A car without audio.. just isnt the same. Help?
Old Jul 6, 2011 | 10:02 PM
BrennenK014's Avatar
Car: 1987 Trans Am
Engine: V8 305
Transmission: 700 R4
Alright guys so I have a 1987 Trans am, when I had gotten the car there was no stereo and knew nothing about it as it was bought from an estate. Although I did find a kenwood deck out of an old MPI writeoff I bought awhile back. ANyways when I went to wire it in, the guy before me seemed to have some kind of aftermarket electronics in there, I think it may have been a touchscreen, theres a fusebox, and a few other gadgets one says Panasonic I believe. Anyways, I got my friend to help wire me in the deck quick, it worked for quite awhile and now all the sudden it doesnt work?
Now I am not sure if the color codes are the same as it had aftermarket wires as it is.. but I did test the I think it was orange for power and there was nothing, I tryed running a wire from the battery straight to the power source, and nothing? Maybe my deck is messed? Or maybe its not the power wire? Please help me out.
Old Jul 7, 2011 | 12:02 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: A car without audio.. just isnt the same. Help?
you're going to have 2 "power" wires - one is constant 12v and the other is switched (ignition) 12v. your typical aftermarket harness will have yellow as constant and red as switched. your factory side of the harness would have had orange as the constant and yellow as the switched.
both of these wires must be sending power to the radio for it to turn on. hope this helps a bit
Old Jul 8, 2011 | 10:30 PM
Car: 1987 Trans Am
Engine: V8 305
Thank you for the reply, I figured it out. Turns out my deck was fried because when i put it straight to the battery for power there was nothing, it was an old crappy deck anyways but I went and got myself a brand new pioneer deck that was on sale, wired it up, sounds great. I made a custom switch and fuse for it.
lee01
Apr 9, 2016 01:56 PM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
