Plans for a Box
Old May 3, 2013 | 09:12 PM
Barlow8869's Avatar
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
Plans for a Box
anyone have plans for a sub box for 10s that fits down in the well that they will pass on for free?
Old May 3, 2013 | 09:41 PM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Re: Plans for a Box
The stickied topics at the top of this forum are your friend:
https://www.thirdgen.org/forums/car-...l-sub-box.html
Old May 4, 2013 | 01:05 AM
Barlow8869's Avatar
Re: Plans for a Box
i may be able to work with that, but i want mine to sit lower in the well, may just go with 1 12" sub
Old May 5, 2013 | 06:19 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Plans for a Box
It's all you need.
Old May 6, 2013 | 05:39 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Re: Plans for a Box
I did this a while back, took me about a day.
Its perfect IMO. T Tops dont hit. Box CANNOT be taken out without removing the rear hatch motor cover so not easily stolen. Only other thing I would add would be a speaker grill for protection but haven't yet.
Sub is a P2D410 Fosgate. Box is on the low side of the recommended volume but it still sounds great.
Old May 9, 2013 | 09:37 PM
Barlow8869's Avatar
Re: Plans for a Box
that is more what i am looking for, do you have the measurements of the box? thank you
Old May 11, 2013 | 10:03 AM
Keoman's Avatar
Re: Plans for a Box
Recommended sealed volume by Fosgate for this sub is 0.50 to 0.85
Recommended vented volume is 1.4 with Port Diameter and Length at 4" x 14"
These dimensions put the box at 1.43 cu. ft. using 1/2" MDF
I planned on making this a vented enclosure but placing the port tube in the box before I finished it, The sub would come VERY close if not in contact with the tube. So I decided to leave it be. Still sounds good to the untrained ear.
The dimensions below are outside dimensions. Make sure you are AT or under the dimensions I have shown, anything bigger and you're not going to be able to get the box into the well of you car.
and here's the beauty of interior paneling. Hiding all the messy stuff!
Old May 11, 2013 | 03:10 PM
Barlow8869's Avatar
Re: Plans for a Box
thank you, that will work just fine, think ill make a different top plate, to make it fit snug in the well, if i can get one mocked up that i like
GTAman
Jul 3, 2024 07:29 PM
J-money
Jan 4, 2019 09:45 AM
HP52TA
Feb 3, 2018 10:51 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
