Component Setups
Old Jul 3, 2012 | 11:16 PM
LivinLarge's Avatar
Component Setups
Please post pictures and details on your component speaker setups in your cars!
Old Jul 9, 2012 | 09:06 PM
LivinLarge's Avatar
Re: Component Setups
Nobody has components??
Old Jul 11, 2012 | 12:04 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
I've never seen components in our cars that didn't look ridiculous to be honest, there is little to no point in doing a component setup because that would require door mods, possibly building out and then mounting the tweeter in the flat panel is there a reason why you're asking? Are you planning this or?
Old Jul 12, 2012 | 06:38 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I built these solely for performance, but I do have to admit that I'm quite fond of how they look too.
Old Jul 12, 2012 | 08:48 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
I like those, normally when people think components they automaticly go for the door, those look good and probably sound great I've been toying with the idea of kick panel speakers but I'm too lazy to do the fiberglass work for it, maybe when work slows down and I have free time ill get around to it, I just blew my 4x6 on the drivers side so I'm gonna do the 5.25 up there and when it gives up on me i will probably do something like those, that's awesome work c
Old Jul 12, 2012 | 09:46 PM
87350IROC's Avatar
Car: 87' IROC
Woofer
Tweeter
I really would like to go with kick panels, but am not willing to give up that much clutch pedal room. Maybe one day I will make my own with super shallow drivers.
Old Jul 12, 2012 | 09:55 PM
Jim85IROC's Avatar
My car has a manual and it's not in the way at all. I had to give up my dead pedal, but thete's plenty of room to shift.
Old Jul 12, 2012 | 10:09 PM
Jimmy64D's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 2.77
The trim panel tweeter is a good idea. Fairly simple I assume?
Old Jul 12, 2012 | 10:10 PM
87350IROC's Avatar
Car: 87' IROC
Yes, that is actually what I mean. With the old auto, you could use the area where the clutch would normally be to rest your foot.
You and I spoke a while ago about making a set of slim kicks. You weren't interested at the time, how about now? The kicks you made look great.
Old Jul 12, 2012 | 10:12 PM
87350IROC's Avatar
Car: 87' IROC
Yup, very easy. There was no room for the tweeter cup nut, so instead I epoxied the cups in place.
Old Jul 13, 2012 | 08:33 AM
Jim85IROC's Avatar
Baby #2 pops out next week. I'm expecting to have even less free time very soon.
Old Jul 13, 2012 | 09:12 AM
87350IROC's Avatar
Car: 87' IROC
Ah, no worries. And congrats.
Old Jul 21, 2012 | 06:11 PM
Seurehkt's Avatar
Car: 86' Camaro
Engine: 350 V8 4b.
Transmission: Automatic
Woofer
Tweeter
Where did you get the mount for the woofer in the dash?
Old Jul 21, 2012 | 06:32 PM
87350IROC's Avatar
Car: 87' IROC
Its just the stock 4x6 bracket that has been cut up.
Old Jul 25, 2012 | 04:30 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Old set up with q-form kick panels
Old Aug 6, 2012 | 03:16 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
i did Fiberglas door panels and built them out, haven't installed the components yet, but the mid woofer will be in the door and the tweeter in the dash
Old Aug 7, 2012 | 02:47 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Woofer
What size is that? Brand?
That set-up looks great. The tweeter looks right at home in the pillar.
Old Aug 7, 2012 | 07:31 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Infinity reference series, 6.5 speaker, they're good speakers for the price they have good miss and highs so if you use subs they blend perfectly
Old Aug 7, 2012 | 07:51 PM
87350IROC's Avatar
Car: 87' IROC
Yup 6020CS is the part number. They are fine. I think they are seriously hindered in the dash though.
Old Aug 7, 2012 | 08:22 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
That's to be expected given the loacation though lol
Old Aug 8, 2012 | 10:14 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I have an ADS 4" component system in my Camaro. 4" is in the stock dash location with an adapter, tweeter is on each door where the power lock switch is located 9manual locks on my ride). I've heard both the pillar mounted tweeters and th door mounted ones - definitely prefer the door mounts, although most cars can't have them that way.
The door speaker idea is good - at least for the woofer as you don't lose any foot space , but the tweeters need to be up higher and/or aimed at your ears.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Pac J
May 17, 2020 10:44 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
customblackbird
Oct 1, 2015 04:30 PM
tattmann
Sep 27, 2015 05:20 PM
