Constant power wire
Old Apr 25, 2012 | 10:04 PM
wsteiger85's Avatar
Car: 91 Z28
Constant power wire
I just hooked up my cd player and for some reason when I hooked everything up normal it didnt want to work but if I unhook the the constant wire and hook it to the ignition power it will work does anyone know the answer for this.
Old Apr 26, 2012 | 12:00 AM
GerryCat09's Avatar
Car: 1986 Trans Am WS6/1991 Firebird
Engine: 305 TPI/305 TBI
Transmission: 700R4 in both
Re: Constant power wire
I've encountered this a few times, try replacing the fuse on the under-dash fuse block labeled ARC.
With it wired the correct way, with the constant hooked up, does it work with the car on accessory? If so you'll turn it off but lose all presets and time, ect. Then the constant isn't getting juice...I've seen people hack into another constant when all they had to do was replace the ARC fuse.
When I had an aftermarket deck in my bird the previous owner had hacked the constant from the plug at the back of the stereo to the main power from the cars harness for the same problem you describe, then I fixed it this way.
Old May 30, 2012 | 10:49 PM
Froddoyo's Avatar
Car: 91' Camaro RS T-top
Engine: 3.1 V6
Yea, I had this same problem. Just replace that fuse. I was running my power on acc for a few days, so Everytime I started my car i had to set my tone settings
BRoss99
Aug 10, 2025 05:08 PM
Bert87
Aug 23, 2015 03:50 PM
jbd1969
Aug 17, 2015 07:06 PM
stalkier
Aug 13, 2015 12:59 PM
ZsTransAm
Aug 11, 2015 07:30 PM
