82' Camaro Fabrication for Subs and Amps?
Old Jun 16, 2012 | 07:51 PM
TheIgnitious's Avatar
Car: 82' Z28 Crossfire
Transmission: Turbo 350
So I just finished restoring pretty much everything on my Camaro. Now it's time for a rocking stereo system! I could easily fab one, but the problem is I need to have full access to my spare tire. I have some ideas, but I would like to see some evidence of people actually doing this. Has anyone accomplished this?
Old Jun 19, 2012 | 08:18 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
Re: 82' Camaro Fabrication for Subs and Amps?
look up mine. i think if you do a search on well sub box or look up project iris, there are pics of it
fully accessable spare
Old Jun 19, 2012 | 08:31 PM
Looks good! I was thinking about doing something similar, but putting two 10" subs side by side, and then stuff an amp under it. BTW! Nice restore! Looks A LOT like mine, condition wise.
Old Jun 19, 2012 | 08:54 PM
morrow's Avatar
Car: 92 Camaro Rs.R
thanks, i recently crashed it , smashed in the front end up to the engine, i rebult it , drove it for the first time in 5 months last week. drives great. looks killer. still need a passenger fender and lower body kit piece on the front end... ill post pics at some point... i have a buddy who did two tens. and put the amps under them. i like the single ten, 600 watt sub with a 1200 watt amp turned down does perfect. i can turn it down and sounds perfectly balanced of turn it up with the integrated sub volume in my dash and rattle ear drums...
Old Jun 19, 2012 | 09:13 PM
Ouch! Didnt total it??? I know these uni-body cars are totaled easy.
And I just got mine fixed. Bought it in a deal with a T-Top for $880. REALLY clean, only one dent on the driver side door.
Old Jun 19, 2012 | 11:22 PM
morrow's Avatar
Car: 92 Camaro Rs.R
oh yea,,, it was totaled but i knew we could fix it , so we did, i would have to see a car go, specialy if i knew i could fix it, we cut th right frame rail cleen off at the crossmember. and graphed in a entirily new core support and frame rail... it is now perfect... good deel on the 880
Old Jun 20, 2012 | 01:24 AM
That's sweet man. My T-Top car used to be a Z28 but some idiot didn't know how to drive and got into multiple accidents. It now has 4 different cars welded onto it. Which is obvious, because I do not think they made a t-top Z28. Main part of car is now RS 25th anniversary.
Old Jun 20, 2012 | 10:28 AM
Blade09's Avatar
Car: '91 RS / '17 FiST
Engine: Internal cumbustion
Transmission: 1 with a fun pedal and 1 without
Axle/Gears: 4th gen ss
I have my amp stowed underneath my subs (I am running 2 10" p1's in a 'false box'). It works great and I like that its hidden but it does get hot underneath there. I can't run my subs for more than about 30-45 minutes without the amp overheating. Its not a serious issue though. I run it pretty hard when I'm cruising and even with it out in the hatch it still overheated after an hour and some change.
So maybe its not much of a problem, just something to think about.
Old Jun 22, 2012 | 11:17 AM
morrow's Avatar
Car: 92 Camaro Rs.R
hmmm, thats odd, my buddy did that and his never over heated, but then again we ported a duct through the face of his box down to the amps and had fans running, im sure that helped alot. my sub is in the driver rear quarter panel and it never over heats in there...
Old Jun 22, 2012 | 12:04 PM
Blade09's Avatar
Im sure porting makes a difference. My box is un ported
Old Jun 24, 2012 | 09:48 AM
morrow's Avatar
Car: 92 Camaro Rs.R
yea maybe thats why,
Old Jun 24, 2012 | 05:32 PM
BigKeg's Avatar
Car: 87 Black Irocz28
Transmission: 700r4 shift kit
Axle/Gears: 3:73 richmend axles and eaton gears
I like the idea of putting the amps in the back seat ...someone had pics ...where they gutted there back seat and the amps sat in side ...looked cool ..
P.s. my iroc-z28 has T-tops and a 350 ...so yes iroc's have T-tops ...but 87 was the first year GM put 350 in 3rd gen's ....
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
kyle5647
Aug 15, 2015 11:56 PM
