cant stop fuel frm leaking where line connects to tbi
Old Dec 30, 2011 | 06:38 PM
scarr001's Avatar
Car: 92 camaro rs anniversary edition
Engine: v8 5.0 Tbi
So we accidently unscrewed the fuel fitting where it connects to the tbi, we have the male ended taped, we have the little "o" ring in, but it keeps leaking? This is a 92 rs, v8 5.0 litre. Any ideas? Any silicone or some type of "putty"?
Omg I am sorry abt putting it under audio
Old Dec 30, 2011 | 06:49 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: cant stop fuel frm leaking where line connects to tbi
not sure what this has to do with car audio , but if you are talking about the fittings that are on the fuel pressure regulator the adapter has a plastic seal sealing it up to the pressure regulator on the throttlebody. The o-rings may be leaking on the end of the supply or the return lines.
gm 22514722 fuel feed
gm 22516256 fuel return or dorman 800-013
5/16 and 3/8 viton 0-rings
Old Dec 30, 2011 | 07:00 PM
scarr001's Avatar
Engine: v8 5.0 Tbi
Thnx tunedperformanc, I am not sure abt the connection being to the regulator? I had trbl finding anything abt it in my haynes, but let me try again. Its where the fuel line connects to the tbi on the outside back and has a fitting that looks like an extension nut - let see if I can take a pic
Old Dec 30, 2011 | 07:06 PM
Engine: Lb9
Transmission: M20
should be the fittings in the picture in the link.
http://www.msextra.com/forums/viewto...p?f=94&t=12161
Old Dec 30, 2011 | 07:20 PM
scarr001's Avatar
Engine: v8 5.0 Tbi
IT IS! I think its leaking frm where that connects to the Tbi
Old Dec 30, 2011 | 07:55 PM
Engine: Lb9
Transmission: M20
I don't think the saganaw inlet fitting gasket is sold separately. You might need to go to the dealership to find out for sure or snag one from the junkyard. The rochesther model 220 tbi was used in many applications and are easy yo find in any junk yard.
Old Jan 7, 2012 | 04:16 AM
Engine: Lb9
Transmission: M20
ACDELCO 17111462
Old Jan 7, 2012 | 05:37 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
silicone does not seal fuel
thats the worst thing you can use/try
really easy fix
you just need a stock o-ring from one of these fittings, factory one
pull the fitting and ring from another tb unit, these tb units are dirt common i just scrapped a whole crap ton of them a couple months ago, to the shredder
jklein337
Sep 19, 2018 06:23 PM
Andrew6.688
Dec 13, 2015 10:59 AM
TheExaminer
Aug 26, 2015 04:59 PM
wayshegoes
Aug 17, 2015 12:00 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
