you got yours in, i have a set of 6x9 memphis, i was going to get the 1.5inch spacers, would they go in pretty easy with those?
1992 Trans Am
May 10, 2023 07:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
89lsc
Aug 14, 2015 04:58 PM
