Single Din Flip out screen DVD/Nav
Old Nov 21, 2012 | 05:28 PM
moshyjoshy's Avatar
Car: 89 I-Roc Z
Engine: 305 5.0L
Hey, I am looking for a good unit to fit my '89 Camaro Iroc-Z. I am looking for certain specific features (back-up camera, Sirius, Navigation, DVD), if it has most, I'll be more then happy!!
I've been looking at the BOSS BV9996B 7 in-dash, but the reviews are a little... how can I say this... two sided?
Can anyone recommend a good single din flip-out screen dash? Or tell me if this one will fit into my Camaro w/o any hardships with the screen opening?
I do like the double dins but I like the flip outs more. I don't mind covering my H VAC unit, doesn't bother me too much.
Old Nov 22, 2012 | 08:38 PM
soul.justice's Avatar
Car: 1985 Firebird Trans Am
Engine: 305 4bbl
Axle/Gears: 3.08
Re: Single Din Flip out screen DVD/Nav
http://www.crutchfield.com/p_130P630....html?tp=20217
Go big or go home. With these single DINs if you're gonna spend the money you may as well get a good one. If you're not looking to drop 700 bucks on a head unit Jensen is a fairly decent brand, I have a VM9115 in my car. None of these have DVD navigation but have pretty much everything else, you may be able to find a single din navi unit on fleabay.
Doing a double DIN will require a custom made radio/ac trim bezel or some type of hacking on your existing one. From what I remember when I dismantled half my car and took my AC control box out I don't really think there'd be enough room back there to jam a double DIN in anyway.
Do not buy BOSS audio products. They're cheaply made, my friend. Hope this helps.
Old Nov 22, 2012 | 09:55 PM
moshyjoshy's Avatar
Car: 89 I-Roc Z
Engine: 305 5.0L
Ok, thank you for the input
My main question is though, if I get a deck with a 7" screen, when it pops out would it hit my shift stick? It's an automatic but I feel that my center console is in the way, no? I'm just worried that I'd have to put my car into drive just to open up the screen. Am I just over worrying or would it actually slide out without any issues?
Old Nov 23, 2012 | 09:40 PM
Engine: 305 4bbl
Axle/Gears: 3.08
I can't attest to other types of shifters, but I still have the original T handle shifter in my car, and the screen does not hit the shifter when it pops out. You'll want to set the angle on the screen when you first set it up though as these head units are set to recline back to the farthest position on start up and it will hit the part of the dash where your rear glass defrost controls are. Set the angle on the screen and make sure your unit defaults to that position when you open it, or you'll burn the motors up in it pretty quick.
Old Jan 1, 2013 | 05:43 PM
cj z28's Avatar
Car: 1999 silverado 1989 iroc 1988 s10
Engine: 4.8,5.7,4.3
I actually put a boss flip out in my 89 today car has an auto and the straight up shifter clears shifter and the screen clears the back of the center console as long as u use the angle feature and put it all the way down it sits up straight and looks great
Old Jan 1, 2013 | 06:25 PM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
My flip up hits the dash for a couple of seconds and goes to the pre-adjusted angle I made. It must be a cheap one. I have a Pioneer media deck with a 3" screen that I am considering as a replacement. It supports IPhone, iPod, SD card and USB with Blue tooth. There is no CD support though.
Old Jan 5, 2013 | 12:27 PM
kitt23's Avatar
to bad this type wouldnt fit my 83 ta
Old Jan 5, 2013 | 02:19 PM
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
Transmission: Tremec 3550
Axle/Gears: 9 Bolt - 3:45
Why not double din?
http://shop.doubledmods.com/Camaro-D...zels_c1291.htm
Old Jan 6, 2013 | 03:26 AM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
You can pick up some really nice 2 din Pioneers for not too much. The entry level units are very good!!!
Old Jan 7, 2013 | 09:56 PM
85 ZXX's Avatar
Originally Posted by Scamo-2.8
Wow, no issues with a/c heat controls? It looks good. Is there a pic of this on a car I can see?
Old Jan 7, 2013 | 10:35 PM
Tinbender59's Avatar
Car: 1997 K1500 SS/SB
Engine: LT1 with TPI on top
Transmission: 4L60E/np241,
I have a Panasonic CQ-VD7005U DVD with remote that I"would like to sell, , very light use. I bought it for the wife's Burb but she dont like touch screens, put a **** stereo in it so this needs a new home. It works great. two Franklins will get it If you are interisted I would do the deal through PayPal so we both are protected.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LT1Formula
Oct 8, 2015 08:34 PM
dusterbd
Sep 29, 2015 08:40 AM
Eric-86sc
Sep 28, 2015 11:37 AM
