Dashboard Speaker Grills???
Old Jun 19, 2012 | 06:59 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Has anyone installed a set of 4x6 Dashboard speaker grills over thier cracked dash grill? I wanna put some in my IROC, but I wanna get the communities opinion. I made a photoshopped image to show what Im trying to explain.
Camarogrill.jpg?t=1340149864
speakergrills.jpg?t=1340149864
Old Jun 19, 2012 | 07:05 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Dashboard Speaker Grills???
I can't think of any reason why you couldn't cut that area out leaving just enough a lip for the aftermarket grill to fit. It would be kinda of like some of the stock Firebird dash pads that have removable speaker grills.
Old Jun 19, 2012 | 07:07 PM
So the Firebird dash has removable grills?
Old Jun 19, 2012 | 07:09 PM
I see... Is it a matching fit for the Camaro's too?
Old Jun 19, 2012 | 07:11 PM
Car: GTA
Unfortunately no...They cannot be interchanged. One off the dashes front to back, I forget which, is deeper, so a gap is left.
Old Jun 19, 2012 | 07:41 PM
Damn. O well.
Old Jun 21, 2012 | 08:53 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Follow mudd746 directions on the grills,This has to be the best repair job I've ever seen
https://www.thirdgen.org/forums/inte...ulit-dash.html
Old Jun 21, 2012 | 11:41 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
The speaker grilles aren't removable.
I wouldn't attempt cutting up my dash if it was in good condition. If you don't like how the project turns out, or you screw up, that's a pretty costly mistake. I would try this first on a shitty dash with cracks all over it and see how it turns out.
Old Jun 21, 2012 | 11:42 PM
Car: GTA
And that is why I did say "cut that area out leaving just enough a lip". Hence the word CUT!
Old Jun 21, 2012 | 11:54 PM
Ok guys. No fighting. My dash is all cracked. That's why I asked. I'm planning on redoing my dashboard any how.
Old Jun 22, 2012 | 12:20 AM
Car: GTA
Wow. You read the above as fighting? I was just restating what I had said, assuming that he misread what I said the first time. Believe me...Those were not "fighting words.
Old Jun 22, 2012 | 12:25 AM
Theres a lot of members who get offended easily. Just tryin to prevent the thread from going south, that's all.
Old Jul 18, 2012 | 12:04 PM
cw3adkins's Avatar
Car: 87 IROC Z-28
Engine: 5.0L 305 TPI V8
I ended up fiberglassing my dash and I did cut out the grills that covered the original 4x6 speakers. I ended up installing 5-1/4" component 'top mount' speakers in place of the 4x6s. From the looks of it, it looks like you could install 6-1/2" speakers if they were top mounted as well, however since I haven't tried it yet, I am unsure exactly.
Old Jul 14, 2013 | 02:28 PM
themcguire's Avatar
Fabric to use
Just wanted to share some info.
I found a fabric that feels like suede and is used in very high end cars. It's called Alcantara.
There is a usa product called Ultrasuede which costs about $90.00 a yard and cheapest I cound Alcantara so far is $110.00 per yard.
http://www.alcantara.com/#/en/home
http://www.alcantara.com/#/en/menu/a...ons/automotive
From wiki: Alcantara is composed of about 68% polyester and 32% polyurethane giving increased durability and stain resistance. The appearance and tactile feel of the material is similar to that of http://en.wikipedia.org/wiki/Suede, and it may be incorrectly identified as such.
Old Jul 14, 2013 | 04:29 PM
mantaguy's Avatar
Engine: 5.0 EFI
Well,It's been a year,lets see some results.
1990RSVERT
Exterior Parts Wanted
May 27, 2024 11:23 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86IROC112
Nov 7, 2015 06:50 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
wanext
Oct 6, 2015 12:18 AM
